Spring MVC
Spring Boot has a number of starters that include Spring MVC. Note that some starters include a dependency on Spring MVC rather than include it directly. This section answers common questions about Spring MVC and Spring Boot.spring-doc.cn
Write a JSON REST Service
Any Spring @RestController in a Spring Boot application should render JSON response by default as long as Jackson2 is on the classpath, as shown in the following example:spring-doc.cn
import org.springframework.web.bind.annotation.RequestMapping;
import org.springframework.web.bind.annotation.RestController;
@RestController
public class MyController {
	@RequestMapping("/thing")
	public MyThing thing() {
		return new MyThing();
@RestController
	fun thing(): MyThing {
		return MyThing()
As long as MyThing can be serialized by Jackson2 (true for a normal POJO or Groovy object), then localhost:8080/thing serves a JSON representation of it by default. Note that, in a browser, you might sometimes see XML responses, because browsers tend to send accept headers that prefer XML.spring-doc.cn
Write an XML REST Service
If you have the Jackson XML extension (jackson-dataformat-xml) on the classpath, you can use it to render XML responses. The previous example that we used for JSON would work. To use the Jackson XML renderer, add the following dependency to your project:spring-doc.cn
<dependency>
	<groupId>com.fasterxml.jackson.dataformat</groupId>
	<artifactId>jackson-dataformat-xml</artifactId>
</dependency>
If Jackson’s XML extension is not available and JAXB is available, XML can be rendered with the additional requirement of having MyThing annotated as @XmlRootElement, as shown in the following example:spring-doc.cn
import jakarta.xml.bind.annotation.XmlRootElement;
@XmlRootElement
public class MyThing {
	private String name;
	// getters/setters ...
	public String getName() {
		return this.name;
	public void setName(String name) {
		this.name = name;
@XmlRootElement
class MyThing {
	var name: String? = null
You will need to ensure that the JAXB library is part of your project, for example by adding:spring-doc.cn
<dependency>
	<groupId>org.glassfish.jaxb</groupId>
	<artifactId>jaxb-runtime</artifactId>
</dependency>
To get the server to render XML instead of JSON, you might have to send an Accept: text/xml header (or use a browser).
Customize the Jackson ObjectMapper
Spring MVC (client and server side) uses HttpMessageConverters to negotiate content conversion in an HTTP exchange. If Jackson is on the classpath, you already get the default converter(s) provided by Jackson2ObjectMapperBuilder, an instance of which is auto-configured for you.spring-doc.cn
The ObjectMapper (or XmlMapper for Jackson XML converter) instance (created by default) has the following customized properties:spring-doc.cn
  • MapperFeature.DEFAULT_VIEW_INCLUSION is disabledspring-doc.cn
  • DeserializationFeature.FAIL_ON_UNKNOWN_PROPERTIES is disabledspring-doc.cn
  • SerializationFeature.WRITE_DATES_AS_TIMESTAMPS is disabledspring-doc.cn
  • SerializationFeature.WRITE_DURATIONS_AS_TIMESTAMPS is disabledspring-doc.cn
Spring Boot also has some features to make it easier to customize this behavior.spring-doc.cn
You can configure the ObjectMapper and XmlMapper instances by using the environment. Jackson provides an extensive suite of on/off features that can be used to configure various aspects of its processing. These features are described in several enums (in Jackson) that map onto properties in the environment:spring-doc.cn
Enum Property Values
EnumFeaturespring-doc.cn
spring.jackson.datatype.enum.<feature_name>spring-doc.cn
true, falsespring-doc.cn
JsonNodeFeaturespring-doc.cn
spring.jackson.datatype.json-node.<feature_name>spring-doc.cn
DeserializationFeaturespring-doc.cn
spring.jackson.deserialization.<feature_name>spring-doc.cn
JsonGenerator.Featurespring-doc.cn
spring.jackson.generator.<feature_name>spring-doc.cn
MapperFeaturespring-doc.cn
spring.jackson.mapper.<feature_name>spring-doc.cn
JsonParser.Featurespring-doc.cn
spring.jackson.parser.<feature_name>spring-doc.cn
SerializationFeaturespring-doc.cn
spring.jackson.serialization.<feature_name>spring-doc.cn
JsonInclude.Includespring-doc.cn
spring.jackson.default-property-inclusionspring-doc.cn
always, non_null, non_absent, non_default, non_emptyspring-doc.cn
For example, to enable pretty print, set spring.jackson.serialization.indent_output=true. Note that, thanks to the use of relaxed binding, the case of indent_output does not have to match the case of the corresponding enum constant, which is INDENT_OUTPUT.spring-doc.cn
This environment-based configuration is applied to the auto-configured Jackson2ObjectMapperBuilder bean and applies to any mappers created by using the builder, including the auto-configured ObjectMapper bean.spring-doc.cn
The context’s Jackson2ObjectMapperBuilder can be customized by one or more Jackson2ObjectMapperBuilderCustomizer beans. Such customizer beans can be ordered (Boot’s own customizer has an order of 0), letting additional customization be applied both before and after Boot’s customization.spring-doc.cn
Any beans of type Module are automatically registered with the auto-configured Jackson2ObjectMapperBuilder and are applied to any ObjectMapper instances that it creates. This provides a global mechanism for contributing custom modules when you add new features to your application.spring-doc.cn
If you wish to register additional modules programmatically using a Jackson2ObjectMapperBuilderCustomizer, make sure to use the modulesToInstall method that takes a consumer as the other variants are not additive.
