This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.3!spring-doc.cn
Sessions (sessions)
The sessions endpoint provides information about the application’s HTTP sessions that are managed by Spring Session.spring-doc.cn
Retrieving Sessions
To retrieve the sessions, make a GET request to /actuator/sessions, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/sessions?username=alice' -i -X GET
The preceding examples retrieves all of the sessions for the user whose username is alice. The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 789
  "sessions" : [ {
    "id" : "79174863-15ab-487e-8adc-45853fb63c44",
    "attributeNames" : [ ],
    "creationTime" : "2025-03-14T04:15:24.174752298Z",
    "lastAccessedTime" : "2025-03-14T16:14:39.174759511Z",
    "maxInactiveInterval" : 1800,
    "expired" : false
    "id" : "9b43e76d-786f-4cdf-93d6-ae51f1a9e0cf",
    "creationTime" : "2025-03-14T14:15:24.179987928Z",
    "lastAccessedTime" : "2025-03-14T16:15:12.179989571Z",
    "expired" : false
    "id" : "4db5efcc-99cb-4d05-a52c-b49acfbb7ea9",
    "creationTime" : "2025-03-14T11:15:24.179975756Z",
    "lastAccessedTime" : "2025-03-14T16:14:47.179980124Z",
    "expired" : false
Query Parameters
The endpoint uses query parameters to limit the sessions that it returns. The following table shows the single required query parameter:spring-doc.cn
Parameter Description
usernamespring-doc.cn
Name of the user.spring-doc.cn
Response Structure
The response contains details of the matching sessions. The following table describes the structure of the response:spring-doc.cn
Path Type Description
sessionsspring-doc.cn
Arrayspring-doc.cn
Sessions for the given username.spring-doc.cn
sessions.[].idspring-doc.cn
Stringspring-doc.cn
ID of the session.spring-doc.cn
sessions.[].attributeNamesspring-doc.cn
Arrayspring-doc.cn
Names of the attributes stored in the session.spring-doc.cn
sessions.[].creationTimespring-doc.cn
Stringspring-doc.cn
Timestamp of when the session was created.spring-doc.cn
sessions.[].lastAccessedTimespring-doc.cn
Stringspring-doc.cn
Timestamp of when the session was last accessed.spring-doc.cn
sessions.[].maxInactiveIntervalspring-doc.cn
Numberspring-doc.cn
Maximum permitted period of inactivity, in seconds, before the session will expire.spring-doc.cn
sessions.[].expiredspring-doc.cn
Booleanspring-doc.cn
Whether the session has expired.spring-doc.cn
Retrieving a Single Session
To retrieve a single session, make a GET request to /actuator/sessions/{id}, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/sessions/4db5efcc-99cb-4d05-a52c-b49acfbb7ea9' -i -X GET
The preceding example retrieves the session with the id of 4db5efcc-99cb-4d05-a52c-b49acfbb7ea9. The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Length: 208
{"id":"4db5efcc-99cb-4d05-a52c-b49acfbb7ea9","attributeNames":[],"creationTime":"2025-03-14T11:15:24.179975756Z","lastAccessedTime":"2025-03-14T16:14:47.179980124Z","maxInactiveInterval":1800,"expired":false}
Response Structure
The response contains details of the requested session. The following table describes the structure of the response:spring-doc.cn
idspring-doc.cn
Stringspring-doc.cn
Arrayspring-doc.cn
Stringspring-doc.cn
Stringspring-doc.cn
Numberspring-doc.cn
Deleting a Session
To delete a session, make a DELETE request to /actuator/sessions/{id}, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/sessions/4db5efcc-99cb-4d05-a52c-b49acfbb7ea9' -i -X DELETE
The preceding example deletes the session with the id of 4db5efcc-99cb-4d05-a52c-b49acfbb7ea9.spring-doc.cn
