This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.1.4!spring-doc.cn
Tombstone Records
When using compacted topics, a record with a null value (also called a tombstone record) represents the deletion of a key. To receive such messages in a Spring Cloud Stream function, you can use the following strategy.spring-doc.cn
public Function<Message<Person>, String> myFunction() {
    return value -> {
        Object v = value.getPayload();
        String className = v.getClass().getName();
        if (className.isEqualTo("org.springframework.kafka.support.KafkaNull")) {
            // this is a tombstone record
        else {
            // continue with processing
