Enable MVC Configuration
You can use the @EnableWebMvc annotation to enable MVC configuration with programmatic configuration, or <mvc:annotation-driven> with XML configuration, as the following example shows:spring-doc.cn
@EnableWebMvc
public class WebConfiguration {
@EnableWebMvc
	   xmlns:mvc="http://www.springframework.org/schema/mvc"
	   xsi:schemaLocation="
			https://www.springframework.org/schema/mvc/spring-mvc.xsd">
	<mvc:annotation-driven/>
</beans>
When using Spring Boot, you may want to use @Configuration classes of type WebMvcConfigurer but without @EnableWebMvc to keep Spring Boot MVC customizations. See more details in the MVC Config API section and in the dedicated Spring Boot documentation.
The preceding example registers a number of Spring MVC infrastructure beans and adapts to dependencies available on the classpath (for example, payload converters for JSON, XML, and others).spring-doc.cn
