For the latest stable version, please use Spring Cloud Config 4.2.0!spring-doc.cn
Custom Environment Repositories
Spring Cloud Config supports enhancing its configuration management by allowing you to create and integrate custom EnvironmentRepository implementations. This enables the addition of unique configuration sources to your application. Implementing the Ordered interface and specifying the getOrder method also lets you set the priority of your custom repository within a composite configuration setup. Without this, custom repositories are considered with the lowest priority by default.spring-doc.cn
Below is an example of how to create and configure a custom EnvironmentRepository:spring-doc.cn
public class CustomConfigurationRepository implements EnvironmentRepository, Ordered {
    public Environment findOne(String application, String profile, String label) {
        // Simulate fetching configuration from a custom source
        final Map<String, String> properties = Map.of(
            "key1", "value1",
            "key2", "value2",
            "key3", "value3"
        Environment environment = new Environment(application, profile);
        environment.add(new PropertySource("customPropertySource", properties));
        return environment;
    public int getOrder() {
        return 0;
@Profile("custom")
public class AppConfig {
    public CustomConfigurationRepository customConfigurationRepository() {
        return new CustomConfigurationRepository();
With this setup, if you activate the custom profile within your Spring application’s configuration, your custom environment repository will be integrated into the configuration server. For instance, specifying the custom profile in your application.properties or application.yml as follows:spring-doc.cn
spring:
  application:
  profiles:
    active: custom
Now, accessing the configuration server at:spring-doc.cn
http://localhost:8080/any-client/dev/latest
will return default values from the custom repository, as shown below:spring-doc.cn
  "name": "any-client",
  "profiles": ["dev"],
  "label": "latest",
  "propertySources": [
      "name": "customPropertySource",
      "source": {
        "key1": "value1",
        "key2": "value2",
        "key3": "value3"
