For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
Logout
Spring Security provides a logout endpoint by default. Once logged in, you can GET /logout to see a default logout confirmation page, or you can POST /logout to initiate logout. This will:spring-doc.cn
  • clear the ServerCsrfTokenRepository, ServerSecurityContextRepository, andspring-doc.cn
  • redirect back to the login pagespring-doc.cn
Often, you will want to also invalidate the session on logout. To achieve this, you can add the WebSessionServerLogoutHandler to your logout configuration, like so:spring-doc.cn
SecurityWebFilterChain http(ServerHttpSecurity http) throws Exception {
    DelegatingServerLogoutHandler logoutHandler = new DelegatingServerLogoutHandler(
            new WebSessionServerLogoutHandler(), new SecurityContextServerLogoutHandler()
    http
        .authorizeExchange((exchange) -> exchange.anyExchange().authenticated())
        .logout((logout) -> logout.logoutHandler(logoutHandler));
    return http.build();
fun http(http: ServerHttpSecurity): SecurityWebFilterChain {
    val customLogoutHandler = DelegatingServerLogoutHandler(
        WebSessionServerLogoutHandler(), SecurityContextServerLogoutHandler()
    return http {
        authorizeExchange {
        logout {
            logoutHandler = customLogoutHandler
