This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.3!spring-doc.cn
Conditions Evaluation Report (conditions)
The conditions endpoint provides information about the evaluation of conditions on configuration and auto-configuration classes.spring-doc.cn
Retrieving the Report
To retrieve the report, make a GET request to /actuator/conditions, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/conditions' -i -X GET
The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 3524
  "contexts" : {
    "application" : {
      "positiveMatches" : {
        "EndpointAutoConfiguration#propertiesEndpointAccessResolver" : [ {
          "condition" : "OnBeanCondition",
          "message" : "@ConditionalOnMissingBean (types: org.springframework.boot.actuate.endpoint.EndpointAccessResolver; SearchStrategy: all) did not find any beans"
        "EndpointAutoConfiguration#endpointOperationParameterMapper" : [ {
          "message" : "@ConditionalOnMissingBean (types: org.springframework.boot.actuate.endpoint.invoke.ParameterValueMapper; SearchStrategy: all) did not find any beans"
        "EndpointAutoConfiguration#endpointCachingOperationInvokerAdvisor" : [ {
          "message" : "@ConditionalOnMissingBean (types: org.springframework.boot.actuate.endpoint.invoker.cache.CachingOperationInvokerAdvisor; SearchStrategy: all) did not find any beans"
      "negativeMatches" : {
        "WebFluxEndpointManagementContextConfiguration" : {
          "notMatched" : [ {
            "condition" : "OnWebApplicationCondition",
            "message" : "not a reactive web application"
          "matched" : [ {
            "condition" : "OnClassCondition",
            "message" : "@ConditionalOnClass found required classes 'org.springframework.web.reactive.DispatcherHandler', 'org.springframework.http.server.reactive.HttpHandler'"
        "GsonHttpMessageConvertersConfiguration.GsonHttpMessageConverterConfiguration" : {
          "notMatched" : [ {
            "condition" : "GsonHttpMessageConvertersConfiguration.PreferGsonOrJacksonAndJsonbUnavailableCondition",
            "message" : "AnyNestedCondition 0 matched 2 did not; NestedCondition on GsonHttpMessageConvertersConfiguration.PreferGsonOrJacksonAndJsonbUnavailableCondition.JacksonJsonbUnavailable NoneNestedConditions 1 matched 1 did not; NestedCondition on GsonHttpMessageConvertersConfiguration.JacksonAndJsonbUnavailableCondition.JsonbPreferred @ConditionalOnProperty (spring.mvc.converters.preferred-json-mapper=jsonb) did not find property 'spring.mvc.converters.preferred-json-mapper'; NestedCondition on GsonHttpMessageConvertersConfiguration.JacksonAndJsonbUnavailableCondition.JacksonAvailable @ConditionalOnBean (types: org.springframework.http.converter.json.MappingJackson2HttpMessageConverter; SearchStrategy: all) found bean 'mappingJackson2HttpMessageConverter'; NestedCondition on GsonHttpMessageConvertersConfiguration.PreferGsonOrJacksonAndJsonbUnavailableCondition.GsonPreferred @ConditionalOnProperty (spring.mvc.converters.preferred-json-mapper=gson) did not find property 'spring.mvc.converters.preferred-json-mapper'"
          "matched" : [ ]
        "WebMvcEndpointManagementContextConfiguration#managementHealthEndpointWebMvcHandlerMapping" : {
          "notMatched" : [ {
            "condition" : "OnManagementPortCondition",
            "message" : "Management Port actual port type (SAME) did not match required type (DIFFERENT)"
          "matched" : [ ]
      "unconditionalClasses" : [ "org.springframework.boot.autoconfigure.context.PropertyPlaceholderAutoConfiguration", "org.springframework.boot.actuate.autoconfigure.endpoint.jackson.JacksonEndpointAutoConfiguration", "org.springframework.boot.actuate.autoconfigure.endpoint.EndpointAutoConfiguration" ]
Response Structure
The response contains details of the application’s condition evaluation. The following table describes the structure of the response:spring-doc.cn
Path Type Description
contextsspring-doc.cn
Objectspring-doc.cn
Application contexts keyed by id.spring-doc.cn
contexts.*.positiveMatchesspring-doc.cn
Objectspring-doc.cn
Classes and methods with conditions that were matched.spring-doc.cn
contexts.*.positiveMatches.*.[].conditionspring-doc.cn
Stringspring-doc.cn
Name of the condition.spring-doc.cn
contexts.*.positiveMatches.*.[].messagespring-doc.cn
Stringspring-doc.cn
Details of why the condition was matched.spring-doc.cn
contexts.*.negativeMatchesspring-doc.cn
Objectspring-doc.cn
Classes and methods with conditions that were not matched.spring-doc.cn
contexts.*.negativeMatches.*.notMatchedspring-doc.cn
Arrayspring-doc.cn
Conditions that were matched.spring-doc.cn
contexts.*.negativeMatches.*.notMatched.[].conditionspring-doc.cn
Stringspring-doc.cn
contexts.*.negativeMatches.*.notMatched.[].messagespring-doc.cn
Stringspring-doc.cn
Details of why the condition was not matched.spring-doc.cn
contexts.*.negativeMatches.*.matchedspring-doc.cn
Arrayspring-doc.cn
contexts.*.negativeMatches.*.matched.[].conditionspring-doc.cn
Stringspring-doc.cn
contexts.*.negativeMatches.*.matched.[].messagespring-doc.cn
Stringspring-doc.cn
contexts.*.unconditionalClassesspring-doc.cn
Arrayspring-doc.cn
Names of unconditional auto-configuration classes if any.spring-doc.cn
contexts.*.parentIdspring-doc.cn
Stringspring-doc.cn
Id of the parent application context, if any.spring-doc.cn
