For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
Run-As Authentication Replacement
The AbstractSecurityInterceptor is able to temporarily replace the Authentication object in the SecurityContext and SecurityContextHolder during the secure object callback phase. This only occurs if the original Authentication object was successfully processed by the AuthenticationManager and AccessDecisionManager. The RunAsManager indicates the replacement Authentication object, if any, that should be used during the SecurityInterceptorCallback.spring-doc.cn
By temporarily replacing the Authentication object during the secure object callback phase, the secured invocation can call other objects that require different authentication and authorization credentials. It can also perform any internal security checks for specific GrantedAuthority objects. Because Spring Security provides a number of helper classes that automatically configure remoting protocols based on the contents of the SecurityContextHolder, these run-as replacements are particularly useful when calling remote web services.spring-doc.cn
Configuration
Spring Security provices a RunAsManager interface:spring-doc.cn
Authentication buildRunAs(Authentication authentication, Object object,
	List<ConfigAttribute> config);
boolean supports(ConfigAttribute attribute);
boolean supports(Class clazz);
The first method returns the Authentication object that should replace the existing Authentication object for the duration of the method invocation. If the method returns null, it indicates no replacement should be made. The second method is used by the AbstractSecurityInterceptor as part of its startup validation of configuration attributes. The supports(Class) method is called by a security interceptor implementation to ensure that the configured RunAsManager supports the type of secure object that the security interceptor presents.spring-doc.cn
Spring Security provides one concrete implementation of RunAsManager. The RunAsManagerImpl class returns a replacement RunAsUserToken if any ConfigAttribute starts with RUN_AS_. If any such ConfigAttribute is found, the replacement RunAsUserToken contains the same principal, credentials, and granted authorities as the original Authentication object, along with a new SimpleGrantedAuthority for each RUN_AS_ ConfigAttribute. Each new SimpleGrantedAuthority is prefixed with ROLE_, followed by the RUN_AS ConfigAttribute. For example, a RUN_AS_SERVER results in the replacement RunAsUserToken containing a ROLE_RUN_AS_SERVER granted authority.spring-doc.cn
The replacement RunAsUserToken is like any other Authentication object. It needs to be authenticated by the AuthenticationManager, probably through delegation to a suitable AuthenticationProvider. The RunAsImplAuthenticationProvider performs such authentication. It accepts as valid any RunAsUserToken presented.spring-doc.cn
To ensure malicious code does not create a RunAsUserToken and present it for guaranteed acceptance by the RunAsImplAuthenticationProvider, the hash of a key is stored in all generated tokens. The RunAsManagerImpl and RunAsImplAuthenticationProvider is created in the bean context with the same key:spring-doc.cn
<bean id="runAsManager"
	class="org.springframework.security.access.intercept.RunAsManagerImpl">
<property name="key" value="my_run_as_password"/>
</bean>
<bean id="runAsAuthenticationProvider"
	class="org.springframework.security.access.intercept.RunAsImplAuthenticationProvider">
</bean>
By using the same key, each RunAsUserToken can be validated because it was created by an approved RunAsManagerImpl. The RunAsUserToken is immutable after creation, for security reasons.spring-doc.cn
