For the latest stable version, please use Spring Cloud Config 4.2.0!spring-doc.cn
Overriding Properties Using Profiles
The final way to override properties coming from the config server is to specify them in profile specific configuration file within the client application.spring-doc.cn
For example, if you have the following configuration from the config serverspring-doc.cn
hello="Hello From Config Server!"
You can override the value of hello in the client application by setting hello in a profile specific configuration file and then enabling that profile.spring-doc.cn
application-overrides.properties
hello="Hello From Application!"
In the above example you would have to enable the overrides profile.spring-doc.cn
