This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Security 6.4.1!spring-doc.cn
Method Security
From version 2.0 onwards Spring Security has improved support substantially for adding security to your service layer methods. It provides support for JSR-250 annotation security as well as the framework’s original @Secured annotation. From 3.0 you can also make use of new expression-based annotations. You can apply security to a single bean, using the intercept-methods element to decorate the bean declaration, or you can secure multiple beans across the entire service layer using the AspectJ style pointcuts.spring-doc.cn
EnableMethodSecurity
In Spring Security 5.6, we can enable annotation-based security using the @EnableMethodSecurity annotation on any @Configuration instance.spring-doc.cn
This improves upon @EnableGlobalMethodSecurity in a number of ways. @EnableMethodSecurity:spring-doc.cn
  1. Uses the simplified AuthorizationManager API instead of metadata sources, config attributes, decision managers, and voters. This simplifies reuse and customization.spring-doc.cn
  2. Favors direct bean-based configuration, instead of requiring extending GlobalMethodSecurityConfiguration to customize beansspring-doc.cn
  3. Is built using native Spring AOP, removing abstractions and allowing you to use Spring AOP building blocks to customizespring-doc.cn
  4. Checks for conflicting annotations to ensure an unambiguous security configurationspring-doc.cn
  5. Complies with JSR-250spring-doc.cn
  6. Enables @PreAuthorize, @PostAuthorize, @PreFilter, and @PostFilter by defaultspring-doc.cn
For earlier versions, please read about similar support with @EnableGlobalMethodSecurity.spring-doc.cn
For example, the following would enable Spring Security’s @PreAuthorize annotation:spring-doc.cn
Method Security Configuration
public class MethodSecurityConfig {
<sec:method-security/>
Adding an annotation to a method (on a class or interface) would then limit the access to that method accordingly. Spring Security’s native annotation support defines a set of attributes for the method. These will be passed to the DefaultAuthorizationMethodInterceptorChain for it to make the actual decision:spring-doc.cn
Method Security Annotation Usage
public interface BankService {
	@PreAuthorize("hasRole('USER')")
	Account readAccount(Long id);
	List<Account> findAccounts();
	@PreAuthorize("hasRole('TELLER')")
	Account post(Account account, Double amount);
	fun readAccount(id : Long) : Account
	fun findAccounts() : List<Account>
	fun post(account : Account, amount : Double) : Account
You can enable support for Spring Security’s @Secured annotation using:spring-doc.cn
@Secured Configuration
@EnableMethodSecurity(securedEnabled = true)
<sec:method-security secured-enabled="true"/>
or JSR-250 using:spring-doc.cn
JSR-250 Configuration
@EnableMethodSecurity(jsr250Enabled = true)
<sec:method-security jsr250-enabled="true"/>
Customizing Authorization
Spring Security’s @PreAuthorize, @PostAuthorize, @PreFilter, and @PostFilter ship with rich expression-based support.spring-doc.cn
If you need to customize the way that expressions are handled, you can expose a custom MethodSecurityExpressionHandler, like so:spring-doc.cn
Custom MethodSecurityExpressionHandler
static MethodSecurityExpressionHandler methodSecurityExpressionHandler() {
	DefaultMethodSecurityExpressionHandler handler = new DefaultMethodSecurityExpressionHandler();
	handler.setTrustResolver(myCustomTrustResolver);
	return handler;
companion object {
	fun methodSecurityExpressionHandler() : MethodSecurityExpressionHandler {
		val handler = DefaultMethodSecurityExpressionHandler();
		return handler;
<sec:method-security>
	<sec:expression-handler ref="myExpressionHandler"/>
</sec:method-security>
<bean id="myExpressionHandler"
		class="org.springframework.security.messaging.access.expression.DefaultMessageSecurityExpressionHandler">
	<property name="trustResolver" ref="myCustomTrustResolver"/>
</bean>
We expose MethodSecurityExpressionHandler using a static method to ensure that Spring publishes it before it initializes Spring Security’s method security @Configuration classesspring-doc.cn
Also, for role-based authorization, Spring Security adds a default ROLE_ prefix, which is uses when evaluating expressions like hasRole.spring-doc.cn
