This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.1.4!spring-doc.cn
Security Configuration
Apache Kafka supports secure connections between client and brokers. To take advantage of this feature, follow the guidelines in the Apache Kafka Documentation as well as the Kafka 0.9 security guidelines from the Confluent documentation. Use the spring.cloud.stream.kafka.binder.configuration option to set security properties for all clients created by the binder.spring-doc.cn
For example, to set security.protocol to SASL_SSL, set the following property:spring-doc.cn
spring.cloud.stream.kafka.binder.configuration.security.protocol=SASL_SSL
All the other security properties can be set in a similar manner.spring-doc.cn
When using Kerberos, follow the instructions in the reference documentation for creating and referencing the JAAS configuration.spring-doc.cn
Spring Cloud Stream supports passing JAAS configuration information to the application by using a JAAS configuration file and using Spring Boot properties.spring-doc.cn
Using JAAS Configuration Files
The JAAS and (optionally) krb5 file locations can be set for Spring Cloud Stream applications by using system properties. The following example shows how to launch a Spring Cloud Stream application with SASL and Kerberos by using a JAAS configuration file:spring-doc.cn
 java -Djava.security.auth.login.config=/path.to/kafka_client_jaas.conf -jar log.jar \
   --spring.cloud.stream.kafka.binder.brokers=secure.server:9092 \
   --spring.cloud.stream.bindings.input.destination=stream.ticktock \
   --spring.cloud.stream.kafka.binder.configuration.security.protocol=SASL_PLAINTEXT
Using Spring Boot Properties
As an alternative to having a JAAS configuration file, Spring Cloud Stream provides a mechanism for setting up the JAAS configuration for Spring Cloud Stream applications by using Spring Boot properties.spring-doc.cn
The following properties can be used to configure the login context of the Kafka client:spring-doc.cn
spring.cloud.stream.kafka.binder.jaas.loginModule
The login module name. Not necessary to be set in normal cases.spring-doc.cn
Default: com.sun.security.auth.module.Krb5LoginModule.spring-doc.cn
spring.cloud.stream.kafka.binder.jaas.controlFlag
The control flag of the login module.spring-doc.cn
Default: required.spring-doc.cn
spring.cloud.stream.kafka.binder.jaas.options
Map with a key/value pair containing the login module options.spring-doc.cn
Default: Empty map.spring-doc.cn
The following example shows how to launch a Spring Cloud Stream application with SASL and Kerberos by using Spring Boot configuration properties:spring-doc.cn
 java --spring.cloud.stream.kafka.binder.brokers=secure.server:9092 \
   --spring.cloud.stream.kafka.binder.autoCreateTopics=false \
   --spring.cloud.stream.kafka.binder.configuration.security.protocol=SASL_PLAINTEXT \
   --spring.cloud.stream.kafka.binder.jaas.options.useKeyTab=true \
   --spring.cloud.stream.kafka.binder.jaas.options.storeKey=true \
   --spring.cloud.stream.kafka.binder.jaas.options.keyTab=/etc/security/keytabs/kafka_client.keytab \
   --spring.cloud.stream.kafka.binder.jaas.options.principal=kafka-client-1@EXAMPLE.COM
The preceding example represents the equivalent of the following JAAS file:spring-doc.cn
KafkaClient {
    com.sun.security.auth.module.Krb5LoginModule required
    useKeyTab=true
    storeKey=true
    keyTab="/etc/security/keytabs/kafka_client.keytab"
    principal="[email protected]";
If the topics required already exist on the broker or will be created by an administrator, autocreation can be turned off and only client JAAS properties need to be sent.spring-doc.cn
Do not mix JAAS configuration files and Spring Boot properties in the same application. If the -Djava.security.auth.login.config system property is already present, Spring Cloud Stream ignores the Spring Boot properties.
Be careful when using the autoCreateTopics and autoAddPartitions with Kerberos. Usually, applications may use principals that do not have administrative rights in Kafka and Zookeeper. Consequently, relying on Spring Cloud Stream to create/modify topics may fail. In secure environments, we strongly recommend creating topics and managing ACLs administratively by using Kafka tooling.
Multi-binder configuration and JAAS
When connecting to multiple clusters in which each one requires separate JAAS configuration, then set the JAAS configuration using the property sasl.jaas.config. When this property is present in the application, it takes precedence over the other strategies mentioned above. See this KIP-85 for more details.spring-doc.cn
For example, if you have two clusters in your application with separate JAAS configuration, then the following is a template that you can use:spring-doc.cn
spring.cloud.stream:
    binders:
        kafka1:
          type: kafka
          environment:
             spring:
               cloud:
                 stream:
                  kafka:
                    binder:
                      brokers: localhost:9092
                      configuration.sasl.jaas.config: "org.apache.kafka.common.security.plain.PlainLoginModule required username=\"admin\" password=\"admin-secret\";"
        kafka2:
          type: kafka
          environment:
            spring:
              cloud:
                stream:
                  kafka:
                    binder:
                      brokers: localhost:9093
                      configuration.sasl.jaas.config: "org.apache.kafka.common.security.plain.PlainLoginModule required username=\"user1\" password=\"user1-secret\";"
    kafka.binder:
        configuration:
          security.protocol: SASL_PLAINTEXT
          sasl.mechanism: PLAIN
Note that both the Kafka clusters, and the sasl.jaas.config values for each of them are different in the above configuration.spring-doc.cn
See this sample application for more details on how to setup and run such an application.spring-doc.cn
