For the latest stable version, please use Spring Security 6.4.1! |
OAuth 2.0 Resource Server JWT
Minimal Dependencies for JWT
Most Resource Server support is collected into spring-security-oauth2-resource-server
However, the support for decoding and verifying JWTs is in spring-security-oauth2-jose
, meaning that both are necessary in order to have a working resource server that supports JWT-encoded Bearer Tokens.
Minimal Configuration for JWTs
When using Spring Boot, configuring an application as a resource server consists of two basic steps. First, include the needed dependencies and second, indicate the location of the authorization server.
Specifying the Authorization Server
In a Spring Boot application, to specify which authorization server to use, simply do:
spring:
security:
oauth2:
resourceserver:
jwt:
issuer-uri: https://idp.example.com/issuer
Where idp.example.com/issuer
is the value contained in the iss
claim for JWT tokens that the authorization server will issue.
Resource Server will use this property to further self-configure, discover the authorization server’s public keys, and subsequently validate incoming JWTs.
To use the issuer-uri property, it must also be true that one of idp.example.com/issuer/.well-known/openid-configuration , idp.example.com/.well-known/openid-configuration/issuer , or idp.example.com/.well-known/oauth-authorization-server/issuer is a supported endpoint for the authorization server.
This endpoint is referred to as a Provider Configuration endpoint or a Authorization Server Metadata endpoint.
And that’s it!
Startup Expectations
When this property and these dependencies are used, Resource Server will automatically configure itself to validate JWT-encoded Bearer Tokens.
It achieves this through a deterministic startup process:
Hit the Provider Configuration or Authorization Server Metadata endpoint, processing the response for the
jwks_url
property -
Configure the validation strategy to query
jwks_url
for valid public keys -
Configure the validation strategy to validate each JWTs
iss
claim againstidp.example.com
A consequence of this process is that the authorization server must be up and receiving requests in order for Resource Server to successfully start up.
If the authorization server is down when Resource Server queries it (given appropriate timeouts), then startup will fail. |
Runtime Expectations
Once the application is started up, Resource Server will attempt to process any request containing an Authorization: Bearer
header:
GET / HTTP/1.1
Authorization: Bearer some-token-value # Resource Server will process this
So long as this scheme is indicated, Resource Server will attempt to process the request according to the Bearer Token specification.
Given a well-formed JWT, Resource Server will:
Validate its signature against a public key obtained from the
jwks_url
endpoint during startup and matched against the JWTs header -
Validate the JWTs
exp
andnbf
timestamps and the JWTsiss
claim, and -
Map each scope to an authority with the prefix
SCOPE_
As the authorization server makes available new keys, Spring Security will automatically rotate the keys used to validate the JWT tokens. |
The resulting Authentication#getPrincipal
, by default, is a Spring Security Jwt
object, and Authentication#getName
maps to the JWT’s sub
property, if one is present.
From here, consider jumping to:
Specifying the Authorization Server JWK Set Uri Directly
If the authorization server doesn’t support any configuration endpoints, or if Resource Server must be able to start up independently from the authorization server, then the jwk-set-uri
can be supplied as well:
spring:
security:
oauth2:
resourceserver:
jwt:
jwk-set-uri: https://idp.example.com/.well-known/jwks.json
The JWK Set uri is not standardized, but can typically be found in the authorization server’s documentation |
Consequently, Resource Server will not ping the authorization server at startup.
We still specify the issuer-uri
so that Resource Server still validates the iss
claim on incoming JWTs.
This property can also be supplied directly on the DSL. |
Overriding or Replacing Boot Auto Configuration
There are two @Bean
s that Spring Boot generates on Resource Server’s behalf.
The first is a SecurityWebFilterChain
that configures the app as a resource server. When including spring-security-oauth2-jose
, this SecurityWebFilterChain
looks like:
Java
Kotlin
SecurityWebFilterChain springSecurityFilterChain(ServerHttpSecurity http) {
http
.authorizeExchange(exchanges -> exchanges
.oauth2ResourceServer(OAuth2ResourceServerSpec::jwt)
return http.build();
fun springSecurityFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
return http {
authorizeExchange {
oauth2ResourceServer {
jwt { }
If the application doesn’t expose a SecurityWebFilterChain
bean, then Spring Boot will expose the above default one.