You can configure the authorization rules to use a different prefix by exposing a GrantedAuthorityDefaults bean, like so:spring-doc.cn
static GrantedAuthorityDefaults grantedAuthorityDefaults() {
	return new GrantedAuthorityDefaults("MYPREFIX_");
companion object {
	fun grantedAuthorityDefaults() : GrantedAuthorityDefaults {
		return GrantedAuthorityDefaults("MYPREFIX_");
<bean id="grantedAuthorityDefaults" class="org.springframework.security.config.core.GrantedAuthorityDefaults">
	<constructor-arg value="MYPREFIX_"/>
</bean>
We expose GrantedAuthorityDefaults using a static method to ensure that Spring publishes it before it initializes Spring Security’s method security @Configuration classesspring-doc.cn
Custom Authorization Managers
Method authorization is a combination of before- and after-method authorization.spring-doc.cn
Before-method authorization is performed before the method is invoked. If that authorization denies access, the method is not invoked, and an AccessDeniedException is thrown After-method authorization is performed after the method is invoked, but before the method returns to the caller. If that authorization denies access, the value is not returned, and an AccessDeniedException is thrownspring-doc.cn
To recreate what adding @EnableMethodSecurity does by default, you would publish the following configuration:spring-doc.cn
Full Pre-post Method Security Configuration
@EnableMethodSecurity(prePostEnabled = false)
	@Role(BeanDefinition.ROLE_INFRASTRUCTURE)
	Advisor preFilterAuthorizationMethodInterceptor() {
		return new PreFilterAuthorizationMethodInterceptor();
	Advisor preAuthorizeAuthorizationMethodInterceptor() {
		return AuthorizationManagerBeforeMethodInterceptor.preAuthorize();
	Advisor postAuthorizeAuthorizationMethodInterceptor() {
		return AuthorizationManagerAfterMethodInterceptor.postAuthorize();
	Advisor postFilterAuthorizationMethodInterceptor() {
		return new PostFilterAuthorizationMethodInterceptor();
	fun preFilterAuthorizationMethodInterceptor() : Advisor {
		return PreFilterAuthorizationMethodInterceptor();
	fun preAuthorizeAuthorizationMethodInterceptor() : Advisor {
	fun postAuthorizeAuthorizationMethodInterceptor() : Advisor {
	fun postFilterAuthorizationMethodInterceptor() : Advisor {
		return PostFilterAuthorizationMethodInterceptor();
<sec:method-security pre-post-enabled="false"/>
<aop:config/>
<bean id="preFilterAuthorizationMethodInterceptor"
		class="org.springframework.security.authorization.method.PreFilterAuthorizationMethodInterceptor"/>
<bean id="preAuthorizeAuthorizationMethodInterceptor"
		class="org.springframework.security.authorization.method.AuthorizationManagerBeforeMethodInterceptor"
		factory-method="preAuthorize"/>
<bean id="postAuthorizeAuthorizationMethodInterceptor"
		class="org.springframework.security.authorization.method.AuthorizationManagerAfterMethodInterceptor"
		factory-method="postAuthorize"/>
<bean id="postFilterAuthorizationMethodInterceptor"
		class="org.springframework.security.authorization.method.PostFilterAuthorizationMethodInterceptor"/>
Notice that Spring Security’s method security is built using Spring AOP. So, interceptors are invoked based on the order specified. This can be customized by calling setOrder on the interceptor instances like so:spring-doc.cn
Publish Custom Advisor
	PostFilterAuthorizationMethodInterceptor interceptor = new PostFilterAuthorizationMethodInterceptor();
	interceptor.setOrder(AuthorizationInterceptorOrders.POST_AUTHORIZE.getOrder() - 1);
	return interceptor;
	val interceptor = PostFilterAuthorizationMethodInterceptor();
	return interceptor;
		class="org.springframework.security.authorization.method.PostFilterAuthorizationMethodInterceptor">
	<property name="order"
			value="#{T(org.springframework.security.authorization.method.AuthorizationInterceptorsOrder).POST_AUTHORIZE.getOrder() -1}"/>
</bean>
You may want to only support @PreAuthorize in your application, in which case you can do the following:spring-doc.cn
Only @PreAuthorize Configuration
	Advisor preAuthorize() {
	fun preAuthorize() : Advisor {
<aop:config/>
Or, you may have a custom before-method AuthorizationManager that you want to add to the list.spring-doc.cn
