This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.1.4!spring-doc.cn
Kafka Metrics
Kafka binder module exposes the following metrics:spring-doc.cn
spring.cloud.stream.binder.kafka.offset: This metric indicates how many messages have not been yet consumed from a given binder’s topic by a given consumer group. The metrics provided are based on the Micrometer library. The binder creates the KafkaBinderMetrics bean if Micrometer is on the classpath and no other such beans provided by the application. The metric contains the consumer group information, topic and the actual lag in committed offset from the latest offset on the topic. This metric is particularly useful for providing auto-scaling feedback to a PaaS platform.spring-doc.cn
The metric collection behaviour can be configured by setting properties in the spring.cloud.stream.kafka.binder.metrics namespace, refer to the kafka binder properties section for more information.spring-doc.cn
You can exclude KafkaBinderMetrics from creating the necessary infrastructure like consumers and then reporting the metrics by providing the following component in the application.spring-doc.cn
@Component
class NoOpBindingMeters {
	NoOpBindingMeters(MeterRegistry registry) {
		registry.config().meterFilter(
				MeterFilter.denyNameStartsWith(KafkaBinderMetrics.OFFSET_LAG_METRIC_NAME));
More details on how to suppress meters selectively can be found here.spring-doc.cn