Replacing this is as simple as exposing the bean within the application:
Java
Kotlin
http
.pathMatchers("/message/**").hasAuthority("SCOPE_message:read")
.oauth2ResourceServer(oauth2 -> oauth2
.jwt(withDefaults())
return http {
authorizeExchange {
authorize("/message/**", hasAuthority("SCOPE_message:read"))
jwt { }
The above requires the scope of message:read
for any URL that starts with /messages/
Methods on the oauth2ResourceServer
DSL will also override or replace auto configuration.
For example, the second @Bean
Spring Boot creates is a ReactiveJwtDecoder
, which decodes String
tokens into validated instances of Jwt
Java
Kotlin
public ReactiveJwtDecoder jwtDecoder() {
return ReactiveJwtDecoders.fromIssuerLocation(issuerUri);
fun jwtDecoder(): ReactiveJwtDecoder {
Calling ReactiveJwtDecoders#fromIssuerLocation is what invokes the Provider Configuration or Authorization Server Metadata endpoint in order to derive the JWK Set Uri.
If the application doesn’t expose a ReactiveJwtDecoder bean, then Spring Boot will expose the above default one.
And its configuration can be overridden using jwkSetUri()
or replaced using decoder()
Using jwkSetUri()
An authorization server’s JWK Set Uri can be configured as a configuration property or it can be supplied in the DSL:
Java
Kotlin
http
.jwt(jwt -> jwt
.jwkSetUri("https://idp.example.com/.well-known/jwks.json")
return http {
authorizeExchange {
jwt {
jwkSetUri = "https://idp.example.com/.well-known/jwks.json"
Using jwkSetUri()
takes precedence over any configuration property.
Using decoder()
More powerful than jwkSetUri()
is decoder()
, which will completely replace any Boot auto configuration of JwtDecoder
Java
Kotlin
http
.jwt(jwt -> jwt
.decoder(myCustomDecoder())
return http {
authorizeExchange {
jwt {
jwtDecoder = myCustomDecoder()
This is handy when deeper configuration, like validation, is necessary.
Exposing a ReactiveJwtDecoder
Or, exposing a ReactiveJwtDecoder
has the same effect as decoder()
Java
Kotlin
return NimbusReactiveJwtDecoder.withJwkSetUri(jwkSetUri).build();
Configuring Trusted Algorithms
By default, NimbusReactiveJwtDecoder
, and hence Resource Server, will only trust and verify tokens using RS256
You can customize this via Spring Boot or the NimbusJwtDecoder builder.
Via Spring Boot
The simplest way to set the algorithm is as a property:
spring:
security:
oauth2:
resourceserver:
jwt:
jws-algorithms: RS512
jwk-set-uri: https://idp.example.org/.well-known/jwks.json
Using a Builder
For greater power, though, we can use a builder that ships with NimbusReactiveJwtDecoder
Java
Kotlin
return NimbusReactiveJwtDecoder.withJwkSetUri(this.jwkSetUri)
.jwsAlgorithm(RS512).build();
Calling jwsAlgorithm
more than once will configure NimbusReactiveJwtDecoder
to trust more than one algorithm, like so:
Java
Kotlin
.jwsAlgorithm(RS512).jwsAlgorithm(ES512).build();
Or, you can call jwsAlgorithms
Java
Kotlin
.jwsAlgorithms(algorithms -> {
algorithms.add(RS512);
algorithms.add(ES512);
}).build();
.jwsAlgorithms {
it.add(RS512)
it.add(ES512)
.build()
Trusting a Single Asymmetric Key
Simpler than backing a Resource Server with a JWK Set endpoint is to hard-code an RSA public key. The public key can be provided via Spring Boot or by Using a Builder.
