For the latest stable version, please use Spring Cloud Config 4.2.0!spring-doc.cn
Health Indicator
Config Server comes with a Health Indicator that checks whether the configured EnvironmentRepository is working. By default, it asks the EnvironmentRepository for an application named app, the default profile, and the default label provided by the EnvironmentRepository implementation.spring-doc.cn
You can configure the Health Indicator to check more applications along with custom profiles and custom labels, as shown in the following example:spring-doc.cn
spring:
  cloud:
    config:
      server:
        health:
          repositories:
            myservice:
              label: mylabel
            myservice-dev:
              profiles: development
You can disable the Health Indicator by setting management.health.config.enabled=false.spring-doc.cn
Also, you can provide a custom down status of your own by setting property spring.cloud.config.server.health.down-health-status (valued to "DOWN' by default).spring-doc.cn
