For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
Java Configuration
General support for Java configuration was added to Spring Framework in Spring 3.1. Spring Security 3.2 introduced Java configuration to let users configure Spring Security without the use of any XML.spring-doc.cn
If you are familiar with the Security Namespace Configuration, you should find quite a few similarities between it and Spring Security Java configuration.spring-doc.cn
Spring Security provides lots of sample applications to demonstrate the use of Spring Security Java Configuration.spring-doc.cn
Hello Web Security Java Configuration
The first step is to create our Spring Security Java Configuration. The configuration creates a Servlet Filter known as the springSecurityFilterChain, which is responsible for all the security (protecting the application URLs, validating submitted username and passwords, redirecting to the log in form, and so on) within your application. The following example shows the most basic example of a Spring Security Java Configuration:spring-doc.cn
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.context.annotation.*;
import org.springframework.security.config.annotation.authentication.builders.*;
import org.springframework.security.config.annotation.web.configuration.*;
@EnableWebSecurity
public class WebSecurityConfig {
	public UserDetailsService userDetailsService() {
		InMemoryUserDetailsManager manager = new InMemoryUserDetailsManager();
		manager.createUser(User.withDefaultPasswordEncoder().username("user").password("password").roles("USER").build());
		return manager;
This configuration is not complex or extensive, but it does a lot:spring-doc.cn
AbstractSecurityWebApplicationInitializer
The next step is to register the springSecurityFilterChain with the WAR file. You can do so in Java configuration with Spring’s WebApplicationInitializer support in a Servlet 3.0+ environment. Not surprisingly, Spring Security provides a base class (AbstractSecurityWebApplicationInitializer) to ensure that the springSecurityFilterChain gets registered for you. The way in which we use AbstractSecurityWebApplicationInitializer differs depending on if we are already using Spring or if Spring Security is the only Spring component in our application.spring-doc.cn
AbstractSecurityWebApplicationInitializer without Existing Spring
If you are not using Spring or Spring MVC, you need to pass the WebSecurityConfig to the superclass to ensure the configuration is picked up:spring-doc.cn
import org.springframework.security.web.context.*;
public class SecurityWebApplicationInitializer
	extends AbstractSecurityWebApplicationInitializer {
	public SecurityWebApplicationInitializer() {
		super(WebSecurityConfig.class);
The SecurityWebApplicationInitializer:spring-doc.cn
AbstractSecurityWebApplicationInitializer with Spring MVC
If we use Spring elsewhere in our application, we probably already have a WebApplicationInitializer that is loading our Spring Configuration. If we use the previous configuration, we would get an error. Instead, we should register Spring Security with the existing ApplicationContext. For example, if we use Spring MVC, our SecurityWebApplicationInitializer could look something like the following:spring-doc.cn
This onlys register the springSecurityFilterChain for every URL in your application. After that, we need to ensure that WebSecurityConfig was loaded in our existing ApplicationInitializer. For example, if we use Spring MVC it is added in the getRootConfigClasses():spring-doc.cn
public class MvcWebApplicationInitializer extends
		AbstractAnnotationConfigDispatcherServletInitializer {
	protected Class<?>[] getRootConfigClasses() {
		return new Class[] { WebSecurityConfig.class };
	// ... other overrides ...
