This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.6!spring-doc.cn
Null-safety
Although Java does not let you express null-safety with its type system, the Spring Framework codebase is annotated with JSpecify annotations to declare the nullness of APIs, fields and related type usages. Reading the JSpecify user guide is highly recommended in order to get familiar with those annotations and semantics.spring-doc.cn
The primary goal of this explicit null-safety arrangement is to prevent NullPointerException to be thrown at runtime via build time checks and to turn explicit nullness into a way to express the possible absence of value. It is useful in both Java by leveraging some tooling (NullAway or IDEs supporting null-safety annotations such as IntelliJ IDEA or Eclipse) and Kotlin where JSpecify annotations are automatically translated to Kotlin’s null safety.spring-doc.cn
The Nullness Spring API can be used at runtime to detect the nullness of a type usage, a field, a method return type or a parameter. It provides full support for JSpecify annotations, Kotlin null safety, Java primitive types, as well as a pragmatic check on any @Nullable annotation (regardless of the package).spring-doc.cn
Annotating libraries with JSpecify annotations
As of Spring Framework 7, the Spring Framework codebase leverages JSpecify annotations to expose null-safe APIs and to check the consistency of those null-safety declarations with NullAway as part of its build. It is recommended for each library depending on Spring Framework (Spring portfolio projects), as well as other libraries related to the Spring ecosystem (Reactor, Micrometer and Spring community projects), to do the same.spring-doc.cn
Leveraging JSpecify annotations in Spring applications
Developing applications with IDEs supporting null-safety annotations, such as IntelliJ IDEA or Eclipse, will provide warnings in Java and errors in Kotlin when the null-safety contracts are not honored, allowing Spring application developers to refine their null handling to prevent NullPointerException to be thrown at runtime.spring-doc.cn
Optionally, Spring application developers can annotate their codebase and use NullAway to enforce null-safety during build time at application level.spring-doc.cn
Guidelines
The purpose of this section is to share some guidelines proposed for specifying explicitly the nullness of Spring-related libraries or applications.spring-doc.cn
JSpecify
The key points to understand is that by default, the nullness of types is unknown in Java, and that non-null type usages are by far more frequent than nullable ones. In order to keep codebases readable, we typically want to define that by default, type usages are non-null unless marked as nullable for a specific scope. This is exactly the purpose of @NullMarked that is typically set with Spring at package level via a package-info.java file, for example:spring-doc.cn
@NullMarked
package org.springframework.core;
import org.jspecify.annotations.NullMarked;
In the various Java files belonging to the package, nullable type usages are defined explicitly with @Nullable. It is recommended that this annotation is specified just before the related type.spring-doc.cn
For example, for a field:spring-doc.cn
private @Nullable String fileEncoding;
Or for method parameters and return value:spring-doc.cn
public static @Nullable String buildMessage(@Nullable String message,
                                            @Nullable Throwable cause) {
When overriding a method, nullness annotations are not inherited from the superclass method. That means those nullness annotations should be repeated if you just want to override the implementation and keep the same API nullness.spring-doc.cn
With arrays and varargs, you need to be able to differentiate the nullness of the elements from the nullness of the array itself. Pay attention to the syntax defined by the Java specification which may be initially surprising:spring-doc.cn
  • @Nullable Object[] array means individual elements can be null but the array itself can’t.spring-doc.cn
  • Object @Nullable [] array means individual elements can’t be null but the array itself can.spring-doc.cn
  • @Nullable Object @Nullable [] array means both individual elements and the array can be null.spring-doc.cn
The Java specifications also enforces that annotations defined with @Target(ElementType.TYPE_USE) like JSpecify @Nullable should be specified after the last . with inner or fully qualified types:spring-doc.cn
@NonNull and @NullUnmarked should rarely be needed for typical use cases.spring-doc.cn
NullAway
Configuration
The recommended configuration is:spring-doc.cn
