For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
Security HTTP Response Headers
Security HTTP Response Headers can be used to increase the security of web applications. This section is dedicated to servlet based support for Security HTTP Response Headers.spring-doc.cn
Default Security Headers
Spring Security provides a default set of Security HTTP Response Headers to provide secure defaults. While each of these headers are considered best practice, it should be noted that not all clients utilize the headers, so additional testing is encouraged.spring-doc.cn
You can customize specific headers. For example, assume that you want the defaults except you wish to specify SAMEORIGIN for X-Frame-Options.spring-doc.cn
You can easily do this with the following Configuration:spring-doc.cn
Customize Default Security Headers
@EnableWebSecurity
public class WebSecurityConfig {
		http
			.headers(headers -> headers
				.frameOptions(frameOptions -> frameOptions
					.sameOrigin()
		return http.build();
<http>
	<headers>
		<frame-options policy="SAMEORIGIN" />
	</headers>
</http>
@EnableWebSecurity
class SecurityConfig {
        http {
            headers {
                frameOptions {
                    sameOrigin = true
        return http.build()
If you do not want the defaults to be added and want explicit control over what should be used, you can disable the defaults. An example is provided below:spring-doc.cn
If you are using Spring Security’s Configuration the following will only add Cache Control.spring-doc.cn
Customize Cache Control Headers
@EnableWebSecurity
		http
				// do not use any default headers unless explicitly listed
				.defaultsDisabled()
				.cacheControl(withDefaults())
<http>
	<headers defaults-disabled="true">
		<cache-control/>
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                defaultsDisabled = true
                cacheControl {
        return http.build()
If necessary, you can disable all of the HTTP Security response headers with the following Configuration:spring-doc.cn
Disable All HTTP Security Headers
@EnableWebSecurity
		http
			.headers(headers -> headers.disable());
<http>
	<headers disabled="true" />
</http>
@EnableWebSecurity
        http {
            headers {
                disable()
        return http.build()
Cache Control
Spring Security includes Cache Control headers by default.spring-doc.cn
However, if you actually want to cache specific responses, your application can selectively invoke HttpServletResponse.setHeader(String,String) to override the header set by Spring Security. This is useful to ensure things like CSS, JavaScript, and images are properly cached.spring-doc.cn
When using Spring Web MVC, this is typically done within your configuration. Details on how to do this can be found in the Static Resources portion of the Spring Reference documentationspring-doc.cn
If necessary, you can also disable Spring Security’s cache control HTTP response headers.spring-doc.cn
Cache Control Disabled
@EnableWebSecurity
		http
				.cacheControl(cache -> cache.disable())
<http>
	<headers>
		<cache-control disabled="true"/>
	</headers>
</http>
@EnableWebSecurity
       http {
            headers {
                cacheControl {
                    disable()
        return http.build()
Content Type Options
Spring Security includes Content-Type headers by default. However, you can disable it with:spring-doc.cn
Content Type Options Disabled
@EnableWebSecurity
		http
				.contentTypeOptions(contentTypeOptions -> contentTypeOptions.disable())
<http>
	<headers>
		<content-type-options disabled="true"/>
	</headers>
</http>
@EnableWebSecurity
       http {
            headers {
                contentTypeOptions {
                    disable()
        return http.build()
HTTP Strict Transport Security (HSTS)
Spring Security provides the Strict Transport Security header by default. However, you can customize the results explicitly. For example, the following is an example of explicitly providing HSTS:spring-doc.cn
@EnableWebSecurity
		http
				.httpStrictTransportSecurity(hsts -> hsts
					.includeSubDomains(true)
					.preload(true)
					.maxAgeInSeconds(31536000)
<http>
	<headers>
		<hsts
			include-subdomains="true"
			max-age-seconds="31536000"
			preload="true" />
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                httpStrictTransportSecurity {
                    includeSubDomains = true
                    preload = true
                    maxAgeInSeconds = 31536000
        return http.build()
HTTP Public Key Pinning (HPKP)
For passivity reasons, Spring Security provides servlet support for HTTP Public Key Pinning but it is no longer recommended.spring-doc.cn
You can enable HPKP headers with the following Configuration:spring-doc.cn
@EnableWebSecurity
		http
				.httpPublicKeyPinning(hpkp -> hpkp
					.reportUri("https://example.net/pkp-report")
					.addSha256Pins("d6qzRu9zOECb90Uez27xWltNsj0e1Md7GkYYkVoZWmM=", "E9CZ9INDbd+2eRQozYqqbQ2yXLVKB9+xcprMF+44U1g=")
<http>
	<headers>
		<hpkp
			report-uri="https://example.net/pkp-report">
			<pins>
				<pin algorithm="sha256">d6qzRu9zOECb90Uez27xWltNsj0e1Md7GkYYkVoZWmM=</pin>