Via Spring Boot
Specifying a key via Spring Boot is quite simple. The key’s location can be specified like so:
spring:
security:
oauth2:
resourceserver:
jwt:
public-key-location: classpath:my-key.pub
Or, to allow for a more sophisticated lookup, you can post-process the RsaKeyConversionServicePostProcessor
Java
Kotlin
BeanFactoryPostProcessor conversionServiceCustomizer() {
return beanFactory ->
beanFactory.getBean(RsaKeyConversionServicePostProcessor.class)
.setResourceLoader(new CustomResourceLoader());
fun conversionServiceCustomizer(): BeanFactoryPostProcessor {
return BeanFactoryPostProcessor { beanFactory: ConfigurableListableBeanFactory ->
beanFactory.getBean<RsaKeyConversionServicePostProcessor>()
.setResourceLoader(CustomResourceLoader())
Specify your key’s location:
key.location: hfds://my-key.pub
And then autowire the value:
Java
Kotlin
@Value("${key.location}")
RSAPublicKey key;
@Value("\${key.location}")
val key: RSAPublicKey? = null
Using a Builder
To wire an RSAPublicKey
directly, you can simply use the appropriate NimbusReactiveJwtDecoder
builder, like so:
Java
Kotlin
return NimbusReactiveJwtDecoder.withPublicKey(this.key).build();
return NimbusReactiveJwtDecoder.withPublicKey(key).build()
Trusting a Single Symmetric Key
Using a single symmetric key is also simple.
You can simply load in your SecretKey
and use the appropriate NimbusReactiveJwtDecoder
builder, like so:
Java
Kotlin
return NimbusReactiveJwtDecoder.withSecretKey(this.key).build();
Configuring Authorization
A JWT that is issued from an OAuth 2.0 Authorization Server will typically either have a scope
or scp
attribute, indicating the scopes (or authorities) it’s been granted, for example:
{ …, "scope" : "messages contacts"}
When this is the case, Resource Server will attempt to coerce these scopes into a list of granted authorities, prefixing each scope with the string "SCOPE_".
This means that to protect an endpoint or method with a scope derived from a JWT, the corresponding expressions should include this prefix:
Java
Kotlin
http
.mvcMatchers("/contacts/**").hasAuthority("SCOPE_contacts")
.mvcMatchers("/messages/**").hasAuthority("SCOPE_messages")
.oauth2ResourceServer(OAuth2ResourceServerSpec::jwt);
return http {
authorizeExchange {
authorize("/contacts/**", hasAuthority("SCOPE_contacts"))
authorize("/messages/**", hasAuthority("SCOPE_messages"))
jwt { }
Or similarly with method security:
Java
Kotlin
@PreAuthorize("hasAuthority('SCOPE_messages')")
public Flux<Message> getMessages(...) {}
fun getMessages(): Flux<Message> { }
Extracting Authorities Manually
However, there are a number of circumstances where this default is insufficient.
For example, some authorization servers don’t use the scope
attribute, but instead have their own custom attribute.
Or, at other times, the resource server may need to adapt the attribute or a composition of attributes into internalized authorities.
To this end, the DSL exposes jwtAuthenticationConverter()
Java
Kotlin
http
.jwt(jwt -> jwt
.jwtAuthenticationConverter(grantedAuthoritiesExtractor())
Converter<Jwt, Mono<AbstractAuthenticationToken>> grantedAuthoritiesExtractor() {
JwtAuthenticationConverter jwtAuthenticationConverter =
new JwtAuthenticationConverter();
jwtAuthenticationConverter.setJwtGrantedAuthoritiesConverter
(new GrantedAuthoritiesExtractor());
return new ReactiveJwtAuthenticationConverterAdapter(jwtAuthenticationConverter);
return http {
authorizeExchange {
jwt {
jwtAuthenticationConverter = grantedAuthoritiesExtractor()
fun grantedAuthoritiesExtractor(): Converter<Jwt, Mono<AbstractAuthenticationToken>> {
val jwtAuthenticationConverter = JwtAuthenticationConverter()
jwtAuthenticationConverter.setJwtGrantedAuthoritiesConverter(GrantedAuthoritiesExtractor())
return ReactiveJwtAuthenticationConverterAdapter(jwtAuthenticationConverter)
which is responsible for converting a Jwt
into an Authentication
As part of its configuration, we can supply a subsidiary converter to go from Jwt
to a Collection
of granted authorities.