HttpSecurity
Thus far, our WebSecurityConfig contains only information about how to authenticate our users. How does Spring Security know that we want to require all users to be authenticated? How does Spring Security know we want to support form-based authentication? Actually, there is a configuration class (called SecurityFilterChain) that is being invoked behind the scenes. It is configured with the following default implementation:spring-doc.cn
	http
		.authorizeRequests(authorize -> authorize
			.anyRequest().authenticated()
		.formLogin(withDefaults())
		.httpBasic(withDefaults());
	return http.build();
The default configuration (shown in the preceding example):spring-doc.cn
  • Ensures that any request to our application requires the user to be authenticatedspring-doc.cn
  • Lets users authenticate with form based loginspring-doc.cn
  • Lets users authenticate with HTTP Basic authenticationspring-doc.cn
Note that this configuration is parallels the XML Namespace configuration:spring-doc.cn
<http>
	<intercept-url pattern="/**" access="authenticated"/>
	<form-login />
	<http-basic />
</http>
Multiple HttpSecurity Instances
We can configure multiple HttpSecurity instances just as we can have multiple <http> blocks in XML. The key is to register multiple SecurityFilterChain @Beans. The following example has a different configuration for URL’s that start with /api/.spring-doc.cn
@EnableWebSecurity
public class MultiHttpSecurityConfig {
	@Bean                                                             (1)
	public UserDetailsService userDetailsService() throws Exception {
		// ensure the passwords are encoded properly
		UserBuilder users = User.withDefaultPasswordEncoder();
		manager.createUser(users.username("user").password("password").roles("USER").build());
		manager.createUser(users.username("admin").password("password").roles("USER","ADMIN").build());
		return manager;
	@Order(1)                                                        (2)
	public SecurityFilterChain apiFilterChain(HttpSecurity http) throws Exception {
		http
			.securityMatcher("/api/**")                                   (3)
				.anyRequest().hasRole("ADMIN")
	@Bean                                                            (4)
	public SecurityFilterChain formLoginFilterChain(HttpSecurity http) throws Exception {
		http
			.formLogin(withDefaults());
1 Configure Authentication as usual.
2 Create an instance of SecurityFilterChain that contains @Order to specify which SecurityFilterChain should be considered first.
3 The http.securityMatcher states that this HttpSecurity is applicable only to URLs that start with /api/.
4 Create another instance of SecurityFilterChain. If the URL does not start with /api/, this configuration is used. This configuration is considered after apiFilterChain, since it has an @Order value after 1 (no @Order defaults to last).
Custom DSLs
You can provide your own custom DSLs in Spring Security:spring-doc.cn
public class MyCustomDsl extends AbstractHttpConfigurer<MyCustomDsl, HttpSecurity> {
	private boolean flag;
	public void init(HttpSecurity http) throws Exception {
		// any method that adds another configurer
		// must be done in the init method
		http.csrf().disable();
	public void configure(HttpSecurity http) throws Exception {
		ApplicationContext context = http.getSharedObject(ApplicationContext.class);
		// here we lookup from the ApplicationContext. You can also just create a new instance.
		MyFilter myFilter = context.getBean(MyFilter.class);
		myFilter.setFlag(flag);
		http.addFilterBefore(myFilter, UsernamePasswordAuthenticationFilter.class);
	public MyCustomDsl flag(boolean value) {
		this.flag = value;
		return this;
	public static MyCustomDsl customDsl() {
		return new MyCustomDsl();
This is actually how methods like HttpSecurity.authorizeRequests() are implemented.spring-doc.cn
You can then use the custom DSL:spring-doc.cn
@EnableWebSecurity
public class Config {
		http
			.apply(customDsl())
				.flag(true)
				.and()
The code is invoked in the following order:spring-doc.cn
If you want, you can have HttpSecurity add MyCustomDsl by default by using SpringFactories. For example, you can create a resource on the classpath named META-INF/spring.factories with the following contents:spring-doc.cn
org.springframework.security.config.annotation.web.configurers.AbstractHttpConfigurer = sample.MyCustomDsl
You can also explicit disable the default:spring-doc.cn
@EnableWebSecurity
		http
			.apply(customDsl()).disable()
Post Processing Configured Objects
Spring Security’s Java configuration does not expose every property of every object that it configures. This simplifies the configuration for a majority of users. After all, if every property were exposed, users could use standard bean configuration.spring-doc.cn
While there are good reasons to not directly expose every property, users may still need more advanced configuration options. To address this issue, Spring Security introduces the concept of an ObjectPostProcessor, which can be used to modify or replace many of the Object instances created by the Java Configuration. For example, to configure the filterSecurityPublishAuthorizationSuccess property on FilterSecurityInterceptor, you can use the following:spring-doc.cn
	http
			.withObjectPostProcessor(new ObjectPostProcessor<FilterSecurityInterceptor>() {
				public <O extends FilterSecurityInterceptor> O postProcess(
						O fsi) {
					fsi.setPublishAuthorizationSuccess(true);
					return fsi;