				<pin algorithm="sha256">E9CZ9INDbd+2eRQozYqqbQ2yXLVKB9+xcprMF+44U1g=</pin>
			</pins>
		</hpkp>
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                httpPublicKeyPinning {
                    reportUri = "https://example.net/pkp-report"
                    pins = mapOf("d6qzRu9zOECb90Uez27xWltNsj0e1Md7GkYYkVoZWmM=" to "sha256",
                            "E9CZ9INDbd+2eRQozYqqbQ2yXLVKB9+xcprMF+44U1g=" to "sha256")
        return http.build()
X-Frame-Options
By default, Spring Security disables rendering within an iframe using X-Frame-Options.spring-doc.cn
You can customize frame options to use the same origin within a Configuration using the following:spring-doc.cn
X-Frame-Options: SAMEORIGIN
@EnableWebSecurity
		http
					.sameOrigin()
<http>
	<headers>
		<frame-options
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                frameOptions {
                    sameOrigin = true
        return http.build()
X-XSS-Protection
By default, Spring Security instructs browsers to block reflected XSS attacks using the <<headers-xss-protection,X-XSS-Protection header>. However, you can change this default. For example, the following Configuration specifies that Spring Security should no longer instruct browsers to block the content:spring-doc.cn
X-XSS-Protection Customization
@EnableWebSecurity
		http
				.xssProtection(xss -> xss
					.block(false)
<http>
	<headers>
		<xss-protection block="false"/>
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                xssProtection {
                    block = false
        return http.build()
Content Security Policy (CSP)
Spring Security does not add Content Security Policy by default, because a reasonable default is impossible to know without context of the application. The web application author must declare the security policy(s) to enforce and/or monitor for the protected resources.spring-doc.cn
For example, given the following security policy:spring-doc.cn
Content Security Policy Example
Content-Security-Policy: script-src 'self' https://trustedscripts.example.com; object-src https://trustedplugins.example.com; report-uri /csp-report-endpoint/
You can enable the CSP header as shown below:spring-doc.cn
@EnableWebSecurity
		http
				.contentSecurityPolicy(csp -> csp
					.policyDirectives("script-src 'self' https://trustedscripts.example.com; object-src https://trustedplugins.example.com; report-uri /csp-report-endpoint/")
<http>
	<headers>
		<content-security-policy
			policy-directives="script-src 'self' https://trustedscripts.example.com; object-src https://trustedplugins.example.com; report-uri /csp-report-endpoint/" />
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                contentSecurityPolicy {
                    policyDirectives = "script-src 'self' https://trustedscripts.example.com; object-src https://trustedplugins.example.com; report-uri /csp-report-endpoint/"
        return http.build()
To enable the CSP report-only header, provide the following configuration:spring-doc.cn
Content Security Policy Report Only
@EnableWebSecurity
		http
					.reportOnly()
<http>
	<headers>
			report-only="true" />
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                    reportOnly = true
        return http.build()
Referrer Policy
Spring Security does not add Referrer Policy headers by default. You can enable the Referrer Policy header using the configuration as shown below:spring-doc.cn
Referrer Policy
@EnableWebSecurity
		http
				.referrerPolicy(referrer -> referrer
					.policy(ReferrerPolicy.SAME_ORIGIN)
<http>
	<headers>
		<referrer-policy policy="same-origin" />
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                referrerPolicy {
                    policy = ReferrerPolicy.SAME_ORIGIN
        return http.build()
Feature Policy
Spring Security does not add Feature Policy headers by default. The following Feature-Policy header:spring-doc.cn
Feature-Policy Example
Feature-Policy: geolocation 'self'
can enable the Feature Policy header using the configuration shown below:spring-doc.cn
Feature-Policy
@EnableWebSecurity
		http
				.featurePolicy("geolocation 'self'")
<http>
	<headers>
		<feature-policy policy-directives="geolocation 'self'" />
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
        return http.build()
Permissions Policy
Spring Security does not add Permissions Policy headers by default. The following Permissions-Policy header:spring-doc.cn
Permissions-Policy Example
Permissions-Policy: geolocation=(self)
can enable the Permissions Policy header using the configuration shown below:spring-doc.cn
Permissions-Policy
@EnableWebSecurity
		http
				.permissionsPolicy(permissions -> permissions
					.policy("geolocation=(self)")
<http>
	<headers>
		<permissions-policy policy="geolocation=(self)" />
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                permissionPolicy {
                    policy = "geolocation=(self)"
        return http.build()
Clear Site Data
Spring Security does not add Clear-Site-Data headers by default. The following Clear-Site-Data header:spring-doc.cn
Clear-Site-Data Example
Clear-Site-Data: "cache", "cookies"
