This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.6!spring-doc.cn
Processing
The DispatcherServlet processes requests as follows:spring-doc.cn
  • The WebApplicationContext is searched for and bound in the request as an attribute that the controller and other elements in the process can use. It is bound by default under the DispatcherServlet.WEB_APPLICATION_CONTEXT_ATTRIBUTE key.spring-doc.cn
  • The locale resolver is bound to the request to let elements in the process resolve the locale to use when processing the request (rendering the view, preparing data, and so on). If you do not need locale resolving, you do not need the locale resolver.spring-doc.cn
  • If you specify a multipart file resolver, the request is inspected for multiparts. If multiparts are found, the request is wrapped in a MultipartHttpServletRequest for further processing by other elements in the process. See Multipart Resolver for further information about multipart handling.spring-doc.cn
  • An appropriate handler is searched for. If a handler is found, the execution chain associated with the handler (preprocessors, postprocessors, and controllers) is run to prepare a model for rendering. Alternatively, for annotated controllers, the response can be rendered (within the HandlerAdapter) instead of returning a view.spring-doc.cn
  • If a model is returned, the view is rendered. If no model is returned (maybe due to a preprocessor or postprocessor intercepting the request, perhaps for security reasons), no view is rendered, because the request could already have been fulfilled.spring-doc.cn
The HandlerExceptionResolver beans declared in the WebApplicationContext are used to resolve exceptions thrown during request processing. Those exception resolvers allow customizing the logic to address exceptions. See Exceptions for more details.spring-doc.cn
For HTTP caching support, handlers can use the checkNotModified methods of WebRequest, along with further options for annotated controllers as described in HTTP Caching for Controllers.spring-doc.cn
You can customize individual DispatcherServlet instances by adding Servlet initialization parameters (init-param elements) to the Servlet declaration in the web.xml file. The following table lists the supported parameters:spring-doc.cn
Table 1. DispatcherServlet initialization parameters
Parameter Explanation
contextClassspring-doc.cn
Class that implements ConfigurableWebApplicationContext, to be instantiated and locally configured by this Servlet. By default, XmlWebApplicationContext is used.spring-doc.cn
contextConfigLocationspring-doc.cn
String that is passed to the context instance (specified by contextClass) to indicate where contexts can be found. The string consists potentially of multiple strings (using a comma as a delimiter) to support multiple contexts. In the case of multiple context locations with beans that are defined twice, the latest location takes precedence.spring-doc.cn
namespacespring-doc.cn
Namespace of the WebApplicationContext. Defaults to [servlet-name]-servlet.spring-doc.cn
throwExceptionIfNoHandlerFoundspring-doc.cn
Whether to throw a NoHandlerFoundException when no handler was found for a request. The exception can then be caught with a HandlerExceptionResolver (for example, by using an @ExceptionHandler controller method) and handled as any others.spring-doc.cn
As of 6.1, this property is set to true and deprecated.spring-doc.cn
Note that, if default servlet handling is also configured, unresolved requests are always forwarded to the default servlet and a 404 is never raised.spring-doc.cn
