For the latest stable version, please use Spring Cloud Config 4.2.0!spring-doc.cn
Sharing Configuration With All Applications
Sharing configuration between all applications varies according to which approach you take, as described in the following topics:spring-doc.cn
File Based Repositories
With file-based (git, svn, and native) repositories, resources with file names in application* (application.properties, application.yml, application-*.properties, and so on) are shared between all client applications. You can use resources with these file names to configure global defaults and have them be overridden by application-specific files as necessary.spring-doc.cn
The property overrides feature can also be used for setting global defaults, with placeholders applications allowed to override them locally.spring-doc.cn
With the “native” profile (a local file system backend) , you should use an explicit search location that is not part of the server’s own configuration. Otherwise, the application* resources in the default search locations get removed because they are part of the server.
Vault Server
When using Vault as a backend, you can share configuration with all applications by placing configuration in secret/application. For example, if you run the following Vault command, all applications using the config server will have the properties foo and baz available to them:spring-doc.cn
$ vault write secret/application foo=bar baz=bam
CredHub Server
When using CredHub as a backend, you can share configuration with all applications by placing configuration in /application/ or by placing it in the default profile for the application. For example, if you run the following CredHub command, all applications using the config server will have the properties shared.color1 and shared.color2 available to them:spring-doc.cn
credhub set --name "/application/profile/master/shared" --type=json
value: {"shared.color1": "blue", "shared.color": "red"}
credhub set --name "/my-app/default/master/more-shared" --type=json
value: {"shared.word1": "hello", "shared.word2": "world"}
JDBC Environment Repository
To share configurations using the JDBC backend, insert records into your database with 'application' as the value in the application column for entries intended to be shared across all clients. Application-specific properties can then override these shared configurations, providing flexibility and control over your application environments.spring-doc.cn
INSERT INTO PROPERTIES (APPLICATION, PROFILE, LABEL, KEY, VALUE)
VALUES ('application', 'default', 'master', 'a.b.c', 'shared-value');
VALUES ('myapp', 'prod', 'master', 'd.e.f', 'specific-value');
Refer to the JdbcEnvironmentRepository implementation and associated tests for detailed examples on setup and configuration management using the JDBC repository.spring-doc.cn
