For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
Configuration Migrations
The following steps relate to changes around how to configure HttpSecurity, WebSecurity, and AuthenticationManager.spring-doc.cn
Add @Configuration annotation
In 6.0, @Configuration is removed from @EnableWebSecurity, @EnableMethodSecurity, @EnableGlobalMethodSecurity, and @EnableGlobalAuthentication.spring-doc.cn
To prepare for this, wherever you are using one of these annotations, you may need to add @Configuration. For example, @EnableMethodSecurity changes from:spring-doc.cn
public class MyConfiguration {
open class MyConfiguration {
Use the new requestMatchers methods
In Spring Security 5.8, the antMatchers, mvcMatchers, and regexMatchers methods were deprecated in favor of new requestMatchers methods.spring-doc.cn
The new requestMatchers methods were added to authorizeHttpRequests, authorizeRequests, CSRF configuration, WebSecurityCustomizer and any other places that had the specialized RequestMatcher methods. The deprecated methods are removed in Spring Security 6.spring-doc.cn
These new methods have more secure defaults since they choose the most appropriate RequestMatcher implementation for your application. In summary, the new methods choose the MvcRequestMatcher implementation if your application has Spring MVC in the classpath, falling back to the AntPathRequestMatcher implementation if Spring MVC is not present (aligning the behavior with the Kotlin equivalent methods).spring-doc.cn
To start using the new methods, you can replace the deprecated methods with the new ones. For example, the following application configuration:spring-doc.cn
@EnableWebSecurity
public class SecurityConfig {
    public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
        http
            .authorizeHttpRequests((authz) -> authz
                .antMatchers("/api/admin/**").hasRole("ADMIN")
                .antMatchers("/api/user/**").hasRole("USER")
                .anyRequest().authenticated()
        return http.build();
can be changed to:spring-doc.cn
@EnableWebSecurity
        http
                .requestMatchers("/api/admin/**").hasRole("ADMIN")
                .requestMatchers("/api/user/**").hasRole("USER")
If you have Spring MVC in the classpath and are using the mvcMatchers methods, you can replace it with the new methods and Spring Security will choose the MvcRequestMatcher implementation for you. The following configuration:spring-doc.cn
@EnableWebSecurity
@EnableWebMvc
        http
                .mvcMatchers("/admin/**").hasRole("ADMIN")
is equivalent to:spring-doc.cn
@EnableWebSecurity
@EnableWebMvc
        http
                .requestMatchers("/admin/**").hasRole("ADMIN")
If you are customizing the servletPath property of the MvcRequestMatcher, you can now use the MvcRequestMatcher.Builder to create MvcRequestMatcher instances that share the same servlet path:spring-doc.cn
@EnableWebSecurity
@EnableWebMvc
        http
                .mvcMatchers("/admin").servletPath("/path").hasRole("ADMIN")
                .mvcMatchers("/user").servletPath("/path").hasRole("USER")
The code above can be rewritten using the MvcRequestMatcher.Builder and the requestMatchers method:spring-doc.cn
@EnableWebSecurity
@EnableWebMvc
    SecurityFilterChain securityFilterChain(HttpSecurity http, HandlerMappingIntrospector introspector) throws Exception {
        MvcRequestMatcher.Builder mvcMatcherBuilder = new MvcRequestMatcher.Builder(introspector).servletPath("/path");
        http
                .requestMatchers(mvcMatcherBuilder.pattern("/admin")).hasRole("ADMIN")
                .requestMatchers(mvcMatcherBuilder.pattern("/user")).hasRole("USER")
If you are having problem with the new requestMatchers methods, you can always switch back to the RequestMatcher implementation that you were using. For example, if you still want to use AntPathRequestMatcher and RegexRequestMatcher implementations, you can use the requestMatchers method that accepts a RequestMatcher instance:spring-doc.cn
import static org.springframework.security.web.util.matcher.AntPathRequestMatcher.antMatcher;
import static org.springframework.security.web.util.matcher.RegexRequestMatcher.regexMatcher;
@EnableWebSecurity
        http
                .requestMatchers(antMatcher("/user/**")).hasRole("USER")
                .requestMatchers(antMatcher(HttpMethod.POST, "/user/**")).hasRole("ADMIN")
                .requestMatchers(regexMatcher(".*\\?x=y")).hasRole("SPECIAL") // matches /any/path?x=y
Note that the above sample uses static factory methods from AntPathRequestMatcher and RegexRequestMatcher to improve readability.spring-doc.cn
If you are using the WebSecurityCustomizer interface, you can replace the deprecated antMatchers methods:spring-doc.cn