can be sent on log out with the following configuration:spring-doc.cn
Clear-Site-Data
@EnableWebSecurity
		http
			.logout((logout) -> logout
                .addLogoutHandler(new HeaderWriterLogoutHandler(new ClearSiteDataHeaderWriter(CACHE, COOKIES)))
@EnableWebSecurity
        http {
            logout {
                addLogoutHandler(HeaderWriterLogoutHandler(ClearSiteDataHeaderWriter(CACHE, COOKIES)))
        return http.build()
Cross-Origin Policies
Spring Security provides built-in support for adding some Cross-Origin policies headers, those headers are:spring-doc.cn
Cross-Origin-Opener-Policy
Cross-Origin-Embedder-Policy
Cross-Origin-Resource-Policy
Spring Security does not add Cross-Origin Policies headers by default. The headers can be added with the following configuration:spring-doc.cn
@EnableWebSecurity
    SecurityFilterChain securityFilterChain(HttpSecurity http) {
        http.headers((headers) -> headers
                .crossOriginOpenerPolicy(CrossOriginOpenerPolicy.SAME_ORIGIN)
                .crossOriginEmbedderPolicy(CrossOriginEmbedderPolicy.REQUIRE_CORP)
                .crossOriginResourcePolicy(CrossOriginResourcePolicy.SAME_ORIGIN)));
@EnableWebSecurity
open class CrossOriginPoliciesConfig {
    open fun securityFilterChain(http: HttpSecurity): SecurityFilterChain {
        http {
            headers {
        return http.build()
This configuration will write the headers with the values provided:spring-doc.cn
Cross-Origin-Opener-Policy: same-origin
Cross-Origin-Embedder-Policy: require-corp
Cross-Origin-Resource-Policy: same-origin
Custom Headers
Spring Security has mechanisms to make it convenient to add the more common security headers to your application. However, it also provides hooks to enable adding custom headers.spring-doc.cn
Static Headers
There may be times you wish to inject custom security headers into your application that are not supported out of the box. For example, given the following custom security header:spring-doc.cn
X-Custom-Security-Header: header-value
The headers could be added to the response using the following Configuration:spring-doc.cn
StaticHeadersWriter
@EnableWebSecurity
		http
				.addHeaderWriter(new StaticHeadersWriter("X-Custom-Security-Header","header-value"))
<http>
	<headers>
		<header name="X-Custom-Security-Header" value="header-value"/>
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                addHeaderWriter(StaticHeadersWriter("X-Custom-Security-Header","header-value"))
        return http.build()
Headers Writer
When the namespace or Java configuration does not support the headers you want, you can create a custom HeadersWriter instance or even provide a custom implementation of the HeadersWriter.spring-doc.cn
Let’s take a look at an example of using an custom instance of XFrameOptionsHeaderWriter. If you wanted to explicitly configure X-Frame-Options it could be done with the following Configuration:spring-doc.cn
Headers Writer
@EnableWebSecurity
		http
				.addHeaderWriter(new XFrameOptionsHeaderWriter(XFrameOptionsMode.SAMEORIGIN))
<http>
	<headers>
		<header ref="frameOptionsWriter"/>
	</headers>
</http>
<!-- Requires the c-namespace.
See https://docs.spring.io/spring/docs/current/spring-framework-reference/htmlsingle/#beans-c-namespace
<beans:bean id="frameOptionsWriter"
	class="org.springframework.security.web.header.writers.frameoptions.XFrameOptionsHeaderWriter"
	c:frameOptionsMode="SAMEORIGIN"/>
@EnableWebSecurity
        http {
            headers {
                addHeaderWriter(XFrameOptionsHeaderWriter(XFrameOptionsMode.SAMEORIGIN))
        return http.build()
DelegatingRequestMatcherHeaderWriter
At times you may want to only write a header for certain requests. For example, perhaps you want to only protect your log in page from being framed. You could use the DelegatingRequestMatcherHeaderWriter to do so.spring-doc.cn
An example of using DelegatingRequestMatcherHeaderWriter in Java Configuration can be seen below:spring-doc.cn
DelegatingRequestMatcherHeaderWriter Java Configuration
@EnableWebSecurity
		RequestMatcher matcher = new AntPathRequestMatcher("/login");
		DelegatingRequestMatcherHeaderWriter headerWriter =
			new DelegatingRequestMatcherHeaderWriter(matcher,new XFrameOptionsHeaderWriter());
		http
				.frameOptions(frameOptions -> frameOptions.disable())
				.addHeaderWriter(headerWriter)
<http>
	<headers>
		<frame-options disabled="true"/>
		<header ref="headerWriter"/>
	</headers>
</http>
<beans:bean id="headerWriter"
	class="org.springframework.security.web.header.writers.DelegatingRequestMatcherHeaderWriter">
	<beans:constructor-arg>
		<bean class="org.springframework.security.web.util.matcher.AntPathRequestMatcher"
			c:pattern="/login"/>
	</beans:constructor-arg>
		<beans:bean
			class="org.springframework.security.web.header.writers.frameoptions.XFrameOptionsHeaderWriter"/>
</beans:bean>
@EnableWebSecurity
        val matcher: RequestMatcher = AntPathRequestMatcher("/login")
        val headerWriter = DelegatingRequestMatcherHeaderWriter(matcher, XFrameOptionsHeaderWriter())
       http {
            headers {
                frameOptions {
                    disable()
        return http.build()
