For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
CORS
Spring Framework provides first class support for CORS. CORS must be processed before Spring Security because the pre-flight request will not contain any cookies (i.e. the JSESSIONID). If the request does not contain any cookies and Spring Security is first, the request will determine the user is not authenticated (since there are no cookies in the request) and reject it.spring-doc.cn
The easiest way to ensure that CORS is handled first is to use the CorsFilter. Users can integrate the CorsFilter with Spring Security by providing a CorsConfigurationSource using the following:spring-doc.cn
@EnableWebSecurity
public class WebSecurityConfig {
		http
			// by default uses a Bean by the name of corsConfigurationSource
			.cors(withDefaults())
		return http.build();
	CorsConfigurationSource corsConfigurationSource() {
		CorsConfiguration configuration = new CorsConfiguration();
		configuration.setAllowedOrigins(Arrays.asList("https://example.com"));
		configuration.setAllowedMethods(Arrays.asList("GET","POST"));
		UrlBasedCorsConfigurationSource source = new UrlBasedCorsConfigurationSource();
		source.registerCorsConfiguration("/**", configuration);
		return source;
@EnableWebSecurity
open class WebSecurityConfig {
        http {
            cors { }
        return http.build()
    open fun corsConfigurationSource(): CorsConfigurationSource {
        val configuration = CorsConfiguration()
        configuration.allowedOrigins = listOf("https://example.com")
        configuration.allowedMethods = listOf("GET", "POST")
        val source = UrlBasedCorsConfigurationSource()
        return source
or in XMLspring-doc.cn
<http>
	<cors configuration-source-ref="corsSource"/>
</http>
<b:bean id="corsSource" class="org.springframework.web.cors.UrlBasedCorsConfigurationSource">
</b:bean>
If you are using Spring MVC’s CORS support, you can omit specifying the CorsConfigurationSource and Spring Security will leverage the CORS configuration provided to Spring MVC.spring-doc.cn
@EnableWebSecurity
		http
			// if Spring MVC is on classpath and no CorsConfigurationSource is provided,
			// Spring Security will use CORS configuration provided to Spring MVC
@EnableWebSecurity
        http {
            cors { }
        return http.build()
<http>
	<!-- Default to Spring MVC's CORS configuration -->
	<cors />
</http>
