This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.3!spring-doc.cn
Configuration Properties (configprops)
The configprops endpoint provides information about the application’s @ConfigurationProperties beans.spring-doc.cn
Retrieving All @ConfigurationProperties Beans
To retrieve all of the @ConfigurationProperties beans, make a GET request to /actuator/configprops, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/configprops' -i -X GET
The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 3411
  "contexts" : {
    "application" : {
      "beans" : {
        "management.endpoints.web.cors-org.springframework.boot.actuate.autoconfigure.endpoint.web.CorsEndpointProperties" : {
          "prefix" : "management.endpoints.web.cors",
          "properties" : {
            "allowedOrigins" : [ ],
            "maxAge" : "PT30M",
            "exposedHeaders" : [ ],
            "allowedOriginPatterns" : [ ],
            "allowedHeaders" : [ ],
            "allowedMethods" : [ ]
          "inputs" : {
            "maxAge" : { },
        "management.endpoints.web-org.springframework.boot.actuate.autoconfigure.endpoint.web.WebEndpointProperties" : {
          "prefix" : "management.endpoints.web",
          "properties" : {
            "pathMapping" : { },
            "exposure" : {
              "include" : [ "*" ],
              "exclude" : [ ]
            "basePath" : "/actuator",
            "discovery" : {
              "enabled" : true
          "inputs" : {
            "exposure" : {
              "include" : [ {
                "value" : "*",
                "origin" : "\"management.endpoints.web.exposure.include\" from property source \"Inlined Test Properties\""
              "exclude" : [ ]
            "basePath" : { },
            "discovery" : {
              "enabled" : { }
        "spring.web-org.springframework.boot.autoconfigure.web.WebProperties" : {
          "prefix" : "spring.web",
          "properties" : {
            "localeResolver" : "ACCEPT_HEADER",
            "resources" : {
              "staticLocations" : [ "classpath:/META-INF/resources/", "classpath:/resources/", "classpath:/static/", "classpath:/public/" ],
              "addMappings" : true,
              "chain" : {
                "cache" : true,
                "compressed" : false,
                "strategy" : {
                  "fixed" : {
                    "enabled" : false,
                    "paths" : [ "/**" ]
                  "content" : {
                    "enabled" : false,
                    "paths" : [ "/**" ]
              "cache" : {
                "cachecontrol" : { },
                "useLastModified" : true
          "inputs" : {
            "localeResolver" : { },
            "resources" : {
              "staticLocations" : [ { }, { }, { }, { } ],
              "addMappings" : { },
              "chain" : {
                "cache" : { },
                "compressed" : { },
                "strategy" : {
                  "fixed" : {
                    "enabled" : { },
                    "paths" : [ { } ]
                  "content" : {
                    "enabled" : { },
                    "paths" : [ { } ]
              "cache" : {
                "useLastModified" : { }
Response Structure
The response contains details of the application’s @ConfigurationProperties beans. The following table describes the structure of the response:spring-doc.cn
Path Type Description
contextsspring-doc.cn
Objectspring-doc.cn
Application contexts keyed by id.spring-doc.cn
contexts.*.beans.*spring-doc.cn
Objectspring-doc.cn
@ConfigurationProperties beans keyed by bean name.spring-doc.cn
contexts.*.beans.*.prefixspring-doc.cn
Stringspring-doc.cn
Prefix applied to the names of the bean’s properties.spring-doc.cn
contexts.*.beans.*.propertiesspring-doc.cn
Objectspring-doc.cn
Properties of the bean as name-value pairs.spring-doc.cn
contexts.*.beans.*.inputsspring-doc.cn
Objectspring-doc.cn
Origin and value of the configuration property used when binding to this bean.spring-doc.cn
contexts.*.parentIdspring-doc.cn
Stringspring-doc.cn
Id of the parent application context, if any.spring-doc.cn
Retrieving @ConfigurationProperties Beans By Prefix
To retrieve the @ConfigurationProperties beans mapped under a certain prefix, make a GET request to /actuator/configprops/{prefix}, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/configprops/spring.jackson' -i -X GET
HTTP/1.1 200 OK
Content-Disposition: inline;filename=f.txt
Content-Length: 878
  "contexts" : {
    "application" : {
      "beans" : {
        "spring.jackson-org.springframework.boot.autoconfigure.jackson.JacksonProperties" : {
          "prefix" : "spring.jackson",
          "properties" : {
            "serialization" : { },
            "visibility" : { },
            "parser" : { },
            "datatype" : {
              "jsonNode" : { },
              "enum" : { }
            "deserialization" : { },
            "generator" : { },
            "mapper" : { }
          "inputs" : {
            "visibility" : { },
            "parser" : { },
            "datatype" : {
              "jsonNode" : { },
              "enum" : { }
            "generator" : { },
            "mapper" : { }
The {prefix} does not need to be exact, a more general prefix will return all beans mapped under that prefix stem.
Response Structure
Objectspring-doc.cn
Objectspring-doc.cn
Stringspring-doc.cn
Objectspring-doc.cn
Objectspring-doc.cn
Stringspring-doc.cn
