For the latest stable version, please use Spring Security 6.4.1! |
JDBC Authentication
Spring Security’s JdbcDaoImpl
implements UserDetailsService to provide support for username/password based authentication that is retrieved using JDBC.
JdbcUserDetailsManager
extends JdbcDaoImpl
to provide management of UserDetails
through the UserDetailsManager
interface.
UserDetails
based authentication is used by Spring Security when it is configured to accept a username/password for authentication.
In the following sections we will discuss:
The Default Schema used by Spring Security JDBC Authentication
Default Schema
Spring Security provides default queries for JDBC based authentication. This section provides the corresponding default schemas used with the default queries. You will need to adjust the schema to match any customizations to the queries and the database dialect you are using.
User Schema
JdbcDaoImpl
requires tables to load the password, account status (enabled or disabled) and a list of authorities (roles) for the user.
The default schema required can be found below.
The default schema is also exposed as a classpath resource named |
create table users(
username varchar_ignorecase(50) not null primary key,
password varchar_ignorecase(500) not null,
enabled boolean not null
create table authorities (
username varchar_ignorecase(50) not null,
authority varchar_ignorecase(50) not null,
constraint fk_authorities_users foreign key(username) references users(username)
create unique index ix_auth_username on authorities (username,authority);
Oracle is a popular database choice, but requires a slightly different schema. You can find the default Oracle Schema for users below.
CREATE TABLE USERS (
USERNAME NVARCHAR2(128) PRIMARY KEY,
PASSWORD NVARCHAR2(128) NOT NULL,
ENABLED CHAR(1) CHECK (ENABLED IN ('Y','N') ) NOT NULL
CREATE TABLE AUTHORITIES (
USERNAME NVARCHAR2(128) NOT NULL,
AUTHORITY NVARCHAR2(128) NOT NULL
ALTER TABLE AUTHORITIES ADD CONSTRAINT AUTHORITIES_UNIQUE UNIQUE (USERNAME, AUTHORITY);
ALTER TABLE AUTHORITIES ADD CONSTRAINT AUTHORITIES_FK1 FOREIGN KEY (USERNAME) REFERENCES USERS (USERNAME) ENABLE;
Group Schema
If your application is leveraging groups, you will need to provide the groups schema. The default schema for groups can be found below.
create table groups (
id bigint generated by default as identity(start with 0) primary key,
group_name varchar_ignorecase(50) not null
create table group_authorities (
group_id bigint not null,
authority varchar(50) not null,
constraint fk_group_authorities_group foreign key(group_id) references groups(id)
create table group_members (
username varchar(50) not null,
constraint fk_group_members_group foreign key(group_id) references groups(id)
Setting up a DataSource
Before we configure JdbcUserDetailsManager
, we must create a DataSource
In our example, we will setup an embedded DataSource that is initialized with the default user schema.
Java
XML
Kotlin
DataSource dataSource() {
return new EmbeddedDatabaseBuilder()
.setType(H2)
.addScript(JdbcDaoImpl.DEFAULT_USER_SCHEMA_DDL_LOCATION)
<jdbc:embedded-database>
<jdbc:script location="classpath:org/springframework/security/core/userdetails/jdbc/users.ddl"/>
</jdbc:embedded-database>
fun dataSource(): DataSource {
return EmbeddedDatabaseBuilder()
.setType(H2)
.build()
In a production environment, you will want to ensure you setup a connection to an external database.
JdbcUserDetailsManager Bean
In this sample we use Spring Boot CLI to encode the password of password
and get the encoded password of {bcrypt}$2a$10$GRLdNijSQMUvl/au9ofL.eDwmoohzzS7.rmNSJZ.0FxO/BTk76klW
See the PasswordEncoder section for more details about how to store passwords.
Java
XML
Kotlin
UserDetailsManager users(DataSource dataSource) {
UserDetails user = User.builder()
.username("user")
.password("{bcrypt}$2a$10$GRLdNijSQMUvl/au9ofL.eDwmoohzzS7.rmNSJZ.0FxO/BTk76klW")
.roles("USER")
UserDetails admin = User.builder()
.username("admin")
.roles("USER", "ADMIN")
JdbcUserDetailsManager users = new JdbcUserDetailsManager(dataSource);
users.createUser(user);
users.createUser(admin);
return users;
<jdbc-user-service>
<user name="user"
password="{bcrypt}$2a$10$GRLdNijSQMUvl/au9ofL.eDwmoohzzS7.rmNSJZ.0FxO/BTk76klW"
authorities="ROLE_USER" />
<user name="admin"
authorities="ROLE_USER,ROLE_ADMIN" />
</jdbc-user-service>
fun users(dataSource: DataSource): UserDetailsManager {
val user = User.builder()
.username("user")
.password("{bcrypt}$2a$10\$GRLdNijSQMUvl/au9ofL.eDwmoohzzS7.rmNSJZ.0FxO/BTk76klW")
.roles("USER")
val admin = User.builder()
.username("admin")
val users = JdbcUserDetailsManager(dataSource)
return users
