This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.1.4!spring-doc.cn
Customizing Consumer and Producer configuration
If you want advanced customization of consumer and producer configuration that is used for creating ConsumerFactory and ProducerFactory in Kafka, you can implement the following customizers.spring-doc.cn
Both of these interfaces provide a way to configure the config map used for consumer and producer properties. For example, if you want to gain access to a bean that is defined at the application level, you can inject that in the implementation of the configure method. When the binder discovers that these customizers are available as beans, it will invoke the configure method right before creating the consumer and producer factories.spring-doc.cn
Both of these interfaces also provide access to both the binding and destination names so that they can be accessed while customizing producer and consumer properties.spring-doc.cn