If you want to replace the default ObjectMapper completely, either define a @Bean of that type or, if you prefer the builder-based approach, define a Jackson2ObjectMapperBuilder @Bean. When defining an ObjectMapper bean, marking it as @Primary is recommended as the auto-configuration’s ObjectMapper that it will replace is @Primary. Note that, in either case, doing so disables all auto-configuration of the ObjectMapper.spring-doc.cn
If you provide any @Beans of type MappingJackson2HttpMessageConverter, they replace the default value in the MVC configuration. Also, a convenience bean of type HttpMessageConverters is provided (and is always available if you use the default MVC configuration). It has some useful methods to access the default and user-enhanced message converters.spring-doc.cn
See the Customize the @ResponseBody Rendering section and the WebMvcAutoConfiguration source code for more details.spring-doc.cn
Spring uses HttpMessageConverters to render @ResponseBody (or responses from @RestController). You can contribute additional converters by adding beans of the appropriate type in a Spring Boot context. If a bean you add is of a type that would have been included by default anyway (such as MappingJackson2HttpMessageConverter for JSON conversions), it replaces the default value. A convenience bean of type HttpMessageConverters is provided and is always available if you use the default MVC configuration. It has some useful methods to access the default and user-enhanced message converters (For example, it can be useful if you want to manually inject them into a custom RestTemplate).spring-doc.cn
As in normal MVC usage, any WebMvcConfigurer beans that you provide can also contribute converters by overriding the configureMessageConverters method. However, unlike with normal MVC, you can supply only additional converters that you need (because Spring Boot uses the same mechanism to contribute its defaults). Finally, if you opt out of the default Spring Boot MVC configuration by providing your own @EnableWebMvc configuration, you can take control completely and do everything manually by using getMessageConverters from WebMvcConfigurationSupport.spring-doc.cn
See the WebMvcAutoConfiguration source code for more details.spring-doc.cn
Handling Multipart File Uploads
Spring Boot embraces the servlet 5 Part API to support uploading files. By default, Spring Boot configures Spring MVC with a maximum size of 1MB per file and a maximum of 10MB of file data in a single request. You may override these values, the location to which intermediate data is stored (for example, to the /tmp directory), and the threshold past which data is flushed to disk by using the properties exposed in the MultipartProperties class. For example, if you want to specify that files be unlimited, set the spring.servlet.multipart.max-file-size property to -1.spring-doc.cn
The multipart support is helpful when you want to receive multipart encoded file data as a @RequestParam-annotated parameter of type MultipartFile in a Spring MVC controller handler method.spring-doc.cn
See the MultipartAutoConfiguration source for more details.spring-doc.cn
It is recommended to use the container’s built-in support for multipart uploads rather than introduce an additional dependency such as Apache Commons File Upload.
