For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
Reactive Migrations
If you have already performed the initial migration steps for your Reactive application, you’re now ready to perform steps specific to Reactive applications.spring-doc.cn
Exploit Protection Migrations
The following steps relate to changes around how to configure CSRF.spring-doc.cn
Configure tokenFromMultipartDataEnabled
In Spring Security 5.8, the method tokenFromMultipartDataEnabled was deprecated in favor of ServerCsrfTokenRequestAttributeHandler#setTokenFromMultipartDataEnabled.spring-doc.cn
To address the deprecation, the following code:spring-doc.cn
Configure tokenFromMultipartDataEnabled with DSL
SecurityWebFilterChain securityWebFilterChain(ServerHttpSecurity http) {
	http
		.csrf((csrf) -> csrf
			.tokenFromMultipartDataEnabled(true)
	return http.build();
open fun securityWebFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
	return http {
		csrf {
			tokenFromMultipartDataEnabled = true
can be replaced with:spring-doc.cn
Configure tokenFromMultipartDataEnabled with ServerCsrfTokenRequestAttributeHandler
	ServerCsrfTokenRequestAttributeHandler requestHandler = new ServerCsrfTokenRequestAttributeHandler();
	requestHandler.setTokenFromMultipartDataEnabled(true);
	http
			.csrfTokenRequestHandler(requestHandler)
	val requestHandler = ServerCsrfTokenRequestAttributeHandler()
	requestHandler.tokenFromMultipartDataEnabled = true
	return http {
		csrf {
			csrfTokenRequestHandler = requestHandler
Protect against CSRF BREACH
You can opt into Spring Security 6’s default support for BREACH protection of the CsrfToken using the following configuration:spring-doc.cn
CsrfToken BREACH Protection
	XorServerCsrfTokenRequestAttributeHandler requestHandler = new XorServerCsrfTokenRequestAttributeHandler();
	http
	val requestHandler = XorServerCsrfTokenRequestAttributeHandler()
	return http {
		csrf {
Opt-out Steps
If configuring CSRF BREACH protection gives you trouble, take a look at these scenarios for optimal opt out behavior:spring-doc.cn
I am using AngularJS or another Javascript framework
If you are using AngularJS and the HttpClientXsrfModule (or a similar module in another framework) along with CookieServerCsrfTokenRepository.withHttpOnlyFalse(), you may find that automatic support no longer works.spring-doc.cn
In this case, you can configure Spring Security to validate the raw CsrfToken from the cookie while keeping CSRF BREACH protection of the response using a custom ServerCsrfTokenRequestHandler with delegation, like so:spring-doc.cn
Configure CsrfToken BREACH Protection to validate raw tokens
	CookieServerCsrfTokenRepository tokenRepository = CookieServerCsrfTokenRepository.withHttpOnlyFalse();
	XorServerCsrfTokenRequestAttributeHandler delegate = new XorServerCsrfTokenRequestAttributeHandler();
	// Use only the handle() method of XorServerCsrfTokenRequestAttributeHandler and the
	// default implementation of resolveCsrfTokenValue() from ServerCsrfTokenRequestHandler
	ServerCsrfTokenRequestHandler requestHandler = delegate::handle;
	http
			.csrfTokenRepository(tokenRepository)
WebFilter csrfCookieWebFilter() {
	return (exchange, chain) -> {
		Mono<CsrfToken> csrfToken = exchange.getAttributeOrDefault(CsrfToken.class.getName(), Mono.empty());
		return csrfToken.doOnSuccess(token -> {
			/* Ensures the token is subscribed to. */
		}).then(chain.filter(exchange));
	val tokenRepository = CookieServerCsrfTokenRepository.withHttpOnlyFalse()
	val delegate = XorServerCsrfTokenRequestAttributeHandler()
	val requestHandler = ServerCsrfTokenRequestHandler(delegate::handle)
	return http.invoke {
		csrf {
			csrfTokenRepository = tokenRepository
fun csrfCookieWebFilter(): WebFilter {
	return WebFilter { exchange, chain ->
		val csrfToken = exchange.getAttribute<Mono<CsrfToken>>(CsrfToken::class.java.name) ?: Mono.empty()
		csrfToken.doOnSuccess {
		}.then(chain.filter(exchange))
I need to opt out of CSRF BREACH protection for another reason
If CSRF BREACH protection does not work for you for another reason, you can opt out using the following configuration:spring-doc.cn
Opt out of CsrfToken BREACH protection
	http
	return http {
		csrf {
Use AuthorizationManager for Method Security
Method Security has been improved through the AuthorizationManager API and direct use of Spring AOP.spring-doc.cn
Should you run into trouble with making these changes, you can follow the opt out steps at the end of this section.spring-doc.cn
In Spring Security 5.8, useAuthorizationManager was added to @EnableReactiveMethodSecurity to allow applications to opt in to AuthorizationManager's features.spring-doc.cn
Change useAuthorizationManager to true
To opt in, change useAuthorizationManager to true like so:spring-doc.cn
changes to:spring-doc.cn
@EnableReactiveMethodSecurity(useAuthorizationManager = true)
Check for AnnotationConfigurationExceptions
useAuthorizationManager activates stricter enforcement of Spring Security’s non-repeatable or otherwise incompatible annotations. If after turning on useAuthorizationManager you see AnnotationConfigurationExceptions in your logs, follow the instructions in the exception message to clean up your application’s method security annotation usage.spring-doc.cn