public WebSecurityCustomizer webSecurityCustomizer() {
	return (web) -> web.ignoring().antMatchers("/ignore1", "/ignore2");
with their requestMatchers counterparts:spring-doc.cn
	return (web) -> web.ignoring().requestMatchers("/ignore1", "/ignore2");
The same way, if you are customizing the CSRF configuration to ignore some paths, you can replace the deprecated methods with the requestMatchers methods:spring-doc.cn
    http
        .csrf((csrf) -> csrf
            .ignoringAntMatchers("/no-csrf")
    http
            .ignoringRequestMatchers("/no-csrf")
Use the new securityMatchers methods
In Spring Security 5.8, the antMatchers, mvcMatchers and requestMatchers methods from HttpSecurity were deprecated in favor of new securityMatchers methods.spring-doc.cn
Note that these methods are not the same from authorizeHttpRequests methods which were deprecated in favor of the requestMatchers methods. However, the securityMatchers methods are similar to the requestMatchers methods in the sense that they will choose the most appropriate RequestMatcher implementation for your application. In summary, the new methods choose the MvcRequestMatcher implementation if your application has Spring MVC in the classpath, falling back to the AntPathRequestMatcher implementation if Spring MVC is not present (aligning the behavior with the Kotlin equivalent methods). Another reason for adding the securityMatchers methods is to avoid confusion with the requestMatchers methods from authorizeHttpRequests.spring-doc.cn
    http
        .antMatcher("/api/**", "/app/**")
can be rewritten using the securityMatchers methods:spring-doc.cn
    http
        .securityMatcher("/api/**", "/app/**")
If you are using a custom RequestMatcher in your HttpSecurity configuration:spring-doc.cn
    http
        .requestMatcher(new MyCustomRequestMatcher())
public class MyCustomRequestMatcher implements RequestMatcher {
you can do the same using securityMatcher:spring-doc.cn
    http
        .securityMatcher(new MyCustomRequestMatcher())
If you are combining multiple RequestMatcher implementations in your HttpSecurity configuration:spring-doc.cn
    http
        .requestMatchers((matchers) -> matchers
            .antMatchers("/api/**", "/app/**")
            .requestMatchers(new MyCustomRequestMatcher())
you can change it by using securityMatchers:spring-doc.cn
    http
        .securityMatchers((matchers) -> matchers
            .requestMatchers("/api/**", "/app/**", "/admin/**")
If you are having problems with the securityMatchers methods choosing the RequestMatcher implementation for you, you can always choose the RequestMatcher implementation yourself:spring-doc.cn
    http
            .requestMatchers(antMatcher("/api/**"), antMatcher("/app/**"))
            .requestMatchers(antMatcher("/api/admin/**")).hasRole("ADMIN")
Stop Using WebSecurityConfigurerAdapter
Publish a SecurityFilterChain Bean
Spring Security 5.4 introduced the capability to publish a SecurityFilterChain bean instead of extending WebSecurityConfigurerAdapter. In 6.0, WebSecurityConfigurerAdapter is removed. To prepare for this change, you can replace constructs like:spring-doc.cn
public class SecurityConfiguration extends WebSecurityConfigurerAdapter {
    protected void configure(HttpSecurity http) throws Exception {
        http
            .authorizeHttpRequests((authorize) -> authorize
            .httpBasic(withDefaults());
open class SecurityConfiguration: WebSecurityConfigurerAdapter() {
    override fun configure(val http: HttpSecurity) {
        http {
            authorizeHttpRequests {
            httpBasic {}
public class SecurityConfiguration {
        http
open class SecurityConfiguration {
    fun filterChain(http: HttpSecurity): SecurityFilterChain {
        http {
            httpBasic {}
        return http.build()
Publish a WebSecurityCustomizer Bean
Spring Security 5.4 introduced WebSecurityCustomizer to replace configure(WebSecurity web) in WebSecurityConfigurerAdapter. To prepare for its removal, you can replace code like the following:spring-doc.cn
    public void configure(WebSecurity web) {
    override fun configure(val web: WebSecurity) {
    fun webSecurityCustomizer(): WebSecurityCustomizer {
Publish an AuthenticationManager Bean
As part of WebSecurityConfigurerAdapter removal, configure(AuthenticationManagerBuilder) is also removed. Preparing for its removal will differ based on your reason for using it.spring-doc.cn
LDAP Authentication
If you are using auth.ldapAuthentication() for LDAP authentication support, you can replace:spring-doc.cn
    protected void configure(AuthenticationManagerBuilder auth) throws Exception {
