Testcontainers
The Testcontainers library provides a way to manage services running inside Docker containers. It integrates with JUnit, allowing you to write a test class that can start up a container before any of the tests run. Testcontainers is especially useful for writing integration tests that talk to a real backend service such as MySQL, MongoDB, Cassandra and others.spring-doc.cn
In following sections we will describe some of the methods you can use to integrate Testcontainers with your tests.spring-doc.cn
Using Spring Beans
The containers provided by Testcontainers can be managed by Spring Boot as beans.spring-doc.cn
To declare a container as a bean, add a @Bean method to your test configuration:spring-doc.cn
import org.testcontainers.containers.MongoDBContainer;
import org.testcontainers.utility.DockerImageName;
import org.springframework.boot.test.context.TestConfiguration;
@TestConfiguration(proxyBeanMethods = false)
class MyTestConfiguration {
	MongoDBContainer mongoDbContainer() {
		return new MongoDBContainer(DockerImageName.parse("mongo:5.0"));
	fun mongoDbContainer(): MongoDBContainer {
		return MongoDBContainer(DockerImageName.parse("mongo:5.0"))
You can then inject and use the container by importing the configuration class in the test class:spring-doc.cn
import org.junit.jupiter.api.Test;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.boot.test.context.SpringBootTest;
import org.springframework.context.annotation.Import;
@SpringBootTest
@Import(MyTestConfiguration.class)
class MyIntegrationTests {
	@Autowired
	private MongoDBContainer mongo;
	@Test
	void myTest() {
@SpringBootTest
@Import(MyTestConfiguration::class)
	@Autowired
	private val mongo: MongoDBContainer? = null
	@Test
	fun myTest() {
This method of managing containers is often used in combination with service connection annotations.
Using the JUnit Extension
Testcontainers provides a JUnit extension which can be used to manage containers in your tests. The extension is activated by applying the @Testcontainers annotation from Testcontainers to your test class.spring-doc.cn
You can then use the @Container annotation on static container fields.spring-doc.cn
The @Testcontainers annotation can be used on vanilla JUnit tests, or in combination with @SpringBootTest:spring-doc.cn
import org.testcontainers.containers.Neo4jContainer;
import org.testcontainers.junit.jupiter.Container;
import org.testcontainers.junit.jupiter.Testcontainers;
@Testcontainers
@SpringBootTest
	@Container
	static Neo4jContainer<?> neo4j = new Neo4jContainer<>("neo4j:5");
	@Test
	void myTest() {
@Testcontainers
@SpringBootTest
	@Test
	fun myTest() {
	companion object {
		@Container
		@JvmStatic
		val neo4j = Neo4jContainer("neo4j:5");
The example above will start up a Neo4j container before any of the tests are run. The lifecycle of the container instance is managed by Testcontainers, as described in their official documentation.spring-doc.cn
In most cases, you will additionally need to configure the application to connect to the service running in the container.
Importing Container Configuration Interfaces
A common pattern with Testcontainers is to declare the container instances as static fields in an interface.spring-doc.cn
For example, the following interface declares two containers, one named mongo of type MongoDBContainer and another named neo4j of type Neo4jContainer:spring-doc.cn
interface MyContainers {
	@Container
	MongoDBContainer mongoContainer = new MongoDBContainer("mongo:5.0");
	@Container
	Neo4jContainer<?> neo4jContainer = new Neo4jContainer<>("neo4j:5");
	companion object {
		@Container
		val mongoContainer: MongoDBContainer = MongoDBContainer("mongo:5.0")
		@Container
		val neo4jContainer: Neo4jContainer<*> = Neo4jContainer("neo4j:5")
When you have containers declared in this way, you can reuse their configuration in multiple tests by having the test classes implement the interface.spring-doc.cn
It’s also possible to use the same interface configuration in your Spring Boot tests. To do so, add @ImportTestcontainers to your test configuration class:spring-doc.cn
import org.springframework.boot.testcontainers.context.ImportTestcontainers;
@ImportTestcontainers(MyContainers.class)
@ImportTestcontainers(MyContainers::class)
Lifecycle of Managed Containers
If you have used the annotations and extensions provided by Testcontainers, then the lifecycle of container instances is managed entirely by Testcontainers. Please refer to the offical Testcontainers documentation for the information.spring-doc.cn
When the containers are managed by Spring as beans, then their lifecycle is managed by Spring:spring-doc.cn
  • Container beans are created and started before all other beans.spring-doc.cn
  • Container beans are stopped after the destruction of all other beans.spring-doc.cn
This process ensures that any beans, which rely on functionality provided by the containers, can use those functionalities. It also ensures that they are cleaned up whilst the container is still available.spring-doc.cn
When your application beans rely on functionality of containers, prefer configuring the containers as Spring beans to ensure the correct lifecycle behavior.
