This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.1.4!spring-doc.cn
RabbitMQ Consumer Properties
The following properties are available for Rabbit consumers only and must be prefixed with spring.cloud.stream.rabbit.bindings.<channelName>.consumer..spring-doc.cn
However if the same set of properties needs to be applied to most bindings, to avoid repetition, Spring Cloud Stream supports setting values for all channels, in the format of spring.cloud.stream.rabbit.default.<property>=<value>.spring-doc.cn
Also, keep in mind that binding specific property will override its equivalent in the default.spring-doc.cn
acknowledgeMode
The acknowledge mode.spring-doc.cn
Default: AUTO.spring-doc.cn
anonymousGroupPrefix
When the binding has no group property, an anonymous, auto-delete queue is bound to the destination exchange. The default naming stragegy for such queues results in a queue named anonymous.<base64 representation of a UUID>. Set this property to change the prefix to something other than the default.spring-doc.cn
Default: anonymous..spring-doc.cn
autoBindDlq
Whether to automatically declare the DLQ and bind it to the binder DLX.spring-doc.cn
Default: false.spring-doc.cn
bindingRoutingKey
The routing key with which to bind the queue to the exchange (if bindQueue is true). Can be multiple keys - see bindingRoutingKeyDelimiter. For partitioned destinations, -<instanceIndex> is appended to each key.spring-doc.cn
Default: #.spring-doc.cn
When this is not null, 'bindingRoutingKey' is considered to be a list of keys delimited by this value; often a comma is used.spring-doc.cn
Default: null.spring-doc.cn
bindQueue
Whether to declare the queue and bind it to the destination exchange. Set it to false if you have set up your own infrastructure and have previously created and bound the queue.spring-doc.cn
Default: true.spring-doc.cn
consumerTagPrefix
Used to create the consumer tag(s); will be appended by #n where n increments for each consumer created. Example: ${spring.application.name}-${spring.cloud.stream.bindings.input.group}-${spring.cloud.stream.instance-index}.spring-doc.cn
Default: none - the broker will generate random consumer tags.spring-doc.cn
containerType
Select the type of listener container to be used. See Choosing a Container in the Spring AMQP documentation for more information. Also see [rabbitmq-stream].spring-doc.cn
Default: simplespring-doc.cn
deadLetterQueueName
The name of the DLQspring-doc.cn
Default: prefix+destination.dlqspring-doc.cn
deadLetterExchange
A DLX to assign to the queue. Relevant only if autoBindDlq is true.spring-doc.cn
Default: 'prefix+DLX'spring-doc.cn
deadLetterExchangeType
The type of the DLX to assign to the queue. Relevant only if autoBindDlq is true.spring-doc.cn
Default: 'direct'spring-doc.cn
deadLetterRoutingKey
A dead letter routing key to assign to the queue. Relevant only if autoBindDlq is true.spring-doc.cn
Default: destinationspring-doc.cn
declareDlx
Whether to declare the dead letter exchange for the destination. Relevant only if autoBindDlq is true. Set to false if you have a pre-configured DLX.spring-doc.cn
declareExchange
Whether to declare the exchange for the destination.spring-doc.cn
delayedExchange
Whether to declare the exchange as a Delayed Message Exchange. Requires the delayed message exchange plugin on the broker. The x-delayed-type argument is set to the exchangeType.spring-doc.cn
dlqBindingArguments
Arguments applied when binding the dlq to the dead letter exchange; used with headers deadLetterExchangeType to specify headers to match on. For example …​dlqBindingArguments.x-match=any, …​dlqBindingArguments.someHeader=someValue.spring-doc.cn
Default: emptyspring-doc.cn
dlqDeadLetterExchange
If a DLQ is declared, a DLX to assign to that queue.spring-doc.cn
Default: nonespring-doc.cn
dlqDeadLetterRoutingKey
If a DLQ is declared, a dead letter routing key to assign to that queue.spring-doc.cn
dlqExpires
How long before an unused dead letter queue is deleted (in milliseconds).spring-doc.cn
Default: no expirationspring-doc.cn
dlqLazy
Declare the dead letter queue with the x-queue-mode=lazy argument. See “Lazy Queues”. Consider using a policy instead of this setting, because using a policy allows changing the setting without deleting the queue.spring-doc.cn
dlqMaxLength
Maximum number of messages in the dead letter queue.spring-doc.cn
Default: no limitspring-doc.cn
dlqMaxLengthBytes
Maximum number of total bytes in the dead letter queue from all messages.spring-doc.cn
dlqMaxPriority
Maximum priority of messages in the dead letter queue (0-255).spring-doc.cn
dlqOverflowBehavior
Action to take when dlqMaxLength or dlqMaxLengthBytes is exceeded; currently drop-head or reject-publish but refer to the RabbitMQ documentation.spring-doc.cn
dlqQuorum.deliveryLimit
When quorum.enabled=true, set a delivery limit after which the message is dropped or dead-lettered.spring-doc.cn
Default: none - broker default will apply.spring-doc.cn
dlqQuorum.enabled
When true, create a quorum dead letter queue instead of a classic queue.spring-doc.cn
Default: falsespring-doc.cn
dlqQuorum.initialGroupSize
When quorum.enabled=true, set the initial quorum size.spring-doc.cn
dlqSingleActiveConsumer
Set to true to set the x-single-active-consumer queue property to true.spring-doc.cn
