对于最新的稳定版本,请使用 Spring Security 6.4.1! |
客户端身份验证支持
JWT 持有者
有关 JWT 不记名客户端身份验证的更多详细信息,请参阅 OAuth 2.0 客户端身份验证和授权的 JSON Web 令牌 (JWT) 配置文件。 |
JWT 不记名客户端身份验证的默认实现是NimbusJwtClientAuthenticationParametersConverter
这是一个Converter
,通过添加
已签名的 JSON Web 令牌 (JWS)client_assertion
参数。
这java.security.PrivateKey
或javax.crypto.SecretKey
用于签署 JWS
由com.nimbusds.jose.jwk.JWK
解析器关联NimbusJwtClientAuthenticationParametersConverter
身份验证方式private_key_jwt
给定 OAuth 2.0 客户端注册的以下 Spring Boot 2.x 属性:
spring:
security:
oauth2:
client:
registration:
okta:
client-id: okta-client-id
client-authentication-method: private_key_jwt
authorization-grant-type: authorization_code
以下示例显示如何配置WebClientReactiveAuthorizationCodeTokenResponseClient
Java
Kotlin
Function<ClientRegistration, JWK> jwkResolver = (clientRegistration) -> {
if (clientRegistration.getClientAuthenticationMethod().equals(ClientAuthenticationMethod.PRIVATE_KEY_JWT)) {
// Assuming RSA key type
RSAPublicKey publicKey = ...
RSAPrivateKey privateKey = ...
return new RSAKey.Builder(publicKey)
.privateKey(privateKey)
.keyID(UUID.randomUUID().toString())
return null;
WebClientReactiveAuthorizationCodeTokenResponseClient tokenResponseClient =
new WebClientReactiveAuthorizationCodeTokenResponseClient();
tokenResponseClient.addParametersConverter(
new NimbusJwtClientAuthenticationParametersConverter<>(jwkResolver));
val jwkResolver: Function<ClientRegistration, JWK> =
Function<ClientRegistration, JWK> { clientRegistration ->
if (clientRegistration.clientAuthenticationMethod.equals(ClientAuthenticationMethod.PRIVATE_KEY_JWT)) {
var publicKey: RSAPublicKey = ...
var privateKey: RSAPrivateKey = ...
.build()
null
val tokenResponseClient = WebClientReactiveAuthorizationCodeTokenResponseClient()
NimbusJwtClientAuthenticationParametersConverter(jwkResolver)
身份验证方式client_secret_jwt
spring:
security:
oauth2:
client:
registration:
okta:
client-authentication-method: client_secret_jwt
authorization-grant-type: client_credentials
以下示例显示如何配置WebClientReactiveClientCredentialsTokenResponseClient
Java
Kotlin
if (clientRegistration.getClientAuthenticationMethod().equals(ClientAuthenticationMethod.CLIENT_SECRET_JWT)) {
SecretKeySpec secretKey = new SecretKeySpec(
clientRegistration.getClientSecret().getBytes(StandardCharsets.UTF_8),
"HmacSHA256");
return new OctetSequenceKey.Builder(secretKey)
return null;
WebClientReactiveClientCredentialsTokenResponseClient tokenResponseClient =
new WebClientReactiveClientCredentialsTokenResponseClient();
val jwkResolver = Function<ClientRegistration, JWK?> { clientRegistration: ClientRegistration ->
if (clientRegistration.clientAuthenticationMethod == ClientAuthenticationMethod.CLIENT_SECRET_JWT) {
val secretKey = SecretKeySpec(
clientRegistration.clientSecret.toByteArray(StandardCharsets.UTF_8),
"HmacSHA256"
.build()
null
val tokenResponseClient = WebClientReactiveClientCredentialsTokenResponseClient()
自定义 JWT 断言
由NimbusJwtClientAuthenticationParametersConverter
包含iss
,sub
,aud
,jti
,iat
和exp
声明。您可以通过提供Consumer<NimbusJwtClientAuthenticationParametersConverter.JwtClientAuthenticationContext<T>>
自setJwtClientAssertionCustomizer()
.以下示例显示如何自定义 JWT 的声明:
Java
Kotlin
Function<ClientRegistration, JWK> jwkResolver = ...
NimbusJwtClientAuthenticationParametersConverter<OAuth2ClientCredentialsGrantRequest> converter =
new NimbusJwtClientAuthenticationParametersConverter<>(jwkResolver);
converter.setJwtClientAssertionCustomizer((context) -> {
context.getHeaders().header("custom-header", "header-value");
context.getClaims().claim("custom-claim", "claim-value");
val jwkResolver = ...
val converter: NimbusJwtClientAuthenticationParametersConverter<OAuth2ClientCredentialsGrantRequest> =
converter.setJwtClientAssertionCustomizer { context ->
context.headers.header("custom-header", "header-value")
context.claims.claim("custom-claim", "claim-value")
