For the latest stable version, please use Spring Cloud Config 4.2.0!spring-doc.cn
CredHub Backend
Spring Cloud Config Server supports CredHub as a backend for configuration properties. You can enable this feature by adding a dependency to Spring CredHub.spring-doc.cn
pom.xml
<dependencies>
	<dependency>
		<groupId>org.springframework.credhub</groupId>
		<artifactId>spring-credhub-starter</artifactId>
	</dependency>
</dependencies>
The following configuration uses mutual TLS to access a CredHub:spring-doc.cn
spring:
  profiles:
    active: credhub
  cloud:
    config:
      server:
        credhub:
          url: https://credhub:8844
The properties should be stored as JSON, such as:spring-doc.cn
credhub set --name "/demo-app/default/master/toggles" --type=json
value: {"toggle.button": "blue", "toggle.link": "red"}
credhub set --name "/demo-app/default/master/abs" --type=json
value: {"marketing.enabled": true, "external.enabled": false}
All client applications with the name spring.cloud.config.name=demo-app will have the following properties available to them:spring-doc.cn
    toggle.button: "blue",
    toggle.link: "red",
    marketing.enabled: true,
    external.enabled: false
When no label is specified master will be used as a default value. You can change that by setting spring.cloud.config.server.credhub.defaultLabel.
When no profile is specified default will be used.
Values added to application will be shared by all the applications.
OAuth 2.0
You can authenticate with OAuth 2.0 using UAA as a provider.spring-doc.cn
pom.xml
<dependencies>
	<dependency>
		<groupId>org.springframework.security</groupId>
		<artifactId>spring-security-config</artifactId>
	</dependency>
	<dependency>
		<artifactId>spring-security-oauth2-client</artifactId>
	</dependency>
</dependencies>
The following configuration uses OAuth 2.0 and UAA to access a CredHub:spring-doc.cn
spring:
  profiles:
    active: credhub
  cloud:
    config:
      server:
        credhub:
          oauth2:
            registration-id: credhub-client
  security:
    oauth2:
      client:
        registration:
          credhub-client:
            provider: uaa
            client-id: credhub_config_server
            client-secret: asecret
            authorization-grant-type: client_credentials
        provider:
          uaa:
            token-uri: https://uaa:8443/oauth/token
The used UAA client-id should have credhub.read as scope.
The following table describes the CredHub configuration properties.spring-doc.cn
Property Name Remarks
urlspring-doc.cn
CredHub server URL.spring-doc.cn
pathspring-doc.cn
Base path for all credentials. Optional, defaults to empty.spring-doc.cn
defaultLabelspring-doc.cn
Default label to use when is not provided by client application. Optional, defaults to master.spring-doc.cn
oauth2spring-doc.cn
OAuth2 configuration to access CredHub. Optional.spring-doc.cn
