For the latest stable version, please use Spring Cloud Config 4.2.0!spring-doc.cn
Vault Backend
Spring Cloud Config Server also supports Vault as a backend.spring-doc.cn
Vault is a tool for securely accessing secrets. A secret is anything that to which you want to tightly control access, such as API keys, passwords, certificates, and other sensitive information. Vault provides a unified interface to any secret while providing tight access control and recording a detailed audit log.spring-doc.cn
For more information on Vault, see the Vault quick start guide.spring-doc.cn
To enable the config server to use a Vault backend, you can run your config server with the vault profile. For example, in your config server’s application.properties, you can add spring.profiles.active=vault.spring-doc.cn
By default, Spring Cloud Config Server uses Token based Authentication to fetch config from Vault. Vault also supports additional authentication methods like AppRole, LDAP, JWT, CloudFoundry, Kubernetes Auth. In order to use any authentication method other than TOKEN or the X-Config-Token header, we need to have Spring Vault Core on the classpath so that Config Server can delegate authentication to that library. Please add the below dependencies to your Config Server App.spring-doc.cn
Maven (pom.xml)spring-doc.cn
<dependencies>
	<dependency>
		<groupId>org.springframework.vault</groupId>
		<artifactId>spring-vault-core</artifactId>
	</dependency>
</dependencies>
Gradle (build.gradle)spring-doc.cn
dependencies {
    implementation "org.springframework.vault:spring-vault-core"
By default, the config server assumes that your Vault server runs at 127.0.0.1:8200. It also assumes that the name of backend is secret and the key is application. All of these defaults can be configured in your config server’s application.properties. The following table describes configurable Vault properties:spring-doc.cn
Name Default Value
hostspring-doc.cn
127.0.0.1spring-doc.cn
portspring-doc.cn
8200spring-doc.cn
schemespring-doc.cn
httpspring-doc.cn
backendspring-doc.cn
secretspring-doc.cn
defaultKeyspring-doc.cn
applicationspring-doc.cn
defaultLabelspring-doc.cn
main (Only used when enableLabel is set to true)spring-doc.cn
enableLabelspring-doc.cn
falsespring-doc.cn
profileSeparatorspring-doc.cn
,spring-doc.cn
kvVersionspring-doc.cn
1spring-doc.cn
skipSslValidationspring-doc.cn
falsespring-doc.cn
timeoutspring-doc.cn
5spring-doc.cn
namespacespring-doc.cn
nullspring-doc.cn
All of the properties in the preceding table must be prefixed with spring.cloud.config.server.vault or placed in the correct Vault section of a composite configuration.
All configurable properties can be found in org.springframework.cloud.config.server.environment.VaultEnvironmentProperties.spring-doc.cn
Vault 0.10.0 introduced a versioned key-value backend (k/v backend version 2) that exposes a different API than earlier versions, it now requires a data/ between the mount path and the actual context path and wraps secrets in a data object. Setting spring.cloud.config.server.vault.kv-version=2 will take this into account.
Optionally, there is support for the Vault Enterprise X-Vault-Namespace header. To have it sent to Vault set the namespace property.spring-doc.cn
With your config server running, you can make HTTP requests to the server to retrieve values from the Vault backend. To do so, you need a token for your Vault server.spring-doc.cn
First, place some data in you Vault, as shown in the following example:spring-doc.cn
$ vault kv put secret/application foo=bar baz=bam
$ vault kv put secret/myapp foo=myappsbar
Second, make an HTTP request to your config server to retrieve the values, as shown in the following example:spring-doc.cn
$ curl -X "GET" "http://localhost:8888/myapp/default" -H "X-Config-Token: yourtoken"spring-doc.cn
You should see a response similar to the following:spring-doc.cn
   "name":"myapp",
   "profiles":[
      "default"
   "label":null,
   "version":null,
   "state":null,
   "propertySources":[
         "name":"vault:myapp",
         "source":{
            "foo":"myappsbar"
         "name":"vault:application",
         "source":{
            "baz":"bam",
            "foo":"bar"
The default way for a client to provide the necessary authentication to let Config Server talk to Vault is to set the X-Config-Token header. However, you can instead omit the header and configure the authentication in the server, by setting the same configuration properties as Spring Cloud Vault. The property to set is spring.cloud.config.server.vault.authentication. It should be set to one of the supported authentication methods. You may also need to set other properties specific to the authentication method you use, by using the same property names as documented for spring.cloud.vault but instead using the spring.cloud.config.server.vault prefix. See the Spring Cloud Vault Reference Guide for more detail.spring-doc.cn
If you omit the X-Config-Token header and use a server property to set the authentication, the Config Server application needs an additional dependency on Spring Vault to enable the additional authentication options. See the Spring Vault Reference Guide for how to add that dependency.
Multiple Properties Sources
When using Vault, you can provide your applications with multiple properties sources. For example, assume you have written data to the following paths in Vault:spring-doc.cn
secret/myApp,dev
secret/myApp
secret/application,dev
secret/application
Properties written to secret/application are available to all applications using the Config Server. An application with the name, myApp, would have any properties written to secret/myApp and secret/application available to it. When myApp has the dev profile enabled, properties written to all of the above paths would be available to it, with properties in the first path in the list taking priority over the others.spring-doc.cn
Enabling Search by Label
By default, Vault backend does not use the label when searching for secrets. You can change this by setting the enableLabel feature flag to true and, optionally, setting the defaultLabel. When defaultLabel is not provided main will be used.spring-doc.cn
When enableLabel feature flag is on, the secrets in Vault should always have all three segments(application name, profile and label) in their paths. So the example in previous section, with enabled feature flag, would be like :spring-doc.cn
secret/myApp,dev,myLabel
secret/myApp,default,myLabel       # default profile
secret/application,dev,myLabel     # default application name
secret/application,default,myLabel # default application name and default profile.
Decrypting Vault Secrets in Property Sources
Spring Cloud Config Server supports decrypting properties from Vault by utilizing a special placeholder prefix {vault}. This feature allows for dynamic resolution of sensitive configuration properties directly from Vault at runtime.spring-doc.cn
Configuration Steps
All configuration settings for integrating with Vault should be placed in your application.yml or application.properties. Below are the specific configurations required to activate the Vault profile, connect to your Vault server, and format properties using the {vault} prefix.spring-doc.cn
Enable Vault Profile
Activate the Vault profile for your Spring Cloud Config Server:spring-doc.cn
spring:
  profiles:
    active: vault
Vault Configuration
Set up the connection to your Vault server with the necessary authentication details:spring-doc.cn
spring:
  cloud:
    config:
      server:
        vault:
          host: vault.example.com
          port: 8200
          scheme: https
          backend: secret
          defaultKey: application
          kvVersion: 2
          authentication: TOKEN
          token: ${VAULT_TOKEN}
          skipSslValidation: true
These settings specify the Vault server address, authentication method, and the token required to access Vault.spring-doc.cn
Property Formatting
Define properties with the {vault} prefix to specify the Vault path and key for retrieving secrets:spring-doc.cn
some:
  sensitive:
    value: '{vault}:path/to/secret#key'
This format directly maps to the location in Vault where the secret is stored (path/to/secret) and the specific secret key (key) to be retrieved.spring-doc.cn
Error Handling
If the Config Server encounters any issues during the decryption process, such as incorrect paths, access issues, or missing keys, the affected property will be prefixed with invalid. and its value will be set to <n/a>. This approach is similar to the handling of properties prefixed with {cipher}, but it is specifically tailored for integration with Vault, providing clear feedback when decryption fails.spring-doc.cn
