For the latest stable version, please use Spring Security 6.4.1! |
Core Configuration
Spring Boot 2.x Sample
Spring Boot 2.x brings full auto-configuration capabilities for OAuth 2.0 Login.
This section shows how to configure the OAuth 2.0 Login WebFlux sample using Google as the Authentication Provider and covers the following topics:
Initial setup
To use Google’s OAuth 2.0 authentication system for login, you must set up a project in the Google API Console to obtain OAuth 2.0 credentials.
Google’s OAuth 2.0 implementation for authentication conforms to the OpenID Connect 1.0 specification and is OpenID Certified. |
Follow the instructions on the OpenID Connect page, starting in the section, "Setting up OAuth 2.0".
After completing the "Obtain OAuth 2.0 credentials" instructions, you should have a new OAuth Client with credentials consisting of a Client ID and a Client Secret.
Setting the redirect URI
The redirect URI is the path in the application that the end-user’s user-agent is redirected back to after they have authenticated with Google and have granted access to the OAuth Client (created in the previous step) on the Consent page.
In the "Set a redirect URI" sub-section, ensure that the Authorized redirect URIs field is set to localhost:8080/login/oauth2/code/google
The default redirect URI template is {baseUrl}/login/oauth2/code/{registrationId} .
The registrationId is a unique identifier for the ClientRegistration.
For our example, the registrationId is google .
If the OAuth Client is running behind a proxy server, it is recommended to check Proxy Server Configuration to ensure the application is correctly configured.
Also, see the supported URI template variables for redirect-uri .
Configure application.yml
Now that you have a new OAuth Client with Google, you need to configure the application to use the OAuth Client for the authentication flow. To do so:
Go to
application.yml
and set the following configuration:spring: security: oauth2: client: registration: (1) google: (2) client-id: google-client-id client-secret: google-client-secret
OAuth Client properties1 spring.security.oauth2.client.registration
is the base property prefix for OAuth Client properties.2 Following the base property prefix is the ID for the ClientRegistration
, such as google. -
Replace the values in the
client-id
andclient-secret
property with the OAuth 2.0 credentials you created earlier.
Boot up the application
Launch the Spring Boot 2.x sample and go to localhost:8080
You are then redirected to the default auto-generated login page, which displays a link for Google.
Click on the Google link, and you are then redirected to Google for authentication.
After authenticating with your Google account credentials, the next page presented to you is the Consent screen. The Consent screen asks you to either allow or deny access to the OAuth Client you created earlier. Click Allow to authorize the OAuth Client to access your email address and basic profile information.
At this point, the OAuth Client retrieves your email address and basic profile information from the UserInfo Endpoint and establishes an authenticated session.
Spring Boot 2.x Property Mappings
The following table outlines the mapping of the Spring Boot 2.x OAuth Client properties to the ClientRegistration properties.
Spring Boot 2.x | ClientRegistration |
A ClientRegistration can be initially configured using discovery of an OpenID Connect Provider’s Configuration endpoint or an Authorization Server’s Metadata endpoint, by specifying the spring.security.oauth2.client.provider.[providerId].issuer-uri property.
CommonOAuth2Provider
pre-defines a set of default client properties for a number of well known providers: Google, GitHub, Facebook, and Okta.
For example, the authorization-uri
, token-uri
, and user-info-uri
do not change often for a Provider.
Therefore, it makes sense to provide default values in order to reduce the required configuration.
As demonstrated previously, when we configured a Google client, only the client-id
and client-secret
properties are required.
The following listing shows an example:
spring:
security:
oauth2:
client:
registration:
google:
The auto-defaulting of client properties works seamlessly here because the registrationId (google ) matches the GOOGLE enum (case-insensitive) in CommonOAuth2Provider .
For cases where you may want to specify a different registrationId
, such as google-login
, you can still leverage auto-defaulting of client properties by configuring the provider
property.
spring:
security:
oauth2:
client:
registration:
google-login: (1)
provider: google (2)
1 | The registrationId is set to google-login . |
2 | The provider property is set to google , which will leverage the auto-defaulting of client properties set in CommonOAuth2Provider.GOOGLE.getBuilder() . |
Configuring Custom Provider Properties
There are some OAuth 2.0 Providers that support multi-tenancy, which results in different protocol endpoints for each tenant (or sub-domain).
For example, an OAuth Client registered with Okta is assigned to a specific sub-domain and have their own protocol endpoints.
