Liquibase (liquibase)
The liquibase endpoint provides information about database change sets applied by Liquibase.spring-doc.cn
Retrieving the Changes
To retrieve the changes, make a GET request to /actuator/liquibase, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/liquibase' -i -X GET
The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 721
  "contexts" : {
    "application" : {
      "liquibaseBeans" : {
        "liquibase" : {
          "changeSets" : [ {
            "author" : "marceloverdijk",
            "changeLog" : "org/springframework/boot/actuate/autoconfigure/liquibase/db.changelog-master.yaml",
            "comments" : "",
            "contexts" : [ ],
            "dateExecuted" : "2025-05-13T03:09:33.637Z",
            "deploymentId" : "7105771000",
            "description" : "createTable tableName=customer",
            "execType" : "EXECUTED",
            "id" : "1",
            "labels" : [ ],
            "checksum" : "9:d3589feb2baad02e15540750499ba311",
            "orderExecuted" : 1
Response Structure
The response contains details of the application’s Liquibase change sets. The following table describes the structure of the response:spring-doc.cn
Path Type Description
contextsspring-doc.cn
Objectspring-doc.cn
Application contexts keyed by idspring-doc.cn
contexts.*.liquibaseBeans.*.changeSetsspring-doc.cn
Arrayspring-doc.cn
Change sets made by the Liquibase beans, keyed by bean name.spring-doc.cn
contexts.*.liquibaseBeans.*.changeSets[].authorspring-doc.cn
Stringspring-doc.cn
Author of the change set.spring-doc.cn
contexts.*.liquibaseBeans.*.changeSets[].changeLogspring-doc.cn
Stringspring-doc.cn
Change log that contains the change set.spring-doc.cn
contexts.*.liquibaseBeans.*.changeSets[].commentsspring-doc.cn
Stringspring-doc.cn
Comments on the change set.spring-doc.cn
contexts.*.liquibaseBeans.*.changeSets[].contextsspring-doc.cn
Arrayspring-doc.cn
Contexts of the change set.spring-doc.cn
contexts.*.liquibaseBeans.*.changeSets[].dateExecutedspring-doc.cn
Stringspring-doc.cn
Timestamp of when the change set was executed.spring-doc.cn
contexts.*.liquibaseBeans.*.changeSets[].deploymentIdspring-doc.cn
Stringspring-doc.cn
ID of the deployment that ran the change set.spring-doc.cn
contexts.*.liquibaseBeans.*.changeSets[].descriptionspring-doc.cn
Stringspring-doc.cn
Description of the change set.spring-doc.cn
contexts.*.liquibaseBeans.*.changeSets[].execTypespring-doc.cn
Stringspring-doc.cn
Execution type of the change set (EXECUTED, FAILED, SKIPPED, RERAN, MARK_RAN).spring-doc.cn
contexts.*.liquibaseBeans.*.changeSets[].idspring-doc.cn
Stringspring-doc.cn
ID of the change set.spring-doc.cn
contexts.*.liquibaseBeans.*.changeSets[].labelsspring-doc.cn
Arrayspring-doc.cn
Labels associated with the change set.spring-doc.cn
contexts.*.liquibaseBeans.*.changeSets[].checksumspring-doc.cn
Stringspring-doc.cn
Checksum of the change set.spring-doc.cn
contexts.*.liquibaseBeans.*.changeSets[].orderExecutedspring-doc.cn
Numberspring-doc.cn
Order of the execution of the change set.spring-doc.cn
contexts.*.liquibaseBeans.*.changeSets[].tagspring-doc.cn
Stringspring-doc.cn
Tag associated with the change set, if any.spring-doc.cn
contexts.*.parentIdspring-doc.cn
Stringspring-doc.cn
Id of the parent application context, if any.spring-doc.cn
