For the latest stable version, please use Spring Cloud Config 4.2.0!spring-doc.cn
AWS Secrets Manager Backend
Spring Cloud Config Server supports AWS Secrets Manager as a backend for configuration properties. You can enable this feature by adding a dependency to AWS Java SDK for Secrets Manager.spring-doc.cn
pom.xml
<dependency>
    <groupId>software.amazon.awssdk</groupId>
    <artifactId>secretsmanager</artifactId>
</dependency>
The following configuration uses the AWS Secrets Manager client to access secrets.spring-doc.cn
spring:
  profiles:
  	active: awssecretsmanager
  cloud:
    config:
      server:
        aws-secretsmanager:
          region: us-east-1
          endpoint: https://us-east-1.console.aws.amazon.com/
          origin: aws:secrets:
          prefix: /secret/foo
          profileSeparator: _
AWS Secrets Manager API credentials are determined using Default Credential Provider Chain.spring-doc.cn
  • When no application is specified application is the default, and when no profile is specified default is used.spring-doc.cn
  • Both label and defaultLabel properties are ignored, when ignoreLabel is set to true.spring-doc.cn
