Configuring MockMvcTester
MockMvcTester can be setup in one of two ways. One is to point directly to the controllers you want to test and programmatically configure Spring MVC infrastructure. The second is to point to Spring configuration with Spring MVC and controller infrastructure in it.spring-doc.cn
For a comparison of those two modes, check Setup Options.
To set up MockMvcTester for testing a specific controller, use the following:spring-doc.cn
public class AccountControllerStandaloneTests {
	private final MockMvcTester mockMvc = MockMvcTester.of(new AccountController());
	val mockMvc = MockMvcTester.of(AccountController())
To set up MockMvcTester through Spring configuration, use the following:spring-doc.cn
@SpringJUnitWebConfig(ApplicationWebConfiguration.class)
class AccountControllerIntegrationTests {
	private final MockMvcTester mockMvc;
	AccountControllerIntegrationTests(@Autowired WebApplicationContext wac) {
		this.mockMvc = MockMvcTester.from(wac);
@SpringJUnitWebConfig(ApplicationWebConfiguration::class)
class AccountControllerIntegrationTests(@Autowired wac: WebApplicationContext) {
	private val mockMvc = MockMvcTester.from(wac)
MockMvcTester can convert the JSON response body, or the result of a JSONPath expression, to one of your domain object as long as the relevant HttpMessageConverter is registered.spring-doc.cn
If you use Jackson to serialize content to JSON, the following example registers the converter:spring-doc.cn
		this.mockMvc = MockMvcTester.from(wac).withHttpMessageConverters(
				List.of(wac.getBean(AbstractJackson2HttpMessageConverter.class)));
	private val mockMvc = MockMvcTester.from(wac).withHttpMessageConverters(
		listOf(wac.getBean(AbstractJackson2HttpMessageConverter::class.java)))
The above assumes the converter has been registered as a Bean.
Finally, if you have a MockMvc instance handy, you can create a MockMvcTester by providing the MockMvc instance to use using the create factory method.spring-doc.cn
