This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.0! |
Validation
Spring MVC has built-in validation for
@RequestMapping
methods, including Java Bean Validation.
Validation may be applied at one of two levels:
@ModelAttribute, @RequestBody, and @RequestPart argument resolvers validate a method argument individually if the method parameter is annotated with Jakarta
@Valid
or Spring’s@Validated
, AND there is noErrors
orBindingResult
parameter immediately after, AND method validation is not needed (to be discussed next). The exception raised in this case isMethodArgumentNotValidException
When
@Constraint
annotations such as@Min
,@NotBlank
and others are declared directly on method parameters, or on the method (for the return value), then method validation must be applied, and that supersedes validation at the method argument level because method validation covers both method parameter constraints and nested constraints via@Valid
. The exception raised in this case isHandlerMethodValidationException
Applications must handle both MethodArgumentNotValidException
and
as either may be raised depending on the controller
method signature. The two exceptions, however are designed to be very similar, and can be
handled with almost identical code. The main difference is that the former is for a single
object while the latter is for a list of method parameters.
@Valid is not a constraint annotation, but rather for nested constraints within
an Object. Therefore, by itself @Valid does not lead to method validation. @NotNull
on the other hand is a constraint, and adding it to an @Valid parameter leads to method
validation. For nullability specifically, you may also use the required flag of
@RequestBody or @ModelAttribute .
Method validation may be used in combination with Errors
or BindingResult
method
parameters. However, the controller method is called only if all validation errors are on
method parameters with an Errors
immediately after. If there are validation errors on
any other method parameter then HandlerMethodValidationException
is raised.
You can configure a Validator
globally through the
WebMvc config, or locally through an
@InitBinder method in an
@Controller
or @ControllerAdvice
. You can also use multiple validators.
If a controller has a class level @Validated , then
method validation is applied
through an AOP proxy. In order to take advantage of the Spring MVC built-in support for
method validation added in Spring Framework 6.1, you need to remove the class level
@Validated annotation from the controller.
The Error Responses section provides further
details on how MethodArgumentNotValidException
and HandlerMethodValidationException
are handled, and also how their rendering can be customized through a MessageSource
and
locale and language specific resource bundles.
For further custom handling of method validation errors, you can extend
ResponseEntityExceptionHandler
or use an @ExceptionHandler
method in a controller
or in a @ControllerAdvice
, and handle HandlerMethodValidationException
directly.
The exception contains a list ofParameterValidationResult
s that group validation errors
by method parameter. You can either iterate over those, or provide a visitor with callback
methods by controller method parameter type:
Java
Kotlin
HandlerMethodValidationException ex = ... ;
ex.visitResults(new HandlerMethodValidationException.Visitor() {
public void requestHeader(RequestHeader requestHeader, ParameterValidationResult result) {
public void requestParam(@Nullable RequestParam requestParam, ParameterValidationResult result) {
public void modelAttribute(@Nullable ModelAttribute modelAttribute, ParameterErrors errors) {
public void other(ParameterValidationResult result) {
// HandlerMethodValidationException
val ex
ex.visitResults(object : HandlerMethodValidationException.Visitor {
override fun requestHeader(requestHeader: RequestHeader, result: ParameterValidationResult) {
override fun requestParam(requestParam: RequestParam?, result: ParameterValidationResult) {
override fun modelAttribute(modelAttribute: ModelAttribute?, errors: ParameterErrors) {
override fun other(result: ParameterValidationResult) {