In this case, you will need to tell Spring Security both the AuthorizationManager and to which methods and classes your authorization manager applies.spring-doc.cn
Thus, you can configure Spring Security to invoke your AuthorizationManager in between @PreAuthorize and @PostAuthorize like so:spring-doc.cn
Custom Before Advisor
	public Advisor customAuthorize() {
		JdkRegexpMethodPointcut pattern = new JdkRegexpMethodPointcut();
		pattern.setPattern("org.mycompany.myapp.service.*");
		AuthorizationManager<MethodInvocation> rule = AuthorityAuthorizationManager.isAuthenticated();
		AuthorizationManagerBeforeMethodInterceptor interceptor = new AuthorizationManagerBeforeMethodInterceptor(pattern, rule);
		interceptor.setOrder(AuthorizationInterceptorsOrder.PRE_AUTHORIZE_ADVISOR_ORDER.getOrder() + 1);
		return interceptor;
	fun customAuthorize() : Advisor {
		val pattern = JdkRegexpMethodPointcut();
		val rule = AuthorityAuthorizationManager.isAuthenticated();
		val interceptor = AuthorizationManagerBeforeMethodInterceptor(pattern, rule);
		return interceptor;
<aop:config/>
<bean id="customAuthorize"
		class="org.springframework.security.authorization.method.AuthorizationManagerBeforeMethodInterceptor">
	<constructor-arg>
		<bean class="org.springframework.aop.support.JdkRegexpMethodPointcut">
			<property name="pattern" value="org.mycompany.myapp.service.*"/>
		</bean>
	</constructor-arg>
	<constructor-arg>
		<bean class="org.springframework.security.authorization.AuthorityAuthorizationManager"
				factory-method="isAuthenticated"/>
	</constructor-arg>
			value="#{T(org.springframework.security.authorization.method.AuthorizationInterceptorsOrder).PRE_AUTHORIZE_ADVISOR_ORDER.getOrder() + 1}"/>
</bean>
You can place your interceptor in between Spring Security method interceptors using the order constants specified in AuthorizationInterceptorsOrder.spring-doc.cn
The same can be done for after-method authorization. After-method authorization is generally concerned with analysing the return value to verify access.spring-doc.cn
For example, you might have a method that confirms that the account requested actually belongs to the logged-in user like so:spring-doc.cn
@PostAuthorize example
	@PostAuthorize("returnObject.owner == authentication.name")
You can supply your own AuthorizationMethodInterceptor to customize how access to the return value is evaluated.spring-doc.cn
For example, if you have your own custom annotation, you can configure it like so:spring-doc.cn
Custom After Advisor
	public Advisor customAuthorize(AuthorizationManager<MethodInvocationResult> rules) {
		AnnotationMatchingPointcut pattern = new AnnotationMatchingPointcut(MySecurityAnnotation.class);
		AuthorizationManagerAfterMethodInterceptor interceptor = new AuthorizationManagerAfterMethodInterceptor(pattern, rules);
		interceptor.setOrder(AuthorizationInterceptorsOrder.POST_AUTHORIZE_ADVISOR_ORDER.getOrder() + 1);
		return interceptor;
	fun customAuthorize(rules : AuthorizationManager<MethodInvocationResult>) : Advisor {
		val pattern = AnnotationMatchingPointcut(MySecurityAnnotation::class.java);
		val interceptor = AuthorizationManagerAfterMethodInterceptor(pattern, rules);
		return interceptor;
<aop:config/>
		class="org.springframework.security.authorization.method.AuthorizationManagerAfterMethodInterceptor">
	<constructor-arg>
		<bean class="org.springframework.aop.support.annotation.AnnotationMethodMatcher">
			<constructor-arg value="#{T(org.mycompany.MySecurityAnnotation)}"/>
		</bean>
	</constructor-arg>
	<constructor-arg>
	</constructor-arg>
</bean>
and it will be invoked after the @PostAuthorize interceptor.spring-doc.cn
We can enable annotation-based security using the @EnableGlobalMethodSecurity annotation on any @Configuration instance. For example, the following would enable Spring Security’s @Secured annotation.spring-doc.cn
@EnableGlobalMethodSecurity(securedEnabled = true)
open class MethodSecurityConfig {
Adding an annotation to a method (on a class or interface) would then limit the access to that method accordingly. Spring Security’s native annotation support defines a set of attributes for the method. These will be passed to the AccessDecisionManager for it to make the actual decision:spring-doc.cn