Having containers managed by Testcontainers instead of as Spring beans provides no guarantee of the order in which beans and containers will shutdown. It can happen that containers are shutdown before the beans relying on container functionality are cleaned up. This can lead to exceptions being thrown by client beans, for example, due to loss of connection.
Container beans are created and started once per application context managed by Spring’s TestContext Framework. For details about how TestContext Framework manages the underlying application contexts and beans therein, please refer to the Spring Framework documentation.spring-doc.cn
Container beans are stopped as part of the TestContext Framework’s standard application context shutdown process. When the application context gets shutdown, the containers are shutdown as well. This usually happens after all tests using that specific cached application context have finished executing. It may also happen earlier, depending on the caching behavior configured in TestContext Framework.spring-doc.cn
A single test container instance can, and often is, retained across execution of tests from multiple test classes.
Service Connections
A service connection is a connection to any remote service. Spring Boot’s auto-configuration can consume the details of a service connection and use them to establish a connection to a remote service. When doing so, the connection details take precedence over any connection-related configuration properties.spring-doc.cn
When using Testcontainers, connection details can be automatically created for a service running in a container by annotating the container field in the test class.spring-doc.cn
import org.springframework.boot.testcontainers.service.connection.ServiceConnection;
@Testcontainers
@SpringBootTest
	@Container
	@ServiceConnection
	@Test
	void myTest() {
@Testcontainers
@SpringBootTest
	@Test
	fun myTest() {
	companion object {
		@Container
		@ServiceConnection
		@JvmStatic
Thanks to @ServiceConnection, the above configuration allows Neo4j-related beans in the application to communicate with Neo4j running inside the Testcontainers-managed Docker container. This is done by automatically defining a Neo4jConnectionDetails bean which is then used by the Neo4j auto-configuration, overriding any connection-related configuration properties.spring-doc.cn
You’ll need to add the spring-boot-testcontainers module as a test dependency in order to use service connections with Testcontainers.
Service connection annotations are processed by ContainerConnectionDetailsFactory classes registered with spring.factories. A ContainerConnectionDetailsFactory can create a ConnectionDetails bean based on a specific Container subclass, or the Docker image name.spring-doc.cn
The following service connection factories are provided in the spring-boot-testcontainers jar:spring-doc.cn
Connection Details Matched on
ActiveMQConnectionDetailsspring-doc.cn
Containers named "symptoma/activemq" or ActiveMQContainerspring-doc.cn
ArtemisConnectionDetailsspring-doc.cn
Containers of type ArtemisContainerspring-doc.cn
CassandraConnectionDetailsspring-doc.cn
Containers of type CassandraContainerspring-doc.cn
CouchbaseConnectionDetailsspring-doc.cn
Containers of type CouchbaseContainerspring-doc.cn
ElasticsearchConnectionDetailsspring-doc.cn
Containers of type ElasticsearchContainerspring-doc.cn
FlywayConnectionDetailsspring-doc.cn
Containers of type JdbcDatabaseContainerspring-doc.cn
JdbcConnectionDetailsspring-doc.cn
KafkaConnectionDetailsspring-doc.cn
Containers of type KafkaContainer, ConfluentKafkaContainer or RedpandaContainerspring-doc.cn
LdapConnectionDetailsspring-doc.cn
Containers named "osixia/openldap" or of type LLdapContainerspring-doc.cn
LiquibaseConnectionDetailsspring-doc.cn
MongoConnectionDetailsspring-doc.cn
Containers of type MongoDBContainerspring-doc.cn
Neo4jConnectionDetailsspring-doc.cn
Containers of type Neo4jContainerspring-doc.cn
OtlpLoggingConnectionDetailsspring-doc.cn
Containers named "otel/opentelemetry-collector-contrib" or of type LgtmStackContainerspring-doc.cn
OtlpMetricsConnectionDetailsspring-doc.cn
OtlpTracingConnectionDetailsspring-doc.cn
PulsarConnectionDetailsspring-doc.cn
Containers of type PulsarContainerspring-doc.cn
R2dbcConnectionDetailsspring-doc.cn
Containers of type ClickHouseContainer, MariaDBContainer, MSSQLServerContainer, MySQLContainer, OracleContainer (free), OracleContainer (XE) or PostgreSQLContainerspring-doc.cn
RabbitConnectionDetailsspring-doc.cn
Containers of type RabbitMQContainerspring-doc.cn
RedisConnectionDetailsspring-doc.cn
Containers of type RedisContainer or RedisStackContainer, or containers named "redis", "redis/redis-stack" or "redis/redis-stack-server"spring-doc.cn
ZipkinConnectionDetailsspring-doc.cn
Containers named "openzipkin/zipkin"spring-doc.cn
By default all applicable connection details beans will be created for a given Container. For example, a PostgreSQLContainer will create both JdbcConnectionDetails and R2dbcConnectionDetails.spring-doc.cn
If you want to create only a subset of the applicable types, you can use the type attribute of @ServiceConnection.spring-doc.cn
