For the latest stable version, please use Spring Cloud Config 4.2.0!spring-doc.cn
Redis Backend
Spring Cloud Config Server supports Redis as a backend for configuration properties. You can enable this feature by adding a dependency to Spring Data Redis.spring-doc.cn
pom.xml
<dependencies>
	<dependency>
		<artifactId>spring-boot-starter-data-redis</artifactId>
	</dependency>
</dependencies>
The following configuration uses Spring Data RedisTemplate to access a Redis. We can use spring.redis.* properties to override default connection settings.spring-doc.cn
spring:
  profiles:
    active: redis
  redis:
    host: redis
    port: 16379
The properties should be stored as fields in a hash. The name of hash should be the same as spring.application.name property or conjunction of spring.application.name and spring.profiles.active[n].spring-doc.cn
HMSET sample-app server.port "8100" sample.topic.name "test" test.property1 "property1"
After running the command visible above a hash should contain the following keys with values:spring-doc.cn
HGETALL sample-app
  "server.port": "8100",
  "sample.topic.name": "test",
  "test.property1": "property1"
When no profile is specified default will be used.
