This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.0! |
Method Arguments
The next table describes the supported controller method arguments. Reactive types are not supported for any arguments.
JDK 8’s java.util.Optional
is supported as a method argument in combination with
annotations that have a required
attribute (for example, @RequestParam
, @RequestHeader
and others) and is equivalent to required=false
Controller method argument | Description |
Generic access to request parameters and request and session attributes, without direct use of the Servlet API. |
Choose any specific request or response type — for example, |
Enforces the presence of a session. As a consequence, such an argument is never |
Servlet 4.0 push builder API for programmatic HTTP/2 resource pushes. Note that this API has been deprecated as of Servlet 6.1. |
Currently authenticated user — possibly a specific Note that this argument is not resolved eagerly, if it is annotated in order to allow a custom resolver to resolve it
before falling back on default resolution via |
The HTTP method of the request. |
The current request locale, determined by the most specific |
The time zone associated with the current request, as determined by a |
For access to the raw request body as exposed by the Servlet API. |
For access to the raw response body as exposed by the Servlet API. |
For access to URI template variables. See URI patterns. |
For access to name-value pairs in URI path segments. See Matrix Variables. |
For access to the Servlet request parameters, including multipart files. Parameter values
are converted to the declared method argument type. See Note that use of |
For access to request headers. Header values are converted to the declared method argument
type. See |
For access to cookies. Cookies values are converted to the declared method argument
type. See |
For access to the HTTP request body. Body content is converted to the declared method
argument type by using |
For access to request headers and body. The body is converted with an |
For access to a part in a |
For access to the model that is used in HTML controllers and exposed to templates as part of view rendering. |
Specify attributes to use in case of a redirect (that is, to be appended to the query string) and flash attributes to be stored temporarily until the request after redirect. See Redirect Attributes and Flash Attributes. |
For access to an existing attribute in the model (instantiated if not present) with
data binding and validation applied. See Note that use of |
For access to errors from validation and data binding for a command object
(that is, a |
For marking form processing complete, which triggers cleanup of session attributes
declared through a class-level |
For preparing a URL relative to the current request’s host, port, scheme, context path, and the literal part of the servlet mapping. See URI Links. |
For access to any session attribute, in contrast to model attributes stored in the session
as a result of a class-level |
For access to request attributes. See |
Any other argument |
If a method argument is not matched to any of the earlier values in this table and it is
a simple type (as determined by
BeanUtils#isSimpleProperty),
it is resolved as a |
