For the latest stable version, please use Spring Cloud Config 4.2.0! |
AWS Parameter Store
When using AWS Parameter Store as a backend, you can share configuration with all applications by placing properties within the /application
hierarchy.
For example, if you add parameters with the following names, all applications using the config server will have the properties foo.bar
and fred.baz
available to them:
/config/application/foo.bar
/config/application-default/fred.baz
