This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.1.4!spring-doc.cn
Manual Acknowledgement
This example illustrates how one may manually acknowledge offsets in a consumer application.spring-doc.cn
This example requires that spring.cloud.stream.kafka.bindings.input.consumer.ackMode be set to MANUAL. Use the corresponding input channel name for your example.spring-doc.cn
@SpringBootApplication
public class ManuallyAcknowdledgingConsumer {
     SpringApplication.run(ManuallyAcknowdledgingConsumer.class, args);
 public Consumer<Message<?>> process() {
    return message -> {
        Acknowledgment acknowledgment = message.getHeaders().get(KafkaHeaders.ACKNOWLEDGMENT, Acknowledgment.class);
        if (acknowledgment != null) {
         System.out.println("Acknowledgment provided");
         acknowledgment.acknowledge();
