This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.1.4!spring-doc.cn
Health Indicator
The health indicator requires the dependency spring-boot-starter-actuator. For maven use:spring-doc.cn
<dependency>
  <artifactId>spring-boot-starter-actuator</artifactId>
</dependency>
Spring Cloud Stream Kafka Streams Binder provides a health indicator to check the state of the underlying streams threads. Spring Cloud Stream defines a property management.health.binders.enabled to enable the health indicator. See the Spring Cloud Stream documentation.spring-doc.cn
The health indicator provides the following details for each stream thread’s metadata:spring-doc.cn
By default, only the global status is visible (UP or DOWN). To show the details, the property management.endpoint.health.show-details must be set to ALWAYS or WHEN_AUTHORIZED. For more details about the health information, see the Spring Boot Actuator documentation.spring-doc.cn
The status of the health indicator is UP if all the Kafka threads registered are in the RUNNING state.
Since there are three individual binders in Kafka Streams binder (KStream, KTable and GlobalKTable), all of them will report the health status. When enabling show-details, some of the information reported may be redundant.spring-doc.cn
When there are multiple Kafka Streams processors present in the same application, then the health checks will be reported for all of them and will be categorized by the application ID of Kafka Streams.spring-doc.cn
