Methods
You can invoke methods by using the typical Java programming syntax. You can also invoke methods directly on literals such as strings or numbers. Varargs are supported as well.spring-doc.cn
The following examples show how to invoke methods.spring-doc.cn
// string literal, evaluates to "bc"
String bc = parser.parseExpression("'abc'.substring(1, 3)").getValue(String.class);
// evaluates to true
boolean isMember = parser.parseExpression("isMember('Mihajlo Pupin')").getValue(
		societyContext, Boolean.class);
val bc = parser.parseExpression("'abc'.substring(1, 3)").getValue(String::class.java)
val isMember = parser.parseExpression("isMember('Mihajlo Pupin')").getValue(
		societyContext, Boolean::class.java)
