This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.1.4!spring-doc.cn
State Cleanup
By default, no local state is cleaned up when the binding is stopped. This is the same behavior effective from Spring Kafka version 2.7. See Spring Kafka documentation for more details. To modify this behavior simply add a single CleanupConfig @Bean (configured to clean up on start, stop, or neither) to the application context; the bean will be detected and wired into the factory bean.spring-doc.cn