dlqTtl
Default time to live to apply to the dead letter queue when declared (in milliseconds).spring-doc.cn
durableSubscription
Whether the subscription should be durable. Only effective if group is also set.spring-doc.cn
exchangeAutoDelete
If declareExchange is true, whether the exchange should be auto-deleted (that is, removed after the last queue is removed).spring-doc.cn
exchangeDurable
If declareExchange is true, whether the exchange should be durable (that is, it survives broker restart).spring-doc.cn
exchangeType
The exchange type: direct, fanout, headers or topic for non-partitioned destinations and direct, headers or topic for partitioned destinations.spring-doc.cn
Default: topic.spring-doc.cn
exclusive
Whether to create an exclusive consumer. Concurrency should be 1 when this is true. Often used when strict ordering is required but enabling a hot standby instance to take over after a failure. See recoveryInterval, which controls how often a standby instance attempts to consume. Consider using singleActiveConsumer instead when using RabbitMQ 3.8 or later.spring-doc.cn
expires
How long before an unused queue is deleted (in milliseconds).spring-doc.cn
failedDeclarationRetryInterval
The interval (in milliseconds) between attempts to consume from a queue if it is missing.spring-doc.cn
Default: 5000spring-doc.cn
frameMaxHeadroom
The number of bytes to reserve for other headers when adding the stack trace to a DLQ message header. All headers must fit within the frame_max size configured on the broker. Stack traces can be large; if the size plus this property exceeds frame_max then the stack trace will be truncated. A WARN log will be written; consider increasing the frame_max or reducing the stack trace by catching the exception and throwing one with a smaller stack trace.spring-doc.cn
Default: 20000spring-doc.cn
headerPatterns
Patterns for headers to be mapped from inbound messages.spring-doc.cn
Default: ['*'] (all headers).spring-doc.cn
lazy
Declare the queue with the x-queue-mode=lazy argument. See “Lazy Queues”. Consider using a policy instead of this setting, because using a policy allows changing the setting without deleting the queue.spring-doc.cn
maxConcurrency
The maximum number of consumers. Not supported when the containerType is direct.spring-doc.cn
Default: 1.spring-doc.cn
maxLength
The maximum number of messages in the queue.spring-doc.cn
maxLengthBytes
The maximum number of total bytes in the queue from all messages.spring-doc.cn
maxPriority
The maximum priority of messages in the queue (0-255).spring-doc.cn
missingQueuesFatal
When the queue cannot be found, whether to treat the condition as fatal and stop the listener container. Defaults to false so that the container keeps trying to consume from the queue — for example, when using a cluster and the node hosting a non-HA queue is down.spring-doc.cn
overflowBehavior
Action to take when maxLength or maxLengthBytes is exceeded; currently drop-head or reject-publish but refer to the RabbitMQ documentation.spring-doc.cn
prefetch
Prefetch count.spring-doc.cn
prefix
A prefix to be added to the name of the destination and queues.spring-doc.cn
Default: "".spring-doc.cn
queueBindingArguments
Arguments applied when binding the queue to the exchange; used with headers exchangeType to specify headers to match on. For example …​queueBindingArguments.x-match=any, …​queueBindingArguments.someHeader=someValue.spring-doc.cn
queueDeclarationRetries
The number of times to retry consuming from a queue if it is missing. Relevant only when missingQueuesFatal is true. Otherwise, the container keeps retrying indefinitely. Not supported when the containerType is direct.spring-doc.cn
Default: 3spring-doc.cn
queueNameGroupOnly
When true, consume from a queue with a name equal to the group. Otherwise the queue name is destination.group. This is useful, for example, when using Spring Cloud Stream to consume from an existing RabbitMQ queue.spring-doc.cn
quorum.deliveryLimit
quorum.enabled
When true, create a quorum queue instead of a classic queue.spring-doc.cn
quorum.initialGroupSize
recoveryInterval
The interval between connection recovery attempts, in milliseconds.spring-doc.cn
Default: 5000.spring-doc.cn
requeueRejected
Whether delivery failures should be re-queued when retry is disabled or republishToDlq is false.spring-doc.cn
republishDeliveryMode
When republishToDlq is true, specifies the delivery mode of the republished message.spring-doc.cn
Default: DeliveryMode.PERSISTENTspring-doc.cn
republishToDlq
By default, messages that fail after retries are exhausted are rejected. If a dead-letter queue (DLQ) is configured, RabbitMQ routes the failed message (unchanged) to the DLQ. If set to true, the binder republishs failed messages to the DLQ with additional headers, including the exception message and stack trace from the cause of the final failure. Also see the frameMaxHeadroom property.spring-doc.cn
Default: truespring-doc.cn
transacted
Whether to use transacted channels.spring-doc.cn
ttl
Default time to live to apply to the queue when declared (in milliseconds).spring-doc.cn
txSize
The number of deliveries between acks. Not supported when the containerType is direct.spring-doc.cn
