Type Conversion
By default, formatters for various number and date types are installed, along with support for customization via @NumberFormat, @DurationFormat, and @DateTimeFormat on fields and parameters.spring-doc.cn
To register custom formatters and converters, use the following:spring-doc.cn
public class WebConfiguration implements WebMvcConfigurer {
	public void addFormatters(FormatterRegistry registry) {
class WebConfiguration : WebMvcConfigurer {
	override fun addFormatters(registry: FormatterRegistry) {
<mvc:annotation-driven conversion-service="conversionService"/>
<bean id="conversionService"
	  class="org.springframework.format.support.FormattingConversionServiceFactoryBean">
	<property name="converters">
		<set>
			<bean class="org.example.MyConverter"/>
		</set>
	</property>
	<property name="formatters">
		<set>
			<bean class="org.example.MyFormatter"/>
			<bean class="org.example.MyAnnotationFormatterFactory"/>
		</set>
	</property>
	<property name="formatterRegistrars">
		<set>
			<bean class="org.example.MyFormatterRegistrar"/>
		</set>
	</property>
</bean>
By default Spring MVC considers the request Locale when parsing and formatting date values. This works for forms where dates are represented as Strings with "input" form fields. For "date" and "time" form fields, however, browsers use a fixed format defined in the HTML spec. For such cases date and time formatting can be customized as follows:spring-doc.cn
public class DateTimeWebConfiguration implements WebMvcConfigurer {
		DateTimeFormatterRegistrar registrar = new DateTimeFormatterRegistrar();
		registrar.setUseIsoFormat(true);
		registrar.registerFormatters(registry);
class DateTimeWebConfiguration : WebMvcConfigurer {
		DateTimeFormatterRegistrar().apply {
See the FormatterRegistrar SPI and the FormattingConversionServiceFactoryBean for more information on when to use FormatterRegistrar implementations.