Opt-out Steps
If you ran into trouble with AuthorizationManager for reactive method security, you can opt out by changing:spring-doc.cn
@EnableReactiveMethodSecurity(useAuthorizationManager = false)
Propagate AuthenticationServiceExceptions
AuthenticationFilter propagates AuthenticationServiceExceptions to the ServerAuthenticationEntryPoint. Because AuthenticationServiceExceptions represent a server-side error instead of a client-side error, in 6.0, this changes to propagate them to the container.spring-doc.cn
Configure ServerAuthenticationFailureHandler to rethrow AuthenticationServiceExceptions
To prepare for the 6.0 default, httpBasic and oauth2ResourceServer should be configured to rethrow AuthenticationServiceExceptions.spring-doc.cn
For each, construct the appropriate authentication entry point for httpBasic and for oauth2ResourceServer:spring-doc.cn
ServerAuthenticationEntryPoint bearerEntryPoint = new BearerTokenServerAuthenticationEntryPoint();
ServerAuthenticationEntryPoint basicEntryPoint = new HttpStatusServerEntryPoint(HttpStatus.UNAUTHORIZED);
val bearerEntryPoint: ServerAuthenticationEntryPoint = BearerTokenServerAuthenticationEntryPoint()
val basicEntryPoint: ServerAuthenticationEntryPoint = HttpStatusServerEntryPoint(HttpStatus.UNAUTHORIZED)
If you use a custom AuthenticationEntryPoint for either or both mechanisms, use that one instead for the remaining steps.spring-doc.cn
Then, construct and configure a ServerAuthenticationEntryPointFailureHandler for each one:spring-doc.cn
AuthenticationFailureHandler bearerFailureHandler = new ServerAuthenticationEntryPointFailureHandler(bearerEntryPoint);
bearerFailureHandler.setRethrowAuthenticationServiceException(true);
AuthenticationFailureHandler basicFailureHandler = new ServerAuthenticationEntryPointFailureHandler(basicEntryPoint);
basicFailureHandler.setRethrowAuthenticationServiceException(true)
val bearerFailureHandler: AuthenticationFailureHandler = ServerAuthenticationEntryPointFailureHandler(bearerEntryPoint)
val basicFailureHandler: AuthenticationFailureHandler = ServerAuthenticationEntryPointFailureHandler(basicEntryPoint)
Finally, wire each authentication failure handler into the DSL, like so:spring-doc.cn
http
    .httpBasic((basic) -> basic.authenticationFailureHandler(basicFailureHandler))
    .oauth2ResourceServer((oauth2) -> oauth2.authenticationFailureHandler(bearerFailureHandler))
http {
    httpBasic {
        authenticationFailureHandler = basicFailureHandler
    oauth2ResourceServer {
        authenticationFailureHandler = bearerFailureHandler
Opt-out Steps
To opt-out of the 6.0 defaults and instead continue to pass AuthenticationServiceException on to ServerAuthenticationEntryPoints, you can follow the same steps as above, except set rethrowAuthenticationServiceException to false.spring-doc.cn
Add @Configuration annotation
In 6.0, @Configuration is removed from @EnableWebFluxSecurity and @EnableReactiveMethodSecurity.spring-doc.cn
To prepare for this, wherever you are using one of these annotations, you may need to add @Configuration. For example, @EnableReactiveMethodSecurity changes from:spring-doc.cn
public class MyConfiguration {
open class MyConfiguration {
Address OAuth2 Client Deprecations
ServerOAuth2AuthorizedClientExchangeFilterFunction
The method setAccessTokenExpiresSkew(…​) can be replaced with one of:spring-doc.cn
  • ClientCredentialsReactiveOAuth2AuthorizedClientProvider#setClockSkew(…​)spring-doc.cn
  • RefreshTokenReactiveOAuth2AuthorizedClientProvider#setClockSkew(…​)spring-doc.cn
  • JwtBearerReactiveOAuth2AuthorizedClientProvider#setClockSkew(…​)spring-doc.cn
The method setClientCredentialsTokenResponseClient(…​) can be replaced with the constructor ServerOAuth2AuthorizedClientExchangeFilterFunction(ReactiveOAuth2AuthorizedClientManager).spring-doc.cn
See Client Credentials for more information.spring-doc.cn
WebSessionOAuth2ServerAuthorizationRequestRepository
The method setAllowMultipleAuthorizationRequests(…​) has no direct replacement.spring-doc.cn
UnAuthenticatedServerOAuth2AuthorizedClientRepository
The class UnAuthenticatedServerOAuth2AuthorizedClientRepository has no direct replacement. Usage of the class can be replaced with AuthorizedClientServiceReactiveOAuth2AuthorizedClientManager.spring-doc.cn
Add @Configuration to @Enable* annotations
In 6.0, all Spring Security’s @Enable* annotations had their @Configuration removed. While convenient, it was not consistent with the rest of the Spring projects and most notably Spring Framework’s @Enable* annotations. Additionally, the introduction of support for @Configuration(proxyBeanMethods=false) in Spring Framework provides another reason to remove @Configuration meta-annotation from Spring Security’s @Enable* annotations and allow users to opt into their preferred configuration mode.spring-doc.cn
The following annotations had their @Configuration removed:spring-doc.cn
For example, if you are using @EnableWebFluxSecurity, you will need to change:spring-doc.cn
public class SecurityConfig {
And the same applies to every other annotation listed above.spring-doc.cn
