此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Security 6.4.3! |
EnableReactiveMethodSecurity
Spring Security 使用 Reactor 的 Context 支持方法安全性,该上下文是使用ReactiveSecurityContextHolder
例如,这演示了如何检索当前登录用户的消息。
为此,该方法的返回类型必须是 |
Java
Kotlin
Authentication authentication = new TestingAuthenticationToken("user", "password", "ROLE_USER");
Mono<String> messageByUsername = ReactiveSecurityContextHolder.getContext()
.map(SecurityContext::getAuthentication)
.map(Authentication::getName)
.flatMap(this::findMessageByUsername)
// In a WebFlux application the `subscriberContext` is automatically setup using `ReactorContextWebFilter`
.subscriberContext(ReactiveSecurityContextHolder.withAuthentication(authentication));
StepVerifier.create(messageByUsername)
.expectNext("Hi user")
.verifyComplete();
val authentication: Authentication = TestingAuthenticationToken("user", "password", "ROLE_USER")
val messageByUsername: Mono<String> = ReactiveSecurityContextHolder.getContext()
.flatMap(this::findMessageByUsername) // In a WebFlux application the `subscriberContext` is automatically setup using `ReactorContextWebFilter`
.verifyComplete()
跟this::findMessageByUsername
定义为:
Java
Kotlin
Mono<String> findMessageByUsername(String username) {
return Mono.just("Hi " + username);
fun findMessageByUsername(username: String): Mono<String> {
return Mono.just("Hi $username")
以下是在响应式应用程序中使用方法安全时的最小方法安全配置。
Java
Kotlin
@EnableReactiveMethodSecurity
public class SecurityConfig {
public MapReactiveUserDetailsService userDetailsService() {
User.UserBuilder userBuilder = User.withDefaultPasswordEncoder();
UserDetails rob = userBuilder.username("rob")
.password("rob")
.roles("USER")
UserDetails admin = userBuilder.username("admin")
.password("admin")
.roles("USER","ADMIN")
return new MapReactiveUserDetailsService(rob, admin);
fun userDetailsService(): MapReactiveUserDetailsService {
val userBuilder: User.UserBuilder = User.withDefaultPasswordEncoder()
val rob = userBuilder.username("rob")
.password("rob")
.roles("USER")
.build()
val admin = userBuilder.username("admin")
.password("admin")
.roles("USER", "ADMIN")
.build()
return MapReactiveUserDetailsService(rob, admin)
请考虑以下类:
Java
Kotlin
@Component
public class HelloWorldMessageService {
@PreAuthorize("hasRole('ADMIN')")
public Mono<String> findMessage() {
return Mono.just("Hello World!");
@Component
fun findMessage(): Mono<String> {
或者,以下使用 Kotlin 协程的类:
Kotlin
@Component
suspend fun findMessage(): String {
delay(10)
return "Hello World!"
结合我们上面的配置,@PreAuthorize("hasRole('ADMIN')")
将确保findByMessage
仅由具有ADMIN
请务必注意,标准方法安全性中的任何表达式都适用于@EnableReactiveMethodSecurity
但是,目前我们只支持 return 类型的Boolean
或boolean
的表达式。
这意味着表达式不能阻塞。
与 WebFlux Security 集成时,Spring Security 会根据经过身份验证的用户自动建立 Reactor 上下文。
Java
Kotlin
@EnableWebFluxSecurity
SecurityWebFilterChain springWebFilterChain(ServerHttpSecurity http) throws Exception {
return http
// Demonstrate that method security works
// Best practice to use both for defense in depth
.authorizeExchange(exchanges -> exchanges
.anyExchange().permitAll()
.httpBasic(withDefaults())
.password("rob")
.roles("USER")
.password("admin")
open fun springWebFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
return http {
authorizeExchange {
authorize(anyExchange, permitAll)
httpBasic { }
.password("rob")
.roles("USER")
.build()
.password("admin")
.build()
您可以在 hellowebflux-method 中找到完整的示例
