Application Startup (startup)
The startup endpoint provides information about the application’s startup sequence.spring-doc.cn
Retrieving the Application Startup Steps
The application startup steps can either be retrieved as a snapshot (GET) or drained from the buffer (POST).spring-doc.cn
Retrieving a snapshot of the Application Startup Steps
To retrieve the steps recorded so far during the application startup phase, make a GET request to /actuator/startup, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/startup' -i -X GET
The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 898
  "springBootVersion" : "3.5.0-SNAPSHOT",
  "timeline" : {
    "startTime" : "2025-05-13T03:09:49.052534920Z",
    "events" : [ {
      "endTime" : "2025-05-13T03:09:49.489411893Z",
      "duration" : "PT0.000006071S",
      "startTime" : "2025-05-13T03:09:49.489405822Z",
      "startupStep" : {
        "name" : "spring.beans.instantiate",
        "id" : 3,
        "tags" : [ {
          "key" : "beanName",
          "value" : "homeController"
        "parentId" : 2
      "endTime" : "2025-05-13T03:09:49.489419648Z",
      "duration" : "PT0.000021691S",
      "startTime" : "2025-05-13T03:09:49.489397957Z",
      "startupStep" : {
        "name" : "spring.boot.application.starting",
        "id" : 2,
        "tags" : [ {
          "key" : "mainApplicationClass",
          "value" : "com.example.startup.StartupApplication"
Draining the Application Startup Steps
To drain and return the steps recorded so far during the application startup phase, make a POST request to /actuator/startup, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/startup' -i -X POST
HTTP/1.1 200 OK
Content-Length: 898
  "timeline" : {
    "events" : [ {
      "endTime" : "2025-05-13T03:09:49.416668264Z",
      "duration" : "PT0.000814387S",
      "startTime" : "2025-05-13T03:09:49.415853877Z",
      "startupStep" : {
        "id" : 1,
        "tags" : [ {
          "key" : "beanName",
        "parentId" : 0
      "endTime" : "2025-05-13T03:09:49.416701937Z",
      "duration" : "PT0.005397099S",
      "startTime" : "2025-05-13T03:09:49.411304838Z",
      "startupStep" : {
        "id" : 0,
        "tags" : [ {
Response Structure
The response contains details of the application startup steps. The following table describes the structure of the response:spring-doc.cn
Path Type Description
springBootVersionspring-doc.cn
Stringspring-doc.cn
Spring Boot version for this application.spring-doc.cn
timeline.startTimespring-doc.cn
Stringspring-doc.cn
Start time of the application.spring-doc.cn
timeline.eventsspring-doc.cn
Arrayspring-doc.cn
An array of steps collected during application startup so far.spring-doc.cn
timeline.events.[].startTimespring-doc.cn
Stringspring-doc.cn
The timestamp of the start of this event.spring-doc.cn
timeline.events.[].endTimespring-doc.cn
Stringspring-doc.cn
The timestamp of the end of this event.spring-doc.cn
timeline.events.[].durationspring-doc.cn
Stringspring-doc.cn
The precise duration of this event.spring-doc.cn
timeline.events.[].startupStep.namespring-doc.cn
Stringspring-doc.cn
The name of the StartupStep.spring-doc.cn
timeline.events.[].startupStep.idspring-doc.cn
Numberspring-doc.cn
The id of this StartupStep.spring-doc.cn
timeline.events.[].startupStep.parentIdspring-doc.cn
Numberspring-doc.cn
The parent id for this StartupStep.spring-doc.cn
timeline.events.[].startupStep.tagsspring-doc.cn
Arrayspring-doc.cn
An array of key/value pairs with additional step info.spring-doc.cn
timeline.events.[].startupStep.tags[].keyspring-doc.cn
Stringspring-doc.cn
The key of the StartupStep Tag.spring-doc.cn
timeline.events.[].startupStep.tags[].valuespring-doc.cn
Stringspring-doc.cn
The value of the StartupStep Tag.spring-doc.cn
