HTTP Exchanges (httpexchanges)
The httpexchanges endpoint provides information about HTTP request-response exchanges.spring-doc.cn
Retrieving the HTTP Exchanges
To retrieve the HTTP exchanges, make a GET request to /actuator/httpexchanges, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/httpexchanges' -i -X GET
The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 511
  "exchanges" : [ {
    "timestamp" : "2022-12-22T13:43:41Z",
    "request" : {
      "uri" : "https://api.example.com",
      "method" : "GET",
      "headers" : {
        "Accept" : [ "application/json" ]
    "response" : {
      "status" : 200,
      "headers" : {
        "Content-Type" : [ "application/json" ]
    "principal" : {
      "name" : "alice"
    "session" : {
      "id" : "83d585d5-5a68-41ba-8718-93aa361fcc72"
    "timeTaken" : "PT0.023S"
Response Structure
The response contains details of the traced HTTP request-response exchanges. The following table describes the structure of the response:spring-doc.cn
Path Type Description
exchangesspring-doc.cn
Arrayspring-doc.cn
An array of HTTP request-response exchanges.spring-doc.cn
exchanges.[].timestampspring-doc.cn
Stringspring-doc.cn
Timestamp of when the exchange occurred.spring-doc.cn
exchanges.[].principalspring-doc.cn
Objectspring-doc.cn
Principal of the exchange, if any.spring-doc.cn
exchanges.[].principal.namespring-doc.cn
Stringspring-doc.cn
Name of the principal.spring-doc.cn
exchanges.[].request.methodspring-doc.cn
Stringspring-doc.cn
HTTP method of the request.spring-doc.cn
exchanges.[].request.remoteAddressspring-doc.cn
Stringspring-doc.cn
Remote address from which the request was received, if known.spring-doc.cn
exchanges.[].request.urispring-doc.cn
Stringspring-doc.cn
URI of the request.spring-doc.cn
exchanges.[].request.headersspring-doc.cn
Objectspring-doc.cn
Headers of the request, keyed by header name.spring-doc.cn
exchanges.[].request.headers.*.[]spring-doc.cn
Arrayspring-doc.cn
Values of the headerspring-doc.cn
exchanges.[].response.statusspring-doc.cn
Numberspring-doc.cn
Status of the responsespring-doc.cn
exchanges.[].response.headersspring-doc.cn
Objectspring-doc.cn
Headers of the response, keyed by header name.spring-doc.cn
exchanges.[].response.headers.*.[]spring-doc.cn
Arrayspring-doc.cn
exchanges.[].sessionspring-doc.cn
Objectspring-doc.cn
Session associated with the exchange, if any.spring-doc.cn
exchanges.[].session.idspring-doc.cn
Stringspring-doc.cn
ID of the session.spring-doc.cn
exchanges.[].timeTakenspring-doc.cn
Stringspring-doc.cn
Time taken to handle the exchange.spring-doc.cn