  • NullAway:OnlyNullMarked=true in order to perform nullness checks only for packages annotated with @NullMarked.spring-doc.cn
  • NullAway:CustomContractAnnotations=org.springframework.lang.Contract which makes NullAway aware of the @Contract annotation in the org.springframework.lang package which can be used to express complementary semantics to avoid non-relevant null-safety warnings in your codebase.spring-doc.cn
A good example of @Contract benefits is Assert#notnull which is annotated with @Contract("null, _ → fail"). With the configuration above, NullAway will understand that after a successful invocation, the value passed as a parameter is not null.spring-doc.cn
Optionally, it is possible to set NullAway:JSpecifyMode=true to enable checks on the full JSpecify semantics, including annotations on generic types. Be aware that this mode is still under development and requires using JDK 22 or later (typically combined with the --release Java compiler flag to configure the expected baseline). It is recommended to enable the JSpecify mode only as a second step, after making sure the codebase generates no warning with the recommended configuration mentioned above.spring-doc.cn
Warnings suppression
There are a few valid use cases where NullAway will wrongly detect nullness problems. In such case, it is recommended to suppress related warnings and to document the reason:spring-doc.cn
  • @SuppressWarnings("NullAway.Init") at field, constructor or class level can be used to avoid unnecessary warnings due to the lazy initialization of fields, for example due to a class implementing InitializingBean.spring-doc.cn
  • @SuppressWarnings("NullAway") // Dataflow analysis limitation can be used when NullAway dataflow analysis is not able to detect that the path involving a nullness problem will never happen.spring-doc.cn
  • @SuppressWarnings("NullAway") // Lambda can be used when NullAway does not take into account assertions performed outside of a lambda for the code path within the lambda.spring-doc.cn
  • @SuppressWarnings("NullAway") // Reflection can be used for some reflection operations that are known returning non-null values even if that can’t be expressed by the API.spring-doc.cn
  • @SuppressWarnings("NullAway") // Well-known map keys can be used when Map#get invocations are done with keys known to be present and non-null related values inserted previously.spring-doc.cn
  • @SuppressWarnings("NullAway") // Overridden method does not define nullness can be used when the super class does not define nullness (typically when the super class is coming from a dependency).spring-doc.cn
Migrating from Spring null-safety annotations
Spring null-safety annotations @Nullable, @NonNull, @NonNullApi, and @NonNullFields in the org.springframework.lang package have been introduced in Spring Framework 5 when JSpecify did not exist and the best option was to leverage JSR 305 (a dormant but widespread JSR) meta-annotations. They are deprecated as of Spring Framework 7 in favor of JSpecify annotations, which provide significant enhancements such as properly defined specifications, a canonical dependency with no split-package issue, better tooling, better Kotlin integration and the capability to specify the nullness more precisely for more use cases.spring-doc.cn
A key difference is that Spring null-safety annotations, following JSR 305 semantics, apply to fields, parameters and return values while JSpecify annotations apply to type usages. This subtle difference is in practice pretty significant, as it allows for example to differentiate the nullness of elements from the nullness of arrays/varargs as well as defining the nullness of generic types.spring-doc.cn
That means array and varargs null-safety declarations have to be updated to keep the same semantic. For example @Nullable Object[] array with Spring annotations needs to be changed to Object @Nullable [] array with JSpecify annotations. Same for varargs.spring-doc.cn
It is also recommended to move field and return value annotations closer to the type, for example:spring-doc.cn
  • For fields, instead of @Nullable private String field with Spring annotations, use private @Nullable String field with JSpecify annotations.spring-doc.cn
  • For return values, instead of @Nullable public String method() with Spring annotations, use public @Nullable String method() with JSpecify annotations.spring-doc.cn
Also, with JSpecify, you don’t need to specify @NonNull when overriding a type usage annotated with @Nullable in the super method to "undo" the nullable declaration in null-marked code. Just declare it unannotated and the null-marked defaults (a type usage is considered non-null unless explicitly annotated as nullable) will apply.spring-doc.cn
