EnableReactiveMethodSecurity
Spring Security supports method security using Reactor’s Context which is setup using ReactiveSecurityContextHolder. For example, this demonstrates how to retrieve the currently logged in user’s message.spring-doc.cn
For this to work the return type of the method must be a org.reactivestreams.Publisher (i.e. Mono/Flux) or the function must be a Kotlin coroutine function. This is necessary to integrate with Reactor’s Context.spring-doc.cn
Authentication authentication = new TestingAuthenticationToken("user", "password", "ROLE_USER");
Mono<String> messageByUsername = ReactiveSecurityContextHolder.getContext()
	.map(SecurityContext::getAuthentication)
	.map(Authentication::getName)
	.flatMap(this::findMessageByUsername)
	// In a WebFlux application the `subscriberContext` is automatically setup using `ReactorContextWebFilter`
	.subscriberContext(ReactiveSecurityContextHolder.withAuthentication(authentication));
StepVerifier.create(messageByUsername)
	.expectNext("Hi user")
	.verifyComplete();
val authentication: Authentication = TestingAuthenticationToken("user", "password", "ROLE_USER")
val messageByUsername: Mono<String> = ReactiveSecurityContextHolder.getContext()
	.flatMap(this::findMessageByUsername) // In a WebFlux application the `subscriberContext` is automatically setup using `ReactorContextWebFilter`
	.verifyComplete()
with this::findMessageByUsername defined as:spring-doc.cn
Mono<String> findMessageByUsername(String username) {
	return Mono.just("Hi " + username);
fun findMessageByUsername(username: String): Mono<String> {
	return Mono.just("Hi $username")
Below is a minimal method security configuration when using method security in reactive applications.spring-doc.cn
@EnableReactiveMethodSecurity
public class SecurityConfig {
	public MapReactiveUserDetailsService userDetailsService() {
		User.UserBuilder userBuilder = User.withDefaultPasswordEncoder();
		UserDetails rob = userBuilder.username("rob")
			.password("rob")
			.roles("USER")
		UserDetails admin = userBuilder.username("admin")
			.password("admin")
			.roles("USER","ADMIN")
		return new MapReactiveUserDetailsService(rob, admin);
	fun userDetailsService(): MapReactiveUserDetailsService {
		val userBuilder: User.UserBuilder = User.withDefaultPasswordEncoder()
		val rob = userBuilder.username("rob")
			.password("rob")
			.roles("USER")
			.build()
		val admin = userBuilder.username("admin")
			.password("admin")
			.roles("USER", "ADMIN")
			.build()
		return MapReactiveUserDetailsService(rob, admin)
Consider the following class:spring-doc.cn
@Component
public class HelloWorldMessageService {
	@PreAuthorize("hasRole('ADMIN')")
	public Mono<String> findMessage() {
		return Mono.just("Hello World!");
@Component
	fun findMessage(): Mono<String> {
Or, the following class using Kotlin coroutines:spring-doc.cn
@Component
    suspend fun findMessage(): String {
        delay(10)
        return "Hello World!"
Combined with our configuration above, @PreAuthorize("hasRole('ADMIN')") will ensure that findByMessage is only invoked by a user with the role ADMIN. It is important to note that any of the expressions in standard method security work for @EnableReactiveMethodSecurity. However, at this time we only support return type of Boolean or boolean of the expression. This means that the expression must not block.spring-doc.cn
When integrating with WebFlux Security, the Reactor Context is automatically established by Spring Security according to the authenticated user.spring-doc.cn
@EnableWebFluxSecurity
	SecurityWebFilterChain springWebFilterChain(ServerHttpSecurity http) throws Exception {
		return http
			// Demonstrate that method security works
			// Best practice to use both for defense in depth
			.authorizeExchange(exchanges -> exchanges
				.anyExchange().permitAll()
			.httpBasic(withDefaults())
			.password("rob")
			.roles("USER")
			.password("admin")
	open fun springWebFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
		return http {
			authorizeExchange {
				authorize(anyExchange, permitAll)
			httpBasic { }
			.password("rob")
			.roles("USER")
			.build()
			.password("admin")
			.build()
You can find a complete sample in hellowebflux-methodspring-doc.cn
