This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.5! |
Mappings (mappings
The mappings
endpoint provides information about the application’s request mappings.
Retrieving the Mappings
To retrieve the mappings, make a GET
request to /actuator/mappings
, as shown in the following curl-based example:
$ curl 'http://localhost:43903/actuator/mappings' -i -X GET \
-H 'accept-encoding: gzip' \
-H 'user-agent: ReactorNetty/1.2.6-SNAPSHOT' \
-H 'accept: */*'
The resulting response is similar to the following:
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Transfer-Encoding: chunked
Date: Tue, 13 May 2025 03:09:58 GMT
Content-Length: 5836
"contexts" : {
"application" : {
"mappings" : {
"dispatcherServlets" : {
"dispatcherServlet" : [ {
"handler" : "Actuator root web endpoint",
"predicate" : "{GET [/actuator], produces [application/vnd.spring-boot.actuator.v3+json || application/vnd.spring-boot.actuator.v2+json || application/json]}",
"details" : {
"handlerMethod" : {
"className" : "org.springframework.boot.actuate.endpoint.web.servlet.WebMvcEndpointHandlerMapping.WebMvcLinksHandler",
"name" : "links",
"descriptor" : "(Ljakarta/servlet/http/HttpServletRequest;Ljakarta/servlet/http/HttpServletResponse;)Ljava/util/Map;"
"requestMappingConditions" : {
"consumes" : [ ],
"headers" : [ ],
"methods" : [ "GET" ],
"params" : [ ],
"patterns" : [ "/actuator" ],
"produces" : [ {
"mediaType" : "application/vnd.spring-boot.actuator.v3+json",
"negated" : false
"mediaType" : "application/vnd.spring-boot.actuator.v2+json",
"negated" : false
"mediaType" : "application/json",
"negated" : false
"handler" : "Actuator web endpoint 'mappings'",
"predicate" : "{GET [/actuator/mappings], produces [application/vnd.spring-boot.actuator.v3+json || application/vnd.spring-boot.actuator.v2+json || application/json]}",
"details" : {
"handlerMethod" : {
"className" : "org.springframework.boot.actuate.endpoint.web.servlet.AbstractWebMvcEndpointHandlerMapping.OperationHandler",
"name" : "handle",
"descriptor" : "(Ljakarta/servlet/http/HttpServletRequest;Ljava/util/Map;)Ljava/lang/Object;"
"consumes" : [ ],
"headers" : [ ],
"params" : [ ],
"patterns" : [ "/actuator/mappings" ],
"produces" : [ {
"negated" : false
"negated" : false
"negated" : false
"handler" : "org.springframework.boot.actuate.autoconfigure.web.mappings.MappingsEndpointServletDocumentationTests$TestConfiguration$$Lambda$2529/0x00007f5218d9f000@6c7a9587",
"predicate" : "(GET && /foo)",
"details" : {
"handlerFunction" : {
"className" : "org.springframework.boot.actuate.autoconfigure.web.mappings.MappingsEndpointServletDocumentationTests$TestConfiguration$$Lambda$2529/0x00007f5218d9f000"
"handler" : "org.springframework.boot.actuate.autoconfigure.web.mappings.MappingsEndpointServletDocumentationTests$ExampleController#example()",
"predicate" : "{POST [/], params [a!=alpha], headers [X-Custom=Foo], consumes [application/json || !application/xml], produces [text/plain]}",
"details" : {
"handlerMethod" : {
"className" : "org.springframework.boot.actuate.autoconfigure.web.mappings.MappingsEndpointServletDocumentationTests.ExampleController",
"name" : "example",
"descriptor" : "()Ljava/lang/String;"
"consumes" : [ {
"negated" : false
"mediaType" : "application/xml",
"negated" : true
"headers" : [ {
"name" : "X-Custom",
"value" : "Foo",
"negated" : false
"methods" : [ "POST" ],
"params" : [ {
"name" : "a",
"value" : "alpha",
"negated" : true
"patterns" : [ "/" ],
"produces" : [ {
"mediaType" : "text/plain",
"negated" : false
"handler" : "ResourceHttpRequestHandler [classpath [META-INF/resources/webjars/]]",
"predicate" : "/webjars/**"
"handler" : "ResourceHttpRequestHandler [classpath [META-INF/resources/], classpath [resources/], classpath [static/], classpath [public/], ServletContext [/]]",
"predicate" : "/**"
"servletFilters" : [ {
"servletNameMappings" : [ ],
"urlPatternMappings" : [ "/*" ],
"name" : "requestContextFilter",
"className" : "org.springframework.boot.web.servlet.filter.OrderedRequestContextFilter"
"name" : "formContentFilter",
"className" : "org.springframework.boot.web.servlet.filter.OrderedFormContentFilter"
"servlets" : [ {
"mappings" : [ "/" ],
"name" : "dispatcherServlet",
"className" : "org.springframework.web.servlet.DispatcherServlet"
Response Structure
The response contains details of the application’s mappings. The items found in the response depend on the type of web application (reactive or Servlet-based). The following table describes the structure of the common elements of the response:
Path | Type | Description |
Application contexts keyed by id. |
Mappings in the context, keyed by mapping type. |
Dispatcher servlet mappings, if any. |
Servlet filter mappings, if any. |
Servlet mappings, if any. |
Dispatcher handler mappings, if any. |
Id of the parent application context, if any. |
The entries that may be found in contexts.*.mappings
are described in the following sections.
Dispatcher Servlets Response Structure
When using Spring MVC, the response contains details of any DispatcherServlet
request mappings beneath contexts.*.mappings.dispatcherServlets
The following table describes the structure of this section of the response:
Dispatcher servlet mappings, if any, keyed by dispatcher servlet bean name. |
Additional implementation-specific details about the mapping. Optional. |
Handler for the mapping. |
Predicate for the mapping. |
Details of the function, if any, that will handle requests to this mapping. |
Fully qualified name of the class of the function. |
Details of the method, if any, that will handle requests to this mapping. |
Fully qualified name of the class of the method. |
Name of the method. |
Descriptor of the method as specified in the Java Language Specification. |
Details of the request mapping conditions. |
Details of the consumes condition |
Consumed media type. |
Whether the media type is negated. |
Details of the headers condition. |
Name of the header. |
Required value of the header, if any. |
Whether the value is negated. |
HTTP methods that are handled. |
Details of the params condition. |
Name of the parameter. |
Required value of the parameter, if any. |
Patterns identifying the paths handled by the mapping. |
Details of the produces condition. |
Produced media type. |
When using the Servlet stack, the response contains details of any Servlet
mappings beneath contexts.*.mappings.servlets
Mappings of the servlet. |
Name of the servlet. |
Class name of the servlet |
Servlet Filters Response Structure
When using the Servlet stack, the response contains details of any Filter
mappings beneath contexts.*.mappings.servletFilters
Names of the servlets to which the filter is mapped. |
URL pattern to which the filter is mapped. |
Name of the filter. |
Class name of the filter |
Dispatcher Handlers Response Structure
When using Spring WebFlux, the response contains details of any DispatcherHandler
request mappings beneath contexts.*.mappings.dispatcherHandlers
Dispatcher handler mappings, if any, keyed by dispatcher handler bean name. |
