This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.0! |
MockMvc integration
If you want to use the AssertJ support but have invested in the original MockMvc
API, MockMvcTester
offers several ways to integrate with it.
If you have your own RequestBuilder
implementation, you can trigger the processing
of the request using perform
. The example below showcases how the query can be
crafted with the original API:
// Static import on MockMvcRequestBuilders.get
assertThat(mockMvc.perform(get("/hotels/{id}", 42)))
.hasStatusOk();
Similarly, if you have crafted custom matchers that you use with the .andExpect
feature
of MockMvc
you can use them via .matches
. In the example below, we rewrite the
preceding example to assert the status with the ResultMatcher
implementation that
MockMvc
provides:
// Static import on MockMvcResultMatchers.status
assertThat(mockMvc.get().uri("/hotels/{id}", 42))
.matches(status().isOk());
MockMvc
also defines a ResultHandler
contract that lets you execute arbitrary actions
on MvcResult
. If you have implemented this contract you can invoke it using .apply