For these cases, Spring Boot 2.x provides the following base property for configuring custom provider properties: spring.security.oauth2.client.provider.[providerId]
spring:
security:
oauth2:
client:
registration:
okta:
client-id: okta-client-id
provider:
okta: (1)
authorization-uri: https://your-subdomain.oktapreview.com/oauth2/v1/authorize
token-uri: https://your-subdomain.oktapreview.com/oauth2/v1/token
user-info-uri: https://your-subdomain.oktapreview.com/oauth2/v1/userinfo
user-name-attribute: sub
jwk-set-uri: https://your-subdomain.oktapreview.com/oauth2/v1/keys
1 | The base property (spring.security.oauth2.client.provider.okta ) allows for custom configuration of protocol endpoint locations. |
Overriding Spring Boot 2.x Auto-configuration
The Spring Boot 2.x auto-configuration class for OAuth Client support is ReactiveOAuth2ClientAutoConfiguration
It performs the following tasks:
Registers a
ReactiveClientRegistrationRepository
composed ofClientRegistration
(s) from the configured OAuth Client properties. -
Registers a
SecurityWebFilterChain
and enables OAuth 2.0 Login throughserverHttpSecurity.oauth2Login()
If you need to override the auto-configuration based on your specific requirements, you may do so in the following ways:
Register a ReactiveClientRegistrationRepository @Bean
The following example shows how to register a ReactiveClientRegistrationRepository
Java
Kotlin
public class OAuth2LoginConfig {
public ReactiveClientRegistrationRepository clientRegistrationRepository() {
return new InMemoryReactiveClientRegistrationRepository(this.googleClientRegistration());
private ClientRegistration googleClientRegistration() {
return ClientRegistration.withRegistrationId("google")
.clientId("google-client-id")
.clientSecret("google-client-secret")
.clientAuthenticationMethod(ClientAuthenticationMethod.CLIENT_SECRET_BASIC)
.authorizationGrantType(AuthorizationGrantType.AUTHORIZATION_CODE)
.redirectUri("{baseUrl}/login/oauth2/code/{registrationId}")
.scope("openid", "profile", "email", "address", "phone")
.authorizationUri("https://accounts.google.com/o/oauth2/v2/auth")
.tokenUri("https://www.googleapis.com/oauth2/v4/token")
.userInfoUri("https://www.googleapis.com/oauth2/v3/userinfo")
.userNameAttributeName(IdTokenClaimNames.SUB)
.jwkSetUri("https://www.googleapis.com/oauth2/v3/certs")
.clientName("Google")
fun clientRegistrationRepository(): ReactiveClientRegistrationRepository {
return InMemoryReactiveClientRegistrationRepository(googleClientRegistration())
private fun googleClientRegistration(): ClientRegistration {
.build()
Register a SecurityWebFilterChain @Bean
The following example shows how to register a SecurityWebFilterChain
with @EnableWebFluxSecurity
and enable OAuth 2.0 login through serverHttpSecurity.oauth2Login()
Java
Kotlin
public class OAuth2LoginSecurityConfig {
public SecurityWebFilterChain securityWebFilterChain(ServerHttpSecurity http) {
http
.authorizeExchange(authorize -> authorize
.oauth2Login(withDefaults());
return http.build();
fun securityWebFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
return http {
authorizeExchange {
oauth2Login { }
Completely Override the Auto-configuration
The following example shows how to completely override the auto-configuration by registering a ReactiveClientRegistrationRepository
and a SecurityWebFilterChain
Java
Kotlin
http
return http {
authorizeExchange {
oauth2Login { }
.build()
Java Configuration without Spring Boot 2.x
If you are not able to use Spring Boot 2.x and would like to configure one of the pre-defined providers in CommonOAuth2Provider
(for example, Google), apply the following configuration:
Java
Kotlin
http
public ReactiveOAuth2AuthorizedClientService authorizedClientService(
ReactiveClientRegistrationRepository clientRegistrationRepository) {
return new InMemoryReactiveOAuth2AuthorizedClientService(clientRegistrationRepository);
public ServerOAuth2AuthorizedClientRepository authorizedClientRepository(
ReactiveOAuth2AuthorizedClientService authorizedClientService) {
return new AuthenticatedPrincipalServerOAuth2AuthorizedClientRepository(authorizedClientService);
return CommonOAuth2Provider.GOOGLE.getBuilder("google")
return http {
authorizeExchange {
oauth2Login { }
fun authorizedClientService(
clientRegistrationRepository: ReactiveClientRegistrationRepository
): ReactiveOAuth2AuthorizedClientService {
return InMemoryReactiveOAuth2AuthorizedClientService(clientRegistrationRepository)
fun authorizedClientRepository(
authorizedClientService: ReactiveOAuth2AuthorizedClientService
): ServerOAuth2AuthorizedClientRepository {
return AuthenticatedPrincipalServerOAuth2AuthorizedClientRepository(authorizedClientService)
.build()