That final converter might be something like GrantedAuthoritiesExtractor
below:
Java
Kotlin
static class GrantedAuthoritiesExtractor
implements Converter<Jwt, Collection<GrantedAuthority>> {
public Collection<GrantedAuthority> convert(Jwt jwt) {
Collection<?> authorities = (Collection<?>)
jwt.getClaims().getOrDefault("mycustomclaim", Collections.emptyList());
return authorities.stream()
.map(Object::toString)
.map(SimpleGrantedAuthority::new)
.collect(Collectors.toList());
internal class GrantedAuthoritiesExtractor : Converter<Jwt, Collection<GrantedAuthority>> {
override fun convert(jwt: Jwt): Collection<GrantedAuthority> {
val authorities: List<Any> = jwt.claims
.getOrDefault("mycustomclaim", emptyList<Any>()) as List<Any>
return authorities
.map { it.toString() }
.map { SimpleGrantedAuthority(it) }
For more flexibility, the DSL supports entirely replacing the converter with any class that implements Converter<Jwt, Mono<AbstractAuthenticationToken>>
Java
Kotlin
static class CustomAuthenticationConverter implements Converter<Jwt, Mono<AbstractAuthenticationToken>> {
public AbstractAuthenticationToken convert(Jwt jwt) {
return Mono.just(jwt).map(this::doConversion);
internal class CustomAuthenticationConverter : Converter<Jwt, Mono<AbstractAuthenticationToken>> {
override fun convert(jwt: Jwt): Mono<AbstractAuthenticationToken> {
Configuring Validation
Using minimal Spring Boot configuration, indicating the authorization server’s issuer uri, Resource Server will default to verifying the iss
claim as well as the exp
and nbf
timestamp claims.
In circumstances where validation needs to be customized, Resource Server ships with two standard validators and also accepts custom OAuth2TokenValidator
instances.
Customizing Timestamp Validation
JWT’s typically have a window of validity, with the start of the window indicated in the nbf
claim and the end indicated in the exp
claim.
However, every server can experience clock drift, which can cause tokens to appear expired to one server, but not to another. This can cause some implementation heartburn as the number of collaborating servers increases in a distributed system.
Resource Server uses JwtTimestampValidator
to verify a token’s validity window, and it can be configured with a clockSkew
to alleviate the above problem:
Java
Kotlin
NimbusReactiveJwtDecoder jwtDecoder = (NimbusReactiveJwtDecoder)
OAuth2TokenValidator<Jwt> withClockSkew = new DelegatingOAuth2TokenValidator<>(
new JwtTimestampValidator(Duration.ofSeconds(60)),
new IssuerValidator(issuerUri));
jwtDecoder.setJwtValidator(withClockSkew);
return jwtDecoder;
val jwtDecoder = ReactiveJwtDecoders.fromIssuerLocation(issuerUri) as NimbusReactiveJwtDecoder
val withClockSkew: OAuth2TokenValidator<Jwt> = DelegatingOAuth2TokenValidator(
JwtIssuerValidator(issuerUri))
return jwtDecoder
By default, Resource Server configures a clock skew of 60 seconds. |
Configuring a Custom Validator
Adding a check for the aud
claim is simple with the OAuth2TokenValidator
API:
Java
Kotlin
public class AudienceValidator implements OAuth2TokenValidator<Jwt> {
OAuth2Error error = new OAuth2Error("invalid_token", "The required audience is missing", null);
public OAuth2TokenValidatorResult validate(Jwt jwt) {
if (jwt.getAudience().contains("messaging")) {
return OAuth2TokenValidatorResult.success();
} else {
return OAuth2TokenValidatorResult.failure(error);
class AudienceValidator : OAuth2TokenValidator<Jwt> {
var error: OAuth2Error = OAuth2Error("invalid_token", "The required audience is missing", null)
override fun validate(jwt: Jwt): OAuth2TokenValidatorResult {
return if (jwt.audience.contains("messaging")) {
} else {
Then, to add into a resource server, it’s a matter of specifying the ReactiveJwtDecoder
instance:
Java
Kotlin
OAuth2TokenValidator<Jwt> audienceValidator = new AudienceValidator();
OAuth2TokenValidator<Jwt> withIssuer = JwtValidators.createDefaultWithIssuer(issuerUri);
OAuth2TokenValidator<Jwt> withAudience = new DelegatingOAuth2TokenValidator<>(withIssuer, audienceValidator);
jwtDecoder.setJwtValidator(withAudience);
return jwtDecoder;
val audienceValidator: OAuth2TokenValidator<Jwt> = AudienceValidator()
val withIssuer: OAuth2TokenValidator<Jwt> = JwtValidators.createDefaultWithIssuer(issuerUri)
val withAudience: OAuth2TokenValidator<Jwt> = DelegatingOAuth2TokenValidator(withIssuer, audienceValidator)
return jwtDecoder