        auth
                .userDetailsContextMapper(new PersonContextMapper())
                .userDnPatterns("uid={0},ou=people")
                .contextSource()
                .port(0);
    override fun configure(auth: AuthenticationManagerBuilder) {
        auth
                .userDetailsContextMapper(PersonContextMapper())
                .contextSource()
                .port(0)
    public EmbeddedLdapServerContextSourceFactoryBean contextSourceFactoryBean() {
        EmbeddedLdapServerContextSourceFactoryBean contextSourceFactoryBean =
            EmbeddedLdapServerContextSourceFactoryBean.fromEmbeddedLdapServer();
        contextSourceFactoryBean.setPort(0);
        return contextSourceFactoryBean;
    AuthenticationManager ldapAuthenticationManager(BaseLdapPathContextSource contextSource) {
        LdapBindAuthenticationManagerFactory factory =
            new LdapBindAuthenticationManagerFactory(contextSource);
        factory.setUserDnPatterns("uid={0},ou=people");
        factory.setUserDetailsContextMapper(new PersonContextMapper());
        return factory.createAuthenticationManager();
    fun contextSourceFactoryBean(): EmbeddedLdapServerContextSourceFactoryBean {
        val contextSourceFactoryBean: EmbeddedLdapServerContextSourceFactoryBean =
    fun ldapAuthenticationManager(val contextSource: BaseLdapPathContextSource): AuthenticationManager {
        val factory = LdapBindAuthenticationManagerFactory(contextSource)
        factory.setUserDetailsContextMapper(PersonContextMapper())
JDBC Authentication
If you are using auth.jdbcAuthentication() for JDBC Authentication support, you can replace:spring-doc.cn
    public DataSource dataSource() {
        return new EmbeddedDatabaseBuilder()
            .setType(EmbeddedDatabaseType.H2)
        UserDetails user = User.withDefaultPasswordEncoder()
            .username("user")
            .password("password")
            .roles("USER")
            .withDefaultSchema()
                .dataSource(this.dataSource)
                .withUser(user);
    fun dataSource(): DataSource {
        return EmbeddedDatabaseBuilder()
            .build()
    override fun configure(val auth: AuthenticationManagerBuilder) {
            .username("user")
            .roles("USER")
            .build()
                .withUser(user)
            .addScript(JdbcDaoImpl.DEFAULT_USER_SCHEMA_DDL_LOCATION)
    public UserDetailsManager users(DataSource dataSource) {
            .username("user")
            .roles("USER")
        JdbcUserDetailsManager users = new JdbcUserDetailsManager(dataSource);
        users.createUser(user);
        return users;
            .build()
    fun users(val dataSource: DataSource): UserDetailsManager {
        val user = User.withDefaultPasswordEncoder()
            .username("user")
            .roles("USER")
            .build()
        val users = JdbcUserDetailsManager(dataSource)
        return users
In-Memory Authentication
If you are using auth.inMemoryAuthentication() for In-Memory Authentication support, you can replace:spring-doc.cn
            .username("user")
            .roles("USER")
            .withUser(user);
            .username("user")
            .roles("USER")
            .build()
            .withUser(user)
    public InMemoryUserDetailsManager userDetailsService() {
            .username("user")
            .roles("USER")
        return new InMemoryUserDetailsManager(user);
    fun userDetailsService(): InMemoryUserDetailsManager {
            .username("user")
            .roles("USER")
            .build()
        return InMemoryUserDetailsManager(user)
Add @Configuration to @Enable* annotations
In 6.0, all Spring Security’s @Enable* annotations had their @Configuration removed. While convenient, it was not consistent with the rest of the Spring projects and most notably Spring Framework’s @Enable* annotations. Additionally, the introduction of support for @Configuration(proxyBeanMethods=false) in Spring Framework provides another reason to remove @Configuration meta-annotation from Spring Security’s @Enable* annotations and allow users to opt into their preferred configuration mode.spring-doc.cn
The following annotations had their @Configuration removed:spring-doc.cn
For example, if you are using @EnableWebSecurity, you will need to change:spring-doc.cn
@EnableWebSecurity
@EnableWebSecurity
And the same applies to every other annotation listed above.spring-doc.cn
Other Scenarios
If you are using AuthenticationManagerBuilder for something more sophisticated, you can publish your own AuthenticationManager @Bean or wire an AuthenticationManager instance into the HttpSecurity DSL with HttpSecurity#authenticationManager.spring-doc.cn