@Secured("IS_AUTHENTICATED_ANONYMOUSLY")
public Account readAccount(Long id);
public Account[] findAccounts();
@Secured("ROLE_TELLER")
public Account post(Account account, double amount);
    fun readAccount(id: Long): Account
    fun findAccounts(): Array<Account>
    fun post(account: Account, amount: Double): Account
Support for JSR-250 annotations can be enabled usingspring-doc.cn
@EnableGlobalMethodSecurity(jsr250Enabled = true)
These are standards-based and allow simple role-based constraints to be applied but do not have the power Spring Security’s native annotations. To use the new expression-based syntax, you would usespring-doc.cn
@EnableGlobalMethodSecurity(prePostEnabled = true)
and the equivalent Java code would bespring-doc.cn
@PreAuthorize("isAnonymous()")
@PreAuthorize("hasAuthority('ROLE_TELLER')")
Sometimes you may need to perform operations that are more complicated than are possible with the @EnableGlobalMethodSecurity annotation allow. For these instances, you can extend the GlobalMethodSecurityConfiguration ensuring that the @EnableGlobalMethodSecurity annotation is present on your subclass. For example, if you wanted to provide a custom MethodSecurityExpressionHandler, you could use the following configuration:spring-doc.cn
public class MethodSecurityConfig extends GlobalMethodSecurityConfiguration {
	protected MethodSecurityExpressionHandler createExpressionHandler() {
		// ... create and return custom MethodSecurityExpressionHandler ...
		return expressionHandler;
open class MethodSecurityConfig : GlobalMethodSecurityConfiguration() {
    override fun createExpressionHandler(): MethodSecurityExpressionHandler {
For additional information about methods that can be overridden, refer to the GlobalMethodSecurityConfiguration Javadoc.spring-doc.cn
The <global-method-security> Element
This element is used to enable annotation-based security in your application (by setting the appropriate attributes on the element), and also to group together security pointcut declarations which will be applied across your entire application context. You should only declare one <global-method-security> element. The following declaration would enable support for Spring Security’s @Secured:spring-doc.cn
<global-method-security secured-annotations="enabled" />
Adding an annotation to a method (on an class or interface) would then limit the access to that method accordingly. Spring Security’s native annotation support defines a set of attributes for the method. These will be passed to the AccessDecisionManager for it to make the actual decision:spring-doc.cn
<global-method-security jsr250-annotations="enabled" />
<global-method-security pre-post-annotations="enabled" />
Expression-based annotations are a good choice if you need to define simple rules that go beyond checking the role names against the user’s list of authorities.spring-doc.cn
The annotated methods will only be secured for instances which are defined as Spring beans (in the same application context in which method-security is enabled). If you want to secure instances which are not created by Spring (using the new operator, for example) then you need to use AspectJ.spring-doc.cn
You can enable more than one type of annotation in the same application, but only one type should be used for any interface or class as the behaviour will not be well-defined otherwise. If two annotations are found which apply to a particular method, then only one of them will be applied.spring-doc.cn
Adding Security Pointcuts using protect-pointcut
The use of protect-pointcut is particularly powerful, as it allows you to apply security to many beans with only a simple declaration. Consider the following example:spring-doc.cn
<protect-pointcut expression="execution(* com.mycompany.*Service.*(..))"
	access="ROLE_USER"/>
</global-method-security>
This will protect all methods on beans declared in the application context whose classes are in the com.mycompany package and whose class names end in "Service". Only users with the ROLE_USER role will be able to invoke these methods. As with URL matching, the most specific matches must come first in the list of pointcuts, as the first matching expression will be used. Security annotations take precedence over pointcuts.spring-doc.cn