By default Container.getDockerImageName().getRepository() is used to obtain the name used to find connection details. The repository portion of the Docker image name ignores any registry and the version. This works as long as Spring Boot is able to get the instance of the Container, which is the case when using a static field like in the example above.spring-doc.cn
If you’re using a @Bean method, Spring Boot won’t call the bean method to get the Docker image name, because this would cause eager initialization issues. Instead, the return type of the bean method is used to find out which connection detail should be used. This works as long as you’re using typed containers such as Neo4jContainer or RabbitMQContainer. This stops working if you’re using GenericContainer, for example with Redis as shown in the following example:spring-doc.cn
import org.testcontainers.containers.GenericContainer;
public class MyRedisConfiguration {
	@ServiceConnection(name = "redis")
	public GenericContainer<?> redisContainer() {
		return new GenericContainer<>("redis:7");
	fun redisContainer(): GenericContainer<*> {
		return GenericContainer("redis:7")
Spring Boot can’t tell from GenericContainer which container image is used, so the name attribute from @ServiceConnection must be used to provide that hint.spring-doc.cn
You can also use the name attribute of @ServiceConnection to override which connection detail will be used, for example when using custom images. If you are using the Docker image registry.mycompany.com/mirror/myredis, you’d use @ServiceConnection(name="redis") to ensure RedisConnectionDetails are created.spring-doc.cn
SSL with Service Connections
You can use the @Ssl, @JksKeyStore, @JksTrustStore, @PemKeyStore and @PemTrustStore annotations on a supported container to enable SSL support for that service connection. Please note that you still have to enable SSL on the service which is running inside the Testcontainer yourself, the annotations only configure SSL on the client side in your application.spring-doc.cn
import com.redis.testcontainers.RedisContainer;
import org.springframework.boot.testcontainers.service.connection.PemKeyStore;
import org.springframework.boot.testcontainers.service.connection.PemTrustStore;
import org.springframework.data.redis.core.RedisOperations;
@Testcontainers
@SpringBootTest
class MyRedisWithSslIntegrationTests {
	@Container
	@ServiceConnection
	@PemKeyStore(certificate = "classpath:client.crt", privateKey = "classpath:client.key")
	@PemTrustStore("classpath:ca.crt")
	static RedisContainer redis = new SecureRedisContainer("redis:latest");
	@Autowired
	private RedisOperations<Object, Object> operations;
	@Test
	void testRedis() {
The above code uses the @PemKeyStore annotation to load the client certificate and key into the keystore and the and @PemTrustStore annotation to load the CA certificate into the truststore. This will authenticate the client against the server, and the CA certificate in the truststore makes sure that the server certificate is valid and trusted.spring-doc.cn
The SecureRedisContainer in this example is a custom subclass of RedisContainer which copies certificates to the correct places and invokes redis-server with commandline parameters enabling SSL.spring-doc.cn
The SSL annotations are supported for the following service connections:spring-doc.cn
The ElasticsearchContainer additionally supports automatic detection of server side SSL. To use this feature, annotate the container with @Ssl, as seen in the following example, and Spring Boot takes care of the client side SSL configuration for you:spring-doc.cn
import org.testcontainers.elasticsearch.ElasticsearchContainer;
import org.springframework.boot.test.autoconfigure.data.elasticsearch.DataElasticsearchTest;
import org.springframework.boot.testcontainers.service.connection.Ssl;
import org.springframework.data.elasticsearch.client.elc.ElasticsearchTemplate;
@Testcontainers
@DataElasticsearchTest
class MyElasticsearchWithSslIntegrationTests {
	@Ssl
	@Container
	@ServiceConnection
	static ElasticsearchContainer elasticsearch = new ElasticsearchContainer(
			"docker.elastic.co/elasticsearch/elasticsearch:8.17.2");
	@Autowired
	private ElasticsearchTemplate elasticsearchTemplate;
	@Test
	void testElasticsearch() {
Dynamic Properties
A slightly more verbose but also more flexible alternative to service connections is @DynamicPropertySource. A static @DynamicPropertySource method allows adding dynamic property values to the Spring Environment.spring-doc.cn
import org.springframework.test.context.DynamicPropertyRegistry;
import org.springframework.test.context.DynamicPropertySource;
@Testcontainers
@SpringBootTest
	@Container
	@Test
	void myTest() {
	static void neo4jProperties(DynamicPropertyRegistry registry) {
		registry.add("spring.neo4j.uri", neo4j::getBoltUrl);
@Testcontainers
@SpringBootTest
	@Test
	fun myTest() {
	companion object {
		@Container
		@JvmStatic
		@JvmStatic
		fun neo4jProperties(registry: DynamicPropertyRegistry) {
			registry.add("spring.neo4j.uri") { neo4j.boltUrl }
The above configuration allows Neo4j-related beans in the application to communicate with Neo4j running inside the Testcontainers-managed Docker container.spring-doc.cn
