For the latest stable version, please use Spring Security 6.4.1! |
DaoAuthenticationProvider
is an AuthenticationProvider
implementation that uses a UserDetailsService
and PasswordEncoder
to authenticate a username and password.
This section examines how DaoAuthenticationProvider
works within Spring Security.
The following figure explains the workings of the AuthenticationManager
in figures from the Reading the Username & Password section.
Usage The authentication
Filter
from the Reading the Username & Password section passes a UsernamePasswordAuthenticationToken
to the AuthenticationManager
, which is implemented by ProviderManager
The
ProviderManager
is configured to use an AuthenticationProvider of type DaoAuthenticationProvider
looks up the UserDetails
from the UserDetailsService
uses the PasswordEncoder
to validate the password on the UserDetails
returned in the previous step.
When authentication is successful, the
Authentication
that is returned is of type UsernamePasswordAuthenticationToken
and has a principal that is the UserDetails
returned by the configured UserDetailsService
Ultimately, the returned UsernamePasswordAuthenticationToken
is set on the SecurityContextHolder
by the authentication Filter