Switch Off the Spring MVC DispatcherServlet
By default, all content is served from the root of your application (/). If you would rather map to a different path, you can configure one as follows:spring-doc.cn
spring.mvc.servlet.path=/mypath
spring:
  mvc:
    servlet:
      path: "/mypath"
If you have additional servlets you can declare a @Bean of type Servlet or ServletRegistrationBean for each and Spring Boot will register them transparently to the container. It is also possible to use @ServletRegistration as an annotation-based alternative to ServletRegistrationBean. Because servlets are registered that way, they can be mapped to a sub-context of the DispatcherServlet without invoking it.spring-doc.cn
Configuring the DispatcherServlet yourself is unusual but if you really need to do it, a @Bean of type DispatcherServletPath must be provided as well to provide the path of your custom DispatcherServlet.spring-doc.cn
Switch Off the Default MVC Configuration
The easiest way to take complete control over MVC configuration is to provide your own @Configuration with the @EnableWebMvc annotation. Doing so leaves all MVC configuration in your hands.spring-doc.cn
Customize ViewResolvers
A ViewResolver is a core component of Spring MVC, translating view names in @Controller to actual View implementations. Note that view resolvers are mainly used in UI applications, rather than REST-style services (a View is not used to render a @ResponseBody). There are many implementations of ViewResolver to choose from, and Spring on its own is not opinionated about which ones you should use. Spring Boot, on the other hand, installs one or two for you, depending on what it finds on the classpath and in the application context. The DispatcherServlet uses all the resolvers it finds in the application context, trying each one in turn until it gets a result. If you add your own, you have to be aware of the order and in which position your resolver is added.spring-doc.cn
WebMvcAutoConfiguration adds the following ViewResolver beans to your context:spring-doc.cn
  • An InternalResourceViewResolver named ‘defaultViewResolver’. This one locates physical resources that can be rendered by using the DefaultServlet (including static resources and JSP pages, if you use those). It applies a prefix and a suffix to the view name and then looks for a physical resource with that path in the servlet context (the defaults are both empty but are accessible for external configuration through spring.mvc.view.prefix and spring.mvc.view.suffix). You can override it by providing a bean of the same type.spring-doc.cn
  • A BeanNameViewResolver named ‘beanNameViewResolver’. This is a useful member of the view resolver chain and picks up any beans with the same name as the View being resolved. It should not be necessary to override or replace it.spring-doc.cn
  • A ContentNegotiatingViewResolver named ‘viewResolver’ is added only if there are actually beans of type View present. This is a composite resolver, delegating to all the others and attempting to find a match to the ‘Accept’ HTTP header sent by the client. There is a useful blog about ContentNegotiatingViewResolver that you might like to study to learn more, and you might also look at the source code for detail. You can switch off the auto-configured ContentNegotiatingViewResolver by defining a bean named ‘viewResolver’.spring-doc.cn
  • If you use Thymeleaf, you also have a ThymeleafViewResolver named ‘thymeleafViewResolver’. It looks for resources by surrounding the view name with a prefix and suffix. The prefix is spring.thymeleaf.prefix, and the suffix is spring.thymeleaf.suffix. The values of the prefix and suffix default to ‘classpath:/templates/’ and ‘.html’, respectively. You can override ThymeleafViewResolver by providing a bean of the same name.spring-doc.cn
  • If you use FreeMarker, you also have a FreeMarkerViewResolver named ‘freeMarkerViewResolver’. It looks for resources in a loader path (which is externalized to spring.freemarker.templateLoaderPath and has a default value of ‘classpath:/templates/’) by surrounding the view name with a prefix and a suffix. The prefix is externalized to spring.freemarker.prefix, and the suffix is externalized to spring.freemarker.suffix. The default values of the prefix and suffix are empty and ‘.ftlh’, respectively. You can override FreeMarkerViewResolver by providing a bean of the same name. FreeMarker variables can be customized by defining a bean of type FreeMarkerVariablesCustomizer.spring-doc.cn
  • If you use Groovy templates (actually, if groovy-templates is on your classpath), you also have a GroovyMarkupViewResolver named ‘groovyMarkupViewResolver’. It looks for resources in a loader path by surrounding the view name with a prefix and suffix (externalized to spring.groovy.template.prefix and spring.groovy.template.suffix). The prefix and suffix have default values of ‘classpath:/templates/’ and ‘.tpl’, respectively. You can override GroovyMarkupViewResolver by providing a bean of the same name.spring-doc.cn
  • If you use Mustache, you also have a MustacheViewResolver named ‘mustacheViewResolver’. It looks for resources by surrounding the view name with a prefix and suffix. The prefix is spring.mustache.prefix, and the suffix is spring.mustache.suffix. The values of the prefix and suffix default to ‘classpath:/templates/’ and ‘.mustache’, respectively. You can override MustacheViewResolver by providing a bean of the same name.spring-doc.cn
For more detail, see the following sections:spring-doc.cn
Customize the ‘whitelabel’ Error Page
Spring Boot installs a ‘whitelabel’ error page that you see in a browser client if you encounter a server error (machine clients consuming JSON and other media types should see a sensible response with the right error code).spring-doc.cn
Set server.error.whitelabel.enabled=false to switch the default error page off. Doing so restores the default of the servlet container that you are using. Note that Spring Boot still tries to resolve the error view, so you should probably add your own error page rather than disabling it completely.
Overriding the error page with your own depends on the templating technology that you use. For example, if you use Thymeleaf, you can add an error.html template. If you use FreeMarker, you can add an error.ftlh template. In general, you need a View that resolves with a name of error or a @Controller that handles the /error path. Unless you replaced some of the default configuration, you should find a BeanNameViewResolver in your ApplicationContext, so a @Bean named error would be one way of doing that. See ErrorMvcAutoConfiguration for more options.spring-doc.cn
See also the section on Error Handling for details of how to register handlers in the servlet container.spring-doc.cn
